Home made trunk cover for JK? - JeepForum.com
post #1 of 88 Old 07-21-2010, 05:57 AM Thread Starter
Neoxxis
Hey!
I see many home made "trunk covers" made out of 3/4 plywood and such.
Anyone has plans or measurements or pictures for an Unlimited JK?
I'm looking for just a top, that would go from the rear seat to the tailgate, side to side under the body lip... Or something.
Thanks!
07 Unlimited Rubi Rescue Green/Auto/pwr
Neoxxis is offline
post #2 of 88 Old 07-21-2010, 06:52 PM
ak67sd
I will be making one soon... i made a cardboard template, just have to get ambitious... i think i'm going to use 16ga aluminum that overlaps the side where the hardtop screws to so that i can use those holes/screws to hold it... it will work with either the hard or soft top... I was going to hinge it in the middle so that it will be easy to fold and stow in the back of the jeep if not required.
1/2" plywood and black carpet over...if anyone has pics of theirs and other ideas i'd like to see some too!
ak
08 Wrangler Unlimited
ak67sd is offline
post #3 of 88 Old 07-21-2010, 07:10 PM
monkers
2010 JK Wrangler
Ive got a 2010 2 door Rubicon and would like to see some pics of what you guys are talking about, its like a shelf? what does it rest on to form a trunk, the top of the tub? mine is a soft top if that makes a difference, thanks
monkers is offline
post #4 of 88 Old 07-21-2010, 08:31 PM
Treeslam
Maybe this will help:
After making a cardboard cutout, I cut out plywood. I actually used advantek engineered plywood.
Next, I coated the wood with contact cement and stapled some automotive carpet (Wal-Mart) tightly to the wood.
After cutting and covering a piece for between the rollbars and tailgate, I mounted a 36" piano hinge to allow for access without removing the entire cover.
Finally I put both pieces in place and finished connecting the two with the piano hinge.
If one of you lived close by, I would give you the one I made because I recently got rid of my JK.
94 YJ White (Sold 4/19/12)
07 JK Black (Sold 7/20/10)
09 Maxima(hers)
09 GMC(work truck)
Treeslam is offline
post #5 of 88 Old 07-21-2010, 09:38 PM
ls6tt
2010 JK Wrangler
nice mp 15-22, I have the same gun
ls6tt is offline
post #6 of 88 Old 07-21-2010, 10:34 PM
Treeslam
That is one of my favorite guns. It is accurate and ammo is cheap.
09 Maxima(hers)
09 GMC(work truck)
Treeslam is offline
post #7 of 88 Old 07-22-2010, 05:36 AM Thread Starter
Neoxxis
Very nice!!!
So you can lift the rear part while it's on?
Neoxxis is offline
post #8 of 88 Old 07-22-2010, 06:54 AM
Grant211
I really like this... Quick question... did you just lay it on the jk or is it "bolted" somehow to the jk?
2007 JK Unlimited Sahara
2.5" Teraflex Budget Boost, 1" MORE Body Lift, KC Slimlights, ProComp 7047 Wheels, 305x65x18 (34's) BFG AT KO's, Airraid CAI, Riddler Differential Covers, Headlight & Taillight guards, etc...
Grant211 is offline
post #9 of 88 Old 07-22-2010, 02:37 PM
jstrubberg
2009 JK Wrangler
Hoo boy! I can see many weekends building JK mods in the near future. This has to be one of them!
I think I will use two sections of piano hinge, though. I will run a second one down the center of the larger section so that if needed it can be removed, folded in half and laid flat in the cargo area for hauling oversize items.
Now I need to work out fasteners. I'd like something that doesn't require tools to remove and fastens underneath so that the lid can't be removed without opening the tailgate. Should make for semi secure storage when the soft top is down.
jstrubberg is offline
post #10 of 88 Old 07-22-2010, 11:22 PM
Treeslam
The cover does just lay in place. I thought of bolting it in if anyone tampered with it but never had a problem. I actually built it so I could have a place out of sight to put things. Anyway, I read your PM and will research a shipping method and get back with you.
09 Maxima(hers)
09 GMC(work truck)
Treeslam is offline
post #11 of 88 Old 07-22-2010, 11:24 PM
Treeslam
Originally Posted by Neoxxis View Post
Very nice!!!
Yes, with the piano hinge, you can actually hinge up the back piece for quick access.
09 Maxima(hers)
09 GMC(work truck)
Treeslam is offline
post #12 of 88 Old 07-25-2010, 04:27 PM Thread Starter
Neoxxis
Update time!
I started phase 1 today...
Inspired by the previous pics, I made the first part from seat to roll cage.
Contact glued carpet, holes to bolt the cover to the Hard top nut inserts...
So that's it for today.
Next part to be done next week.
[Note: I put temporary carpet stripes under the cover for now so that the glue and paint do not stick to the Jeep's body...]
10-4 and thanks for the inspiration.
Neoxxis is offline
post #13 of 88 Old 07-26-2010, 06:05 AM
monkers
2010 JK Wrangler
looks nice, where did you get the carpet from, and the fire ext that matches the color of your jeep, I have a 2010 Rubicon Rescue Green....nice work!
monkers is offline
post #14 of 88 Old 07-26-2010, 06:44 AM Thread Starter
Neoxxis
Carpet from Reno Depot...
Some kind of exterior carpet... Came in 6'x9'...
(I made a scratch/climbing "tree" for our new cat with this carpet 2 weeks ago and this stuff is fun to play with so I applied it to the Jeep! )
And standard white extinguisher painted with the Rescue Green rattle can from the dealer...
Neoxxis is offline
post #15 of 88 Old 07-26-2010, 08:18 AM
jstrubberg
2009 JK Wrangler
I was all set to work on one of these this week. After looking aroudn inside the tub and taking measurements, I've run into a snag. Are you guys doing this leaving a slot along the edge for the front hard top bow to fall into when you put the soft top down?
d.i.y. trunk cover , JK Wrangler , rear cover , trunk cover , wrangler
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Self made Insta-trunk? iceman123187 TJ Wrangler Technical Forum 21 05-18-2014 08:44 PM
Home made accessories for a factory made roof rack jeepgunner12 TJ Wrangler Technical Forum 0 11-11-2009 07:16 PM
home made insta trunk? hoot20 TJ Wrangler Technical Forum 12 10-23-2009 08:55 PM
anyone made a home made engine lift???? texas_yj YJ Wrangler Technical Forum 7 01-22-2009 05:54 PM
Home made front frame cover. surfsmeller YJ Wrangler Technical Forum 0 05-06-2004 08:33 PM
