How could I be having radiator issues? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > How could I be having radiator issues?
Bill Baird Motorsports DIY parts - NalinMFG.comFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 07-26-2014, 05:32 AM   #1
joeorzechowski
joeorzechowski's Avatar
2010 JK Wrangler
JK with 31k, didn't run for a week, pulled out with no warmup, went 5 miles to get coffee, noticed alot of white steam coming from the radiator. Did not smell smoke. Fluid is ok, not full- about 1/3 full, radiator maybe looked a little black or singed on part of the front. Just had a flush about 3k ago. No smell. No leaks.
Is that normal? Did not see if the engine was running hot. Pulled over then drove home 3 miles.
joeorzechowski is offline   Reply With Quote
Unread 07-26-2014, 07:42 AM   #2
ncb
Condensation/water on the radiator will cause steam. Mine does it on certain days. After the car wash it makes lots of steam out of the grill.
ncb is offline   Reply With Quote
Unread 07-26-2014, 08:28 AM   #3
joeorzechowski
2010 JK Wrangler
it must have been condensation then, it is always garaged, but the garage is usually quite hot in there. Thanks for the advice. By the way I have definitely had that steam issue in rainstorms. Its a bit unnerving.
