Home built power distribution panel - Page 2 - JeepForum.com
post #16 of 24 Old 07-26-2010, 05:58 PM
fernjack
Originally Posted by Warlord2 View Post
^^^^ right on, if you ever change your mind amplifier fuses are water tight, super easy to wire in and can easily be found in the current you need. With that much protection I wouldnt think you will have a issue though
Thanks dude ! You should take up the cause and do that locker write up with pics ........ lots of us would love to have that for a reference .....
07' Rubi Unlimited 6spd. , Rescue green #64 CDN , 35x12.5 mudders
Rick .
fernjack is offline
post #17 of 24 Old 07-26-2010, 08:01 PM Thread Starter
MilitaryJK4455
2010 JK Wrangler
Ill second that
MilitaryJK4455 is offline
post #18 of 24 Old 07-27-2010, 12:57 PM
Neoxxis
Subscribed.
I did similar with 10 circuits but it's not that clean (relays standing alone around the battery and such... )
I need to re-do it now that I know what went wrong... (relays should be near the fuses, all wiring needs to be cleaned up, etc)
07 Unlimited Rubi Rescue Green/Auto/pwr
Neoxxis is offline
post #19 of 24 Old 11-21-2010, 09:35 PM
RMiksits
Pictures are gone
RMiksits is offline
post #20 of 24 Old 11-21-2010, 10:53 PM
Warlord2
Originally Posted by RMiksits View Post
Pictures are gone
donno where his went, heres mine Im working on
Auto Zone has the relay blocks, 6 terminals, each good for 30 amps.
The relays are from amazon, each for $0.77 cents good for 40 amps...whatever you do dont buy the relays from the auto shop chains, they charge WAY too much for them. Buy some extras as well, they dont like vibrations and go bad every once in a while.
GL
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #21 of 24 Old 11-21-2010, 11:37 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Wow the pic's are gone
I'll see if I can figure out what happened and how to get them back.
If others from the F.A.Q. are noticed missing please let me know
Jim
JLC08JK is offline
post #22 of 24 Old 11-22-2010, 12:44 AM
JLC08JK
JLC08JK's Avatar
I found a few and added them to post 1, I sent a PM to try and retrieve the others.
Jim
JLC08JK is offline
post #23 of 24 Old 01-09-2015, 04:39 PM
AirborneCav
I hate to revive an old thread, but is there wiring schematic for these? I love the layout but want to make sure I do it right (the first time). Its hard to see with just these pictures.
SILVER JEEP MEMBER #15
AirborneCav is offline
post #24 of 24 Old 01-10-2015, 11:07 AM
Double_DD-s
This is an alternative that I used. Came out really clean and all water resistant.
https://www.youtube.com/watch?v=OYMe2xTvyUQ
Parts list on the you tube link.
Double_DD-s is offline
diy , JK Wrangler , power distribution panel , relays , wiring , wiring for lights , wrangler
help with my 97 TJ Power Distribution Center firefly TJ Wrangler Technical Forum 2 11-06-2009 09:08 PM
WHere is the power distribution center? rocknroller89 YJ Wrangler Technical Forum 8 06-16-2009 10:15 PM
Power Distribution Center Ferrick YJ Wrangler Technical Forum 5 02-21-2008 02:15 PM
Need Ideas - Power distribution, fuses, and Switch Panel jtice TJ Wrangler Technical Forum 5 02-15-2008 01:00 PM
Power distribution fuse 19 '51plymouth TJ Wrangler Technical Forum 1 09-11-2007 05:36 AM
