How big of tires can you go with stock wheels + lift? - JeepForum.com
post #1 of 3 Old 06-02-2014, 01:50 PM Thread Starter
willcherokeexj
2014 JK Wrangler
I wanted to keep my Willy's Wheeler black rubi wheels. I am thinking a 1.5-2.5 inch lift. Could I put bigger tires if I do that without rubbing?
2000 XJ - traded in
2014 JK - Willy's Wheeler Edition
willcherokeexj is offline
post #2 of 3 Old 06-02-2014, 03:22 PM
HappyTrails
HappyTrails's Avatar
With the stock lift, you can go as high as 35" tires. I wouldn't take it off-road, however. You will probably rub the lower control arms unless you change the wheels to ones with 4.5" backspacing or less. Stock wheels have 6.75" backspacing, I believe.
If you want to keep the stock wheels, put some wheels spacers on (recommend 1.5" spacers). That will get your backspacing down to about 5.25", close but not perfect.
At 1.5" of lift and 35" tires, you can take it off-road, but be sure to have extended bumpstops.
At 2.5" of lift and 35" tires, you can take it off-road (again with extended bumpstops) and do very well.
At 2.5" of lift and flat fenders, you can fit 37" tires (again again with extended bumpstops) and rock that ****!
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #3 of 3 Old 06-02-2014, 03:56 PM
SLADE
Stock 17" wheels have 6.25" back spacing.
1.5" wheel spacers will put you at 4.75" of back spacing.
You can run 35's on 5" of back spacing with mild rubbing on the air dam.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
