Hinges, hinges everywhere, and not-a-one with paint! - Page 2 - JeepForum.com
post #16 of 28 Old 02-22-2012, 08:57 AM Thread Starter
Gomofast
Gomofast's Avatar
Originally Posted by cruisemissle View Post
... the hinges are alloy of some kind. The problem with the paint is likely to be from the alloy itself, as impurities will work their way out of it with heat cycling...
I think you're on to something there. It may be a combination of factors, but I've never had a problem like this with any of the steel hinges on my past Jeeps.
It's just unfortunate. I've spent countless hours modding and maintaining my past jeeps, but with a baby at home now, I just don't have the time for something that requires so much intervention. That's why I was looking at a newer 4-door Jeep (not to mention that I need the extra room now too). I was hoping to have something that I could just drive without having to do silly maintenance like sanding/painting the hinges after just a couple of years!
08 JK Unlimited X, 2" Black Diamond lift, 33's, 1.5" wheel spacers, stubby bumper mod.
98 TJ Sport, 4" Rough Country Lift, homemade discos,
35" BFG Mud Terrain T/A KM's, 4.56 gears, Detroit Truetrac
up front, factory Trac-Lok out back,Warn M8274 8000lb
winch, York OBA, rock guards, custom intake, 48" HI Lift.
Gomofast is offline
post #17 of 28 Old 02-22-2012, 09:06 AM
MrSmiley
Originally Posted by Gomofast
Why is it that nearly every single JK I'm looking at (mostly 07s and 08s), have the paint bubbling/peeling off the door hinges?
Seriously, almost every one I've seen. I'm looking to buy a used 4-door, but I don't want one with corroded door hinges after only a few years. What's the deal?
Because the body and hinges are made of two different types of metal.. and they react over time causing what you are describing
Certified Web Wheeler
MrSmiley is offline
post #18 of 28 Old 02-22-2012, 09:21 AM Thread Starter
Gomofast
Gomofast's Avatar
Yeah, that seems to be what we're finding out here. I think the alloy in the hinges starts to corrode quickly (perhaps even quicker when pelted by road debris), causing the paint to bubble and peel off of them. I wonder if Jeep has a solution.
Gomofast is offline
post #19 of 28 Old 02-22-2012, 09:24 AM
LIJeepJC
Originally Posted by Gomofast View Post
Well, you live in Nevada, and I live in New York. I'm sure the climate has something to do with it.
Anybody else in the northeast notice this? I mean, I'm talking literally about 19 out of 20 JKs that I've looked at have had this problem. I'm wondering if Jeep would repaint the hinges under warranty perhaps (if the factory warranty hasn't expired)?
Hey guys, newbie here. I have this problem on my 09 JK. I'm out in LI NY.
LIJeepJC is offline
post #20 of 28 Old 02-22-2012, 09:25 AM
LIJeepJC
Anybody know what the warranty is for the rust and corrosion coverage? Isn't it 7 years, 100k?
LIJeepJC is offline
post #21 of 28 Old 02-22-2012, 09:26 AM
JKatfish
Any pictures? I've heard that there is no paint between the hinge and doors and body.
JKatfish is offline
post #22 of 28 Old 02-22-2012, 09:33 AM Thread Starter
Gomofast
Gomofast's Avatar
Forgive me for posting this link to another forum, but I found this link with some pics and info about repairs under warranty...
http://www.jkowners.com/forum/showthread.php?p=1073323
Gomofast is offline
post #23 of 28 Old 02-22-2012, 09:34 AM
MrSmiley
I highly doubt they have a solution.. or even want to acknowledge it sadly :/ but I gave heard you can get them replaced even if your warrenty is out
MrSmiley is offline
post #24 of 28 Old 02-22-2012, 09:40 AM
mikeinminn
This is a constant problem up here in Minnesota. It is also a problem for older TJs that have aluminum mirror mounts and rear door hinges. Thing is, the rocks are thrown up at an angle. The longer the vehicle, the more exposure the hinges that are low or in back have. The part of the hinge that is attached to the body is steel. The part that is attached to the door is aluminum. Still, even if it wasn't for the rocks, corrosion still seems to attack the aluminum as others have said.
You can get those little plastic caps to go over your hinges. But if I had it to do over, I would get that clear plastic they use on the clear bras and fenders sometimes and apply it to the leading edge of the hinges.
mikeinminn is offline
post #25 of 28 Old 02-22-2012, 09:50 AM
BLK2000TJ
I think it's 5 years 100,00 miles.. My dealership repainted the hinges on my '08 last spring under warranty (75,000 miles). They acted like they were doing me a favor.
2010 JKU Rubicon 3.5" AEV , AEV Pintlers 35" KM2's , AEV Bumpers, AEV Hood / Snorkel
2008 JKU (Daily Driver)
2000 TJ Auto 4.5 RE Superflex ,35" MTZ 's , Warn ,Viking, LoD, RockHard,AEV, JKS, ARB's, Vanco Big Brake Kit ,Currie etc. etc.etc.
BLK2000TJ is offline
post #26 of 28 Old 02-22-2012, 10:16 AM
WillysEdition04
Is this warranty transferable to secondary owners?
04 TJ Willys Edition 41MB-04TJ ...SOLD
08 JK Unlimited
WillysEdition04 is offline
post #27 of 28 Old 02-22-2012, 10:23 AM
LIJeepJC
Yeah, thanks. Dealers have a knack of acting like that...
LIJeepJC is offline
post #28 of 28 Old 02-22-2012, 10:28 AM
tturkstra
This is a very common problem in Canada, whether you wheel a lot or not. I've had mine resprayed 3 times under the warranty (pretty much yearly). Since the last respray 2 years ago, the rust never came back but my right rear door is really hard to open. I'm planning to go stainless when this happens again, if I can find some black stainless hinges, but it's not cheap.
The problem is the dissimilar metals in the hinge allowing an electolytic reaction.
08 JK unlimited Yellow
"When all is said and done, it seems a lot more gets said than done."
tturkstra is offline
door , door hinge , hinges , paint
2002 TJ Hard Top Hinges - Dealer says hinges don't fit!!! lexukc TJ Wrangler Technical Forum 6 01-19-2012 04:45 PM
Paint Bubbling on Hinges AJ in Japan JK Wrangler Technical Forum 10 10-08-2009 07:31 PM
Cosmetic fixes? door hinges rusty and hard top window hinges peeled............... hangwire TJ Wrangler Technical Forum 8 08-25-2009 02:39 PM
Hex bolts for windshield hinges? How do I seal the hinges? ZeroGravity YJ Wrangler Technical Forum 4 05-20-2009 09:34 PM
paint issues with aftermarket hinges? COBY TJ Wrangler Technical Forum 5 07-18-2008 11:52 PM
