Hooking up Delta Bumper Fog Light Upgrades - JeepForum.com
post #1 of 5 Old 09-27-2013, 07:41 PM Thread Starter
DeVo24
I posted last week about my fog light housings melting. I bought the Delta Xenon upgrade kit since I liked my headlight upgrades, it seemed like a safe bet. My problem now is the switch. I really don't want another switch until I start adding lights. I found some old posts that said I could wire up the harness and run my stock hot wire to the relay and continue using the factory switch instead of the delta switch. It sounds perfect in theory but all the posts were old so I was wondering if there was a problem found with doing this or it's just that much of a no brainer? I do it but I hate working on electric and usually keep it simple when I do. I'm putting them in tomorrow so any quick feedback is appreciated.
DeVo24 is offline
post #2 of 5 Old 09-27-2013, 10:53 PM
Filthy-Beast
No problem and is a good way to wire it. Power from the battery to the relay and then to the fogs. Negative from battery to fogs. Old hot wire to the fogs run to the control pin on the relay post 30 IIRC. solder the connections and use dielectric grease on all connections especially the fog harness
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #3 of 5 Old 09-28-2013, 09:05 AM Thread Starter
DeVo24
Thanks dude!
DeVo24 is offline
post #4 of 5 Old 09-28-2013, 02:42 PM Thread Starter
DeVo24
One more question for the sake of simplicity can I use the factory ground wires to ground the new lights? I'll use them if I can or take them out all together.
DeVo24 is offline
post #5 of 5 Old 09-28-2013, 02:48 PM
Filthy-Beast
It's better to run directly to battery.
For Sale:
