Hmmm...thinking of putting 33" Tires on stock wheels. Have 1 question first? - JeepForum.com
post #1 of 9 Old 10-10-2011, 05:13 PM Thread Starter
USHotRod
2011 JK Wrangler
Not will it rub....but what is it rubbing?
I have a 2" AEV Spacer Lift. Does this satisfy the rubbing problem to put 287/70/17 Duratracs on? I see that the sticky says I should be good...but I've been told otherwise.
Thanks.
USHotRod is offline
post #2 of 9 Old 10-10-2011, 05:33 PM
OH9JK
2009 JK Wrangler
If you install a wider tire and don't compensate with either a different wheel or a wheel spacer to push the tire away then your tire could end up rubbing some of the suspension components.
The other type of rubbing occurs when your Jeep flexes its suspension without a lift and it typically rubs the fenders, bumper or body.
Clear as mud?
OH9JK is offline
post #3 of 9 Old 10-10-2011, 05:34 PM
Charles
2017 WK
We need something on the sticky along the lines of what he just said. It should also say: If it rubs the suspension a little, you'll need wheel spacers and if touches the fenders a little you'll need extra bump-stop or flat fenders.
2017 TrailHawk Hemi, Everything but the TV's.
Charles is offline
post #4 of 9 Old 10-10-2011, 06:41 PM
Caribic-TJ
x2
08 JKU Rubicon
98 TJ fully locked
Caribic-TJ is offline
post #5 of 9 Old 10-10-2011, 06:52 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Done!
Really, go look!
Jim
JLC08JK is offline
post #6 of 9 Old 10-10-2011, 08:27 PM
joeyc
2011 JK Wrangler
I'm running a 33x12x17 on a stock rubicon rim with a 1.5" leveling kit plenty of fender clearance and a 1.5" wheelspacer spidertrac no rubbing front or rear.. Let me tell you I had the tires on about 4 days without the wheel spacers and my front rubbed like **** on the sway bar link... once I got the spacers on sweet fine no problems even at full lock. Without the 1.5" lift it rubs the fender wells even on the slightest bumps... remove your rear splash guard and it gives a little bit more room.
2011 2dr Natural Green | 1.5" Teraflex Leveling Kit | Unlimited Springs | SkyJacker Hydro Shocks | 295/70/17 Trail Grapplers | 17" Rubi Rims Painted Carbon | 1.5" Spidertrax Spacer | Bed Lined Tub | RR Mirror Relocations | Manual Transmission | Soft Top | Gutter Guard Grill | Painted Grill | Smoked Turn Signals | Front and Rear diff Covers in Blue | Extended Breather Hoses | Customs Bumper
joeyc is offline
post #7 of 9 Old 10-10-2011, 09:22 PM
Vin
Don't forget about the front air dam
Vin is offline
post #8 of 9 Old 10-10-2011, 09:41 PM Thread Starter
USHotRod
2011 JK Wrangler
Oye...maybe I will just go with the new wheels then. Seems almost more of a hassle to use stock wheels. Although I do like the look of them.
USHotRod is offline
post #9 of 9 Old 10-10-2011, 10:26 PM
JLC08JK
JLC08JK's Avatar
Same amount of hassle whether you use the spacers or the proper backspaced wheels. If you like the stock wheels just get the spacers and you're good to go!
Jim
JLC08JK is offline
Question about putting 33" tires on my 1997 Wrangler TJ SE xalexxromerox TJ Wrangler Technical Forum 18 11-29-2014 09:05 PM
How much lift for 35" tires, stock 17"wheels, pocket flares? kirk81 JK Wrangler Technical Forum 12 09-02-2011 07:37 PM
Thinking of putting 33" tires on my JK, biggest size? nobusinessdone JK Wrangler Technical Forum 45 11-16-2010 02:52 PM
Burly looking 33" tires for stock 18" Sahara wheels ChuKronos JK Wrangler Technical Forum 27 02-13-2008 05:57 PM
Need pics of new "RAVINE" wheels w/anything but stock tires thejafe TJ Wrangler Technical Forum 9 01-07-2004 07:32 AM
