how to add uconnect - JeepForum.com
post #1 of 20 Old 09-27-2009, 11:28 PM Thread Starter
TYPHOON4X4
how to add uconnect
id like to add uconnect to my rubi. parts part numbers etc thanks in advance
TYPHOON4X4 is offline
post #2 of 20 Old 09-28-2009, 09:40 AM
TJ Willy
TJ Willy's Avatar
+1 on this....
2008 JK Unlimited Sahara -
SOLD: 99 TJ
SOLD: 04 TJ Willys Ed.
TJ Willy is offline
post #3 of 20 Old 09-28-2009, 09:43 AM
Jerzjeep
2009 JK Wrangler
this site will help
MYGIG MICROPHONE
2009 Sahara 2dr 2.5" RC coil lift, DCl 16x8 wheels, DC FCll 285/75R16 tires, Rampage Recovery bumpers F & R
Jerzjeep is offline
post #4 of 20 Old 09-28-2009, 12:47 PM
99TJSport
99TJSport's Avatar
Does it have a MyGig Nav unit or not? That will make a HUGE difference in the answer...
Jeff
08 Rubicon Unlimited, 2.5TF Lift, 285/70/17 BFG KM2s, lots of skids, MyGig, and both sets of doors/tops.
Parrothead Jeepers Union #24
99TJSport is offline
post #5 of 20 Old 09-28-2009, 01:06 PM
Professorkx
Agree. We don't have navigation, but would sure like to use the hands free phone system...if that's what the thing does. Hard to tell from the owners manual...
Professorkx is offline
post #6 of 20 Old 09-28-2009, 01:58 PM
Jerzjeep
2009 JK Wrangler
without the nav radio I would read this thread
http://www.jeepforum.com/forum/f96/i...-mygig-497556/
Jerzjeep is offline
post #7 of 20 Old 09-28-2009, 02:30 PM
waterboarder
waterboarder's Avatar
I think we get a new version of this thread every week. If you search for "uconnect" in this forum, you will find a lot of info.
waterboarder is offline
post #8 of 20 Old 09-28-2009, 06:13 PM Thread Starter
TYPHOON4X4
oh i do have mygig with sat nav.
post #9 of 20 Old 09-28-2009, 08:37 PM
99TJSport
99TJSport's Avatar
MyGig with Nav...you just need the mic kit (82211743AB) which is ab out $40 at the dealership. Then go into the engineering menu and "Enable JK HF/VR" and you're all set.
Jeff
post #10 of 20 Old 09-28-2009, 09:11 PM
NJeep09
2009 JK Wrangler
works great after the mic is installed
had it installed by the dealer, but if you have the time and inclination you can do it your self. If it wasn't for this forum I would never have known about the mic, as the dealer sure didnt seem aware of it until I kept asking about it.
2000 Black Sahara - 4.0L Auto
2009 Black Sahara - 2dr -6spd
RIPP Supercharger
Magnaflow Catback
Delta Light Bars
Rugged Ridge Grill inserts
Off Road Trailer -
4.88 Superior Gears
Front & Rear ARB lockers
3.25" RC lift
35 inch DC's
NJeep09 is offline
post #11 of 20 Old 09-29-2009, 02:45 PM Thread Starter
TYPHOON4X4
well thanks for the help so far .i bought the kit disassembled the dash cliped the mic into the only port it would fit into the rear then i ran the mic up the back along the top . i havent decided yet where to install it if there is a space its supposed to go in do tell im all ears. the kit came with a disk . i looked for the engineering menu and as hard as lokked i could seem to find that menu and the disk just reads data and nothing happens what am i doing wrong ?
post #12 of 20 Old 09-29-2009, 03:17 PM
99TJSport
99TJSport's Avatar
The engineering menu is brought up by pressing Seek Up, Seek Down, and Menu all at once. Go down to page 4 or 5 and you'll see a soft key that says "Enable JK HF/VR". Press that key and the Uconnect will now be active, and the key will change to "Disable" instead. Exit it out of the menu and now when you press UConnect, you should be give the "Uconnect" prompt from the speakers. If it doesn't take the first time (mine didn't), Go back in and disable, then renable it and it'll work.
The disc in the kit is a PDF of instructions, won't play in the MyGig.
Also, make sure your software is up to date on the MyGig. The older versions didn't have the "Enable" button in the engineering menu, feature was added later. The latest and greatest software (1.220 official and 2.042 beta (which I run)) can be downloaded at the Unofficial MyGig site, http://mofv.com/mygig
Jeff
post #13 of 20 Old 09-29-2009, 03:44 PM Thread Starter
TYPHOON4X4
dude tahnks a ton it worked on the first try thanks
post #14 of 20 Old 09-29-2009, 07:47 PM
99TJSport
99TJSport's Avatar
Awesome...glad everything worked out for you.
I have wayyyy too much experience with these radios lol...
Jeff
post #15 of 20 Old 09-29-2009, 08:47 PM Thread Starter
TYPHOON4X4
really thanks any other functions i should know about ? lolololol
UConnect. yellowx13 JK Wrangler Technical Forum 5 02-04-2010 08:18 PM
Uconnect rockeye JK Wrangler Technical Forum 1 10-01-2009 08:09 AM
UConnect pcj14 JK Wrangler Technical Forum 3 10-31-2008 06:03 AM
What's up with UConnect michaelkern JK Wrangler Technical Forum 25 10-17-2007 09:26 AM
UConnect pcj14 JK Wrangler Technical Forum 10 11-13-2006 03:05 PM
