Hood Flutter! - JeepForum.com
post #1 of 46 Old 08-15-2010, 03:36 AM Thread Starter
leojam73
Hood Flutter!
Hi all,
The JK hood flutter on the highway is really starting to annoy me ! Has anyone addressed the issue and what have you used?
I've seen a few options, but I can't seem to make up my mind.
Thanks
Joe
leojam73 is offline
post #2 of 46 Old 08-15-2010, 03:44 AM
1222
RIP John
1222's Avatar
What you see is what you get. Daystar, zip ties, remove spring, AEV hood and Drake. I think thatís it. It bugs us all but we actually get used to it somewhat.
(2011-2016)
1222 is offline
post #3 of 46 Old 08-15-2010, 04:05 AM
TheDustMan
Huh... I've never noticed it except when crossing paths with a semi-truck. It used to be REALLY bad on my YJ, like, to the point where I thought the hold downs were going to break.
TheDustMan is offline
post #4 of 46 Old 08-15-2010, 05:12 AM
krutj
2009 JK Wrangler
Same here with the JK ^^
It has scared the heck outa me a few times.
That new Drake hold down looks good, but it has a small plastic coated cable that looks like it would rub the paint at highway speeds.
-- Joel --
krutj is offline
post #5 of 46 Old 08-15-2010, 06:11 AM
riverzendz
Take the spring off of the hood. I did that two years ago after noticing the flutter and it never happened again. Took 5 minutes and it was free.
Woods, www.jeepswag.com, has a nifty little fix as well. I think he sends it free with any purchase. Consists of some square steel and a zip tie. Works like a champ.
riverzendz is offline
post #6 of 46 Old 08-15-2010, 06:42 AM
Res6cue
2009 JK Wrangler
Doesn't bother me any more as long as I can see my hood latches are closed
Res6cue is offline
post #7 of 46 Old 08-15-2010, 07:02 AM
FC2TurboMSS
I put a skid row front skid plate on after i ripped the plastic POS off during a recovery. With Stock bumpers it is a bolt up mod and with a RR XRD modular it is just two new holes in the stubby. Since putting that on, I have had zero hood bounce, flutter, lift, etc. I think it was $58 and looks way better than the plastic as well as offers far more protection for the swaybar disco motor (if you have it). I have since put a 2" spacer lift on the front end with a 1" on the rear end and was wondering if nosing the rig up in the front would bring back my flutter but it has not. So spend a few pennies, look better, protect better, and get rid of the flutter.
"The World was large, now it is small. It was lonely, now it is crowded. It was dark, now the lights are on. Some day the old will be new again. Keep your guns close but your sword closer. For one day Man will again fear the dark of the World."
--The Zombie Prophet
FC2TurboMSS is offline
post #8 of 46 Old 08-15-2010, 07:21 AM
limelight76
I have the Drake hold downs and LOVE them. However, they are a bit expensive. The cables have never once touched the paint or moved the slightest at highway speeds. Pics below. I think some people have taken some videos of them at highway speeds that also confirm this. You may want to do a search if you are interested.
limelight76 is offline
post #9 of 46 Old 08-15-2010, 07:23 AM
Purdo
One of the threads on here mentioned that the rubber hold downs on the 2010 JKs are stronger. I believe this, as mine got hit in the fender/hood and when they replaced that hold down, I notice that only the other side flutters now. So, the simple answer appears to be, go to your Jeep parts department and order a set of new hold downs.
Purdo is offline
post #10 of 46 Old 08-15-2010, 08:15 AM
Dronac
Mine fluttered bad after a 3'' lift and removing the air dam. I reinforced the rubber with zip ties, and I may have to remove the hood spring as well.
2008 Jeep JK X: auto trans, 3.73 gears, D44 rear, D30 front
Mods: 2'' Rusty's coil lift, Superchips 93 octane tune, Cobra 75 CB radio, 33'' Duratrac's, onboard air compressor
My Build Thread! ---> http://www.jeepforum.com/forum/f96/dronacs-build-thread-1104134/
Dronac is offline
post #11 of 46 Old 08-15-2010, 08:16 AM
kik
X2. Have a 10 Rubi and no hood flutter.
kik is offline
post #12 of 46 Old 08-15-2010, 08:33 AM
JBravo41
2010 JK Wrangler
I've had two 2010's and both have hood flutter...
Bravo
JBravo41 is offline
post #13 of 46 Old 08-15-2010, 08:40 AM
hkenny90
just run some Velcro around the rubber to anchor it, worked great for me, and i already had the Velcro so no brainier
hkenny90 is offline
post #14 of 46 Old 08-15-2010, 08:41 AM
Voyame
I put a small hose clamp on the center latch. Adjusted it til it hooked with just a little push on the hood. It's a two step operation to open the hood but not a problem at all.
Voyame is offline
post #15 of 46 Old 08-15-2010, 08:45 AM
fernjack
I put the Daystar hood wranglers on ...... problem solved .....
07' Rubi Unlimited 6spd. , Rescue green #64 CDN , 35x12.5 mudders
Rick .
fernjack is offline
hood flutter , hood latches , JK Wrangler , problem , solution , wrangler
Please Help with HID Flutter Not Flicker WickedcustomsTj TJ Wrangler Technical Forum 1 07-28-2010 08:25 AM
Does your hood "flutter"?? Elwood TJ Wrangler Technical Forum 35 07-12-2010 02:03 PM
flutter noise from underneath at speed drumkite2 TJ Wrangler Technical Forum 1 12-12-2009 04:04 PM
Flutter noise Under Load.. latham83 TJ Wrangler Technical Forum 6 01-29-2006 05:18 PM
engine flutter hguffman YJ Wrangler Technical Forum 1 09-14-2004 10:53 AM
