Horn for jk - JeepForum.com
post #1 of 24 Old 01-31-2012, 01:22 PM Thread Starter
BigBlue7
2010 JK Wrangler
Horn for jk
Im looking for suggestions on a replacement horn for a JK. If anyone can recommend a good horn and has pictures of an install, please share! I was checking out the Grover 1510 Emergency Air Horn. Pretty awesome! Not too knowledgeable with air horns and what all is required though. Also, I have seen people with the PIAA 400 500, which would be great if it sounds loud and if it's easy to install.
BigBlue7 is offline
post #2 of 24 Old 01-31-2012, 01:30 PM
fmfa0801
2009 JK Wrangler
I am getting this one. I am also gona try and hook it up to air up tires with it too.
http://trainhornsdelivered.com/maxlevelthree.html
fmfa0801 is offline
post #3 of 24 Old 01-31-2012, 01:37 PM Thread Starter
BigBlue7
2010 JK Wrangler
Very cool, good luck with the install! - I'm sure all trian horns require a lot of space. So ill prop go with a regular horn, just want a loud deep one!
BigBlue7 is offline
post #4 of 24 Old 01-31-2012, 01:39 PM
kik
I and a bunch of others have the PIAA 400/500hz horns. They work great, easy to install and loud enough.
kik is offline
post #5 of 24 Old 01-31-2012, 02:12 PM
Joevacs
2010 JK Wrangler
I've got this one. The horns fit nicely between the radiator and the engine, pointed strait down ( the loadest ), and the tank is under the passenger seat, the compressor is in front of the battery
http://www.hornblasters.com/products...train-horn-kit
2010 Rubicon, 4" lift, Currie control arms and trackbar, 40" Procomp MTR
Joevacs is offline
post #6 of 24 Old 01-31-2012, 02:18 PM
ncb
Nice horns.
ncb is offline
post #7 of 24 Old 01-31-2012, 02:35 PM Thread Starter
BigBlue7
2010 JK Wrangler
LOUD and HUGE!
BigBlue7 is offline
post #8 of 24 Old 01-31-2012, 03:03 PM
billypete
I put the WOLO Bad Boy air horn in the same location as the stock horn, it is plenty LOUD now!
http://www.amazon.com/Wolo-Model-419-Black-Design/dp/B000F5DQWY/ref=sr_1_1?s=automotive&ie=UTF8&qid=1328047431&sr=1-1
2012 Orange Crush Sahara 2dr.
billypete is offline
post #9 of 24 Old 01-31-2012, 04:29 PM Thread Starter
BigBlue7
2010 JK Wrangler
That's the one I just started looking at! Does it require any other equipment, i.e. air compressor, or any tanks???
Rock Krawler | TeraFlex | Synergy | Fox | Poison Spyder | Genright | Nemesis |Beer
BigBlue7 is offline
post #10 of 24 Old 01-31-2012, 06:23 PM
GXP20T
2010 JK Wrangler
I bought the PIAA horns mentioned in this write-up. Waiting to be installed.
http://tmar.net/piaa-sports-horns-40...stallation.htm
GXP20T is offline
post #11 of 24 Old 01-31-2012, 06:25 PM Thread Starter
BigBlue7
2010 JK Wrangler
So far my best option is between the piaa's and the wolo
BigBlue7 is offline
post #12 of 24 Old 01-31-2012, 09:09 PM
Vin
I also went with the Wolo. The only thing you may not like about it is that it is a high pitched horn. It requires no extra tanks, or compessors. You can use the metal bar that the stock horn is attached to, but I had an extra piece from an old radio install so I used that. You'll have to change to a 20 amp fuse. The OE 10 amp fuse will blow after a few toots of the horn.
Vin is offline
post #13 of 24 Old 01-31-2012, 09:23 PM
billypete
Yup I had to put a 15 amp fuse in also. its loud and the sound clip on the amazon site I posted is exactly what it sounds like for tone. Just fits the factory horn location, man they dont leave any extra room anywhere under the hood on the 12's.
post #14 of 24 Old 02-01-2012, 07:02 AM
Joevacs
2010 JK Wrangler
You might also consider Hella dual horns. They will plug right in to where the factory horn plugs in, and they are very load. I had them on a Jeep i used to have.
http://www.google.com/products/catal...ed=0CGAQ8wIwAQ
Joevacs is offline
post #15 of 24 Old 02-01-2012, 07:15 AM Thread Starter
BigBlue7
2010 JK Wrangler
I have considered all of these. I am trying to find the most aggressive sounding one. Thanks everyone.
BigBlue7 is offline
My horn is shot, shopping advice for a loud horn cj5mudman4x4 TJ Wrangler Technical Forum 7 07-28-2011 02:36 PM
Horn wont work, relay and fuse ok and horn works if direct wired Redskin TJ Wrangler Technical Forum 5 01-02-2010 04:24 PM
Hooking up aftermarket horn to '94 YJ. . .OEM horn wiring diagram??? atomicjoe23 YJ Wrangler Technical Forum 14 07-21-2009 06:39 PM
Anemic JK horn fixed! - Air Horn Install tturkstra JK Wrangler Technical Forum 11 10-03-2008 09:04 AM
Removed horn pad and the 3 screws underneath the horn pad - help Rocky529 YJ Wrangler Technical Forum 4 05-20-2006 05:48 PM
