How to check for bad control arms? - JeepForum.com
post #1 of 3 Old 12-26-2008, 09:51 PM Thread Starter
Hellbound13
How do you check to see if your control arms are bad? By looking at them the rubber looks fine, they look like thin flat disc shapes between the control arm and the body, is this right?
Also if I try to move them by hand there is BARELY any play in them. Do I need to have the Jeep lifted off the ground to check them?
I can't figure out how you know you have a bad one?
Hellbound13 is offline
post #2 of 3 Old 12-26-2008, 10:07 PM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Why do you think you have a bad one?
Generally you'll see play. Go under the jeep, lay on your back, put your foot against a tire and rock the jeep with your legs. If you see play in the bushings then you may want to replace that arms bushings or the entire arm itself.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #3 of 3 Old 12-26-2008, 10:18 PM Thread Starter
Hellbound13
Im not fully understanding what you mean..
Just push on the tire with my foot while under the Jeep? How much play should I look for?
Rusty's Control Arms vs. RE Control Arms? wrangler2007 TJ Wrangler Technical Forum 26 04-12-2010 10:57 PM
Can I use stock control arm bolts on Rubicon Express control arms? LGriffith TJ Wrangler Technical Forum 2 01-10-2010 01:11 PM
Fixed control arms>Stock control arms $lick TJ Wrangler Technical Forum 12 03-21-2009 04:08 PM
regular control arms vs. heim joint control arms. lucasinpsj TJ Wrangler Technical Forum 7 10-27-2004 02:35 AM
upgrading stock control arms with--->ZJ arms?? Dave Taylor TJ Wrangler Technical Forum 8 02-19-2004 12:23 AM
