How deep I can go? - JeepForum.com
post #1 of 56 Old 01-05-2008, 09:53 AM Thread Starter
sportman
How deep I can go?
I never try to go in deep water..maybe this clip will answer part of my Q yah it seams JK can go through such deep water..but what is the limit and did someone try to drive in deep river without modifying his JK?
http://www.youtube.com/watch?v=iHVkh...eature=related
sportman is offline
post #2 of 56 Old 01-05-2008, 10:16 AM
nd95450
I don't have the balls for that.
nd95450 is offline
post #3 of 56 Old 01-05-2008, 10:36 AM
newguy66
newguy66's Avatar
I'll try it......when my Jeep is finally payed off.
2008 Unlimited 4X4,hard top,rescue green,manual,power group,limited slip and Sirius.
Teraflex 2.5BBw/shocks,33''Hankook Dynapro mt's on AEV's.Skid Row front skid plate.AEV snorkel.Tough stuff
hood rack.
newguy66 is offline
post #4 of 56 Old 01-05-2008, 10:55 AM
BirdsFanVa
BirdsFanVa's Avatar
Yep it can. I have had some water on the inside. Keep the corner of the hood on the passenger side above the water and your fine. Be aware that you need to check all fluids for contamination after a run like that. I have not had a problem with gear oil yet in the diffs, but did drain my t-case.
Have fun out there, but be smart. I would recommend a snorkel if you plan on that all the time.
07 Black Sahara Unlimited 2.5" Skyjacker suspension lift, RE quick discos, 3/4" front spacers, 16x8 soft 8's, BFG 33x12.50's MT's, Shrockworks rock rails. Bulldog rock crawler winch bumper, Warn M8000 and lot's of armor! (Mine)
08 Redrock X Unlimited (Hers)
____________________________________________
Driving a Jeep to work makes it feel like you're going camping!
BirdsFanVa is offline
post #5 of 56 Old 01-05-2008, 11:58 AM
donkie
See part three http://www.youtube.com/watch?v=p3tW_S8tblQ&NR=1
Sucked in some water on that run near the 44 second mark, also blue smoke at 38 seconds might have been then too. Custom ventilated block for sale...
Unless it is for your survival why would anyone go through water this deep? Get a snorkel!
Warning: Jeep death photos below!
Engine is not running anymore. FAIL
Recovering Jeepaholic
2007 Wrangler Sahara - SOLD
Geaux Tigers!!!
donkie is offline
post #6 of 56 Old 01-05-2008, 12:07 PM
ZX14Rider
ZX14Rider's Avatar
I second that, this thing has to last me a while as a daily driver..I'm more than content watching others from the sideline....
ZX14Rider is offline
post #7 of 56 Old 01-05-2008, 01:20 PM
MiamiPaco
I'm part of that club!
MiamiPaco is offline
post #8 of 56 Old 01-05-2008, 01:27 PM
wrnglrguy
wrnglrguy's Avatar
You can run it into water that is about as deep as your fender flares and not worry too much. There is no distributor cap, so it can't get wet like older Jeeps. The air intake comes up to (about) the top of the hood. So, as long as the water does not exceed the top of your hood, you're fine. I haven't done it in my JK (yet), but I did in my TJ. I had water coming inside the Jeep, but with the drain plugs in the floorboard, that is easy to get cleaned up and dried out.
wrnglrguy is offline
post #9 of 56 Old 01-05-2008, 01:49 PM
hig4s
the JK manual page 288 says 20 inches @ less than 5 mph. Also remember if you have a manual trans you shouldn't use the clutch while in water, manual clutches are not water tight and will lets water between the friction plate and clutch plate.
hig4s is offline
post #10 of 56 Old 01-05-2008, 01:53 PM
jeepxj91
1991 XJ Cherokee
ha maybe this will answer your question
this video is insane
http://www.youtube.com/watch?v=xMCfan0upRg
jeepxj91 is offline
post #11 of 56 Old 01-05-2008, 02:03 PM
JeepMan1975
This thread topic sounds dirty.
To answer the question, 20 inches (508mm, 50.8cm, 0.508m) is the limit on a stock JK.
JeepMan1975 is offline
post #12 of 56 Old 01-05-2008, 03:22 PM
wrnglrguy
wrnglrguy's Avatar
The manual say 20", but trust me, it will go deeper than that. The manual says that for safety reasons. I would imagine Porsche manuals probably say drive 55, but we all know they go faster then that.
post #13 of 56 Old 01-05-2008, 04:45 PM
mrsig
I have been up to my windshield with out any problems at all! Why?
http://www.youtube.com/watch?v=ld0wMSGt1w0
This was the hole that was over my hood!
JK 4 Door Auto, 33" BFG MTKs, River Raider Ram Air Snorkel System with a K&N flat filter, Cool Tech Exhaust, 410 Gears, Front & Rear Lockers with OX covers, 2.5" Suspension Lift with Heavy Duty Gas Shocks, Piaa Yellow Ion Fog Lights, Custom Built Steel Front Ram Bumper with White Fog Lights, 10,000 lbs Front or Rear Removable Winch, Garmin Jeep Trail Guide Navigation System with Topo, Sirius Satellite 6 disk in dash changer Infinity system, Full Rubber Floors and Custom Fit Neoprene Seat Covers. For photos of my Jeep in action go to http://www.aaof.us/jeep.htm
mrsig is offline
post #14 of 56 Old 01-05-2008, 09:19 PM
wrnglrguy
wrnglrguy's Avatar
Hey! You're cheating, mister "I have a snorkel"
Jeeps have always been notorious for forging water better than anything else. The high air intake helps. Of course, the snorkel helps more. Nice pics by the way.
post #15 of 56 Old 01-05-2008, 10:24 PM
BigJerm
but a snorkel wont solve all your problems... snorkels dont keep electronics dry.
Like others have said, the manual says 20". Ive been over the headlights for a few seconds, just dont get it over the hood or your intake will be sucking in water. Best bet is if you dont know how deep something is, dont go through it. And if you suddenly take a nose dive turn the jeep off quickly and you MIGHT save yourself after you do some things to insure no water is in the engine.
07 Jeep Wrangler Unlimited Rubicon
BigJerm is offline
How deep is too deep? ggrodregez TJ Wrangler Technical Forum 70 08-01-2007 10:09 AM
How deep is too deep? sccabrian TJ Wrangler Technical Forum 23 06-14-2007 03:12 AM
I was in deep !#@$ dbikers YJ Wrangler Technical Forum 5 10-08-2006 07:47 PM
WATER : How deep is too deep? msavard TJ Wrangler Technical Forum 39 06-23-2006 07:37 PM
Water crossings: How deep is too deep? Dirty Backroads TJ Wrangler Technical Forum 32 11-27-2005 06:18 AM
