Hood Flutter! - Page 2 - JeepForum.com
post #16 of 46 Old 08-15-2010, 08:50 AM
dvdsjk
dvdsjk's Avatar
I installed this Bushwacker hood protector to hide a big ding and some rock chips and it "accidently" removed my hood flutter and even helped a little bit with the bugs!
dvdsjk is offline
post #17 of 46 Old 08-15-2010, 08:55 AM
Mark4883
Just switch out your latches for a set of these and then try driving on the freeway for a few minutes. You will love your stock JK hinges.
Mark4883 is offline
post #18 of 46 Old 08-15-2010, 09:39 AM
krutj
2009 JK Wrangler
Originally Posted by limelight76 View Post
I have the Drake hold downs and LOVE them. However, they are a bit expensive. The cables have never once touched the paint or moved the slightest at highway speeds. Pics below. I think some people have taken some videos of them at highway speeds that also confirm this. You may want to do a search if you are interested.
Thanks, that's good to know. I really like the design
-- Joel --
krutj is offline
post #19 of 46 Old 08-15-2010, 09:39 AM
rirrgang
Daystars here as well. No more bounce.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #20 of 46 Old 08-15-2010, 09:50 AM
1222
RIP John
1222's Avatar
I donít have the Drake hold downs but I can tell you that the cables will not hit your Jeep. That was one of my concerns too and since Iím close to Drakes I was invited to take a look of them mounted on one of their Jeeps. There is absolutely no way the cables will hit.
(2011-2016)
1222 is offline
post #21 of 46 Old 08-15-2010, 11:24 AM
tclaremont
2014 JK Wrangler
Before you do anything, check with the dealer. I believe there was a recall for certain Wranglers that had to do with the hood hold downs. Do a search here on the forums and I am sure it will come up.
Tim C.
Rochester, NY
tclaremont is offline
post #22 of 46 Old 08-15-2010, 11:34 AM
tennistom1
2009 JK Wrangler
Read here that the the stock JK front-end is raked down and the aero-dynamics pushes the hood down. If you lift it and get rid of the rake you lose the wind-force pushing the hood down. Mine's a 2010 and can't say I've noticed the issue, maybe they fixed it on mine.
Out of curiosity, why do Jeeps use the two latches to secure the hood?
2009 JK Rubicon 4-Door
2006 TJ Rubicon Unlimited
tennistom1 is offline
post #23 of 46 Old 08-15-2010, 01:54 PM
TxJeepGuy2
Originally Posted by riverzendz View Post
Take the spring off of the hood. I did that two years ago after noticing the flutter and it never happened again. Took 5 minutes and it was free.
x2 on this suggestion. I would definitely try it first. I did it and have not had a problem since.
Bryan . . JKU 2007 (First Production Year)
- Jeep Green - Sahara -
3" lift - 35" Fierce Attitude M/T Tires
TxJeepGuy2 is offline
post #24 of 46 Old 08-15-2010, 02:03 PM
JeepScout3
2010 JK Wrangler
I had two (on the passenger side, both times) hold downs actually break on my TJ passing semi trucks on a two lane highway about 6 months apart. First time, thought it was a fluke, second time I went to war with Chrysler. They said they had never heard of them breaking. There is no recall and all Jeep will do if it happens is replace them. They refuse to put any locking ones on them, saying they weren't OEM. Let me tell you, at 70 mph when it snapped my hood buckled about 12-18 inches on the passenger side, scare the bejesus out of me and my passenger. Because Chrysler wouldn't do anything I bought the Hood Locks. First thing I did when I got my JK was put on Daystar Hood Wranglers, no flutter whatsoever.
2010 JK Sport, Dark Charcoal, 6-Speed, 3.73, 285/70R17
JeepScout3 is offline
post #25 of 46 Old 08-15-2010, 03:16 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Tie wrap.
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline
post #26 of 46 Old 08-15-2010, 10:23 PM Thread Starter
leojam73
Hey Guys,
Thanks for all the great suggestions. I have an 08 Unlimited with a 2.5" lift...so the hood flutter has been bugging me! The Daystars look promising. I'll post pictures with my solution....
Thanks Again
Joe
leojam73 is offline
post #27 of 46 Old 08-16-2010, 01:03 AM
tavic
2010 JK Wrangler
The Wranglers were originally designed to have the front lower than the back to improve fuel economy. Most lifts don't take this into account, so once it is sitting level the aerodynamics are off and the wind gets up underneath the hood.
So my recommendation is to use the hood flutter as a good excuse to put a winch on the front bumper to lower the front end slightly.
tavic is offline
post #28 of 46 Old 08-16-2010, 01:37 PM
tulsarob
Originally Posted by Thunderstrike View Post
Tie wrap.
I kept breakin the 1/8 wide tie straps so I put on 1/4 wide ties rated at 75 pounds.
Havn't broke them so far lol
2008 JK Silver Rubicon, 2 dr, 6 spd, pwr windows, tow package, slush mats, lockin gas cap, lug nut locks, shorty antenna, woven-wire grill guard, Cobra 75WXST, Wilson 3' Flex Antenna, Teraflex ant bracket, Highrock element doors, RR Grab Handles,RR Fire Ext Holder, RR bumper,Smittybilt 8k winch,Daystar 3/4 coil spacer on front, Kilby engine skid, Rockhard transfer case skid, Poision Spyder evap skid
tulsarob is offline
post #29 of 46 Old 08-16-2010, 03:11 PM
BAMAJK
2009 JK Wrangler
Definitely try taking the hood spring off first. I did this after I removed the POS air dam and I only have flutter in VERY strong winds. The best part is the cost: $0.
BLUE JEEP #237
BAMAJK is offline
post #30 of 46 Old 08-16-2010, 03:57 PM
aermotor
Use the replacement Daystar hood rubbers, fixes it right up.
aermotor is offline
hood flutter , hood latches , JK Wrangler , problem , solution , wrangler
Please Help with HID Flutter Not Flicker WickedcustomsTj TJ Wrangler Technical Forum 1 07-28-2010 08:25 AM
Does your hood "flutter"?? Elwood TJ Wrangler Technical Forum 35 07-12-2010 02:03 PM
flutter noise from underneath at speed drumkite2 TJ Wrangler Technical Forum 1 12-12-2009 04:04 PM
Flutter noise Under Load.. latham83 TJ Wrangler Technical Forum 6 01-29-2006 05:18 PM
engine flutter hguffman YJ Wrangler Technical Forum 1 09-14-2004 10:53 AM
