hood hold down - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > hood hold down
Want to be able to SEE? DOT Approved Headlights for under We have FLASHLIGHTS! Great for your Emergency bag!Flowmaster Overstock: Special Holiday Pricing!!!!
Unread 11-23-2014, 12:10 PM   #1
woof359
hood hold down
any one ever here of the rubber hood hold down failing ? driving on hiway 169 this morning with all the farm grain trucks driving in the opposite direction at warp sppeds and I be my hood lifting up at least 4 inches, I wonder who makes the best replacement hold down ?
woof359 is offline   Reply With Quote Quick reply to this message
Unread 11-23-2014, 12:50 PM   #2
Jiblet
I've never hear of one failing, plus the latch has a catch. But the sudden dance is common and can be disturbing.
There are several replacements available. Thriftier folks use zip ties around the rubber portion. Others claim good results from removing the spring by the latch.
Jiblet is offline   Reply With Quote Quick reply to this message
Unread 11-23-2014, 01:04 PM   #3
ncb
The safety catch will only allow the hood to bounce up two inches so I doubt it was bouncing four inches. I added a short piece of 1/2 inch square tubing under the radiator support and the hood is solid on windy days.
ncb is offline   Reply With Quote Quick reply to this message
Unread 11-23-2014, 01:15 PM   #4
jwmbishop
2011 JK Wrangler
I just mocked up the same - and it held my hood open about an inch at the seal- what is different that holds yours down - instead of up?
J Wm Bishop EA, ASADE
Alcohol - because great stories never run on gasoline...
jwmbishop is online now   Reply With Quote Quick reply to this message
Unread 11-23-2014, 01:25 PM   #5
ncb
Not sure. With the tubing in place the safety latch sits in its natural spot. It catches the latch if any up force is applied to the hood. Works perfect for a couple bucks of supplies.
Unread 11-23-2014, 02:03 PM   #6
LeighP
I've got the Rugged Ridge alloy catches on mine....easy to fit and adjust...very solid, no hood lift when trucks blow by.
Regards,
Leigh
2013 JK Overland/Sahara 3.6L
LeighP is online now   Reply With Quote Quick reply to this message
Unread 11-23-2014, 02:22 PM   #7
JIMBOX
I removed the spring and added a car trunk seal from left side to right side, under the leading edge of the hood, 4 years ago--
Hood no lifty-
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is online now   Reply With Quote Quick reply to this message
Unread 11-23-2014, 04:13 PM   #8
TxJeepGuy2
I removed the spring and it was fine for years with very little lifting. Then one rubber latch broke in a minor fender bender, I replaced it with the Daystar replacement hood latch, and not have not had a problem since.
Bryan . . JKU 2007 (First Production Year)
- Jeep Green - Sahara -
3" lift - 35" Fierce Attitude M/T Tires
TxJeepGuy2 is offline   Reply With Quote Quick reply to this message
Unread 11-23-2014, 05:09 PM   #9
Spoony1968
2014 JK Wrangler
Daystar has a replacement,cheap and works.
Spoony1968 is offline   Reply With Quote Quick reply to this message
Unread 11-23-2014, 10:21 PM   #10
onlyone
2014 JK Wrangler
I'm one of the cheap ones. Zip ties work great. Never any lift.
Thank you Jesus
2014 Wrangler Sport 1.5" spacers in front .75 rear, 1" BL 255/80/17 BFG KM2
onlyone is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 10:09 AM   #11
14Sport
2014 JK Wrangler
Well I gues I'm not as thrifty as others. I have the Rampage locking ones and they hold the hood tight. Zero flutter. As an added bonus no under hood tampering (city guy) allowed.
2014 JK Sport, auto, 35x12.5x17, 3.73s.
I jeep therefore I am.
14Sport is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 01:38 PM   #12
Bosun
Daystar replacement latches worke for me. Real tight a first. Then they break in and are nice and tight. Easy to change out.
"Never chose a life at sea-it holds you like a prison"
2012 2 door JK, Dozer yellow
1980 CJ5, Brown
1978 CJ5, Yellow
Bosun is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 03:57 PM   #13
LVCapo
The Voice of Reason
LVCapo's Avatar
I'd vote for Drake hood retainers. A little pricey, but outstanding quality.
LVCapo is online now   Reply With Quote Quick reply to this message
Unread 11-25-2014, 11:07 AM   #14
ASteve
ASteve's Avatar
1972 CJ5
Problem solved...for me...I'm not a Rugged Ridge fan but...these, to me, are the best looking and for RR seem to be somewhat of a quality product.
Hated when a Semi would pass in the opposite direction and make my hood flutter 4"...
http://www.astevecali.com
ASteve is offline   Reply With Quote Quick reply to this message
Unread 11-25-2014, 04:08 PM   #15
COLOUXJ
2010 JK Wrangler
Ill vote for the Daystar. Have them on and they are nice and tight. No hood Flutter at all.
"When i die, bury me with my jeep. Its never been in a hole it can't get out of"
Black Jeep Society
My JEEP helped win a War > Your Honda mows my grass!!
Mechanical Engineers Build weapons Civil Engineers build targets
Originally Posted by cyberpyrot View Post
is it a plink plink kerrrrdunk? or more of a brrrrrconk doc doc miiiidge pang!!!? or is it a badonk ka donk? if it is the latter its just the normal fat *** of the JK
COLOUXJ is offline   Reply With Quote Quick reply to this message
