Hinges, hinges everywhere, and not-a-one with paint! - JeepForum.com
post #1 of 28 Old 02-22-2012, 08:34 AM Thread Starter
Gomofast
Gomofast's Avatar
Why is it that nearly every single JK I'm looking at (mostly 07s and 08s), have the paint bubbling/peeling off the door hinges?
Seriously, almost every one I've seen. I'm looking to buy a used 4-door, but I don't want one with corroded door hinges after only a few years. What's the deal?
08 JK Unlimited X, 2" Black Diamond lift, 33's, 1.5" wheel spacers, stubby bumper mod.
98 TJ Sport, 4" Rough Country Lift, homemade discos,
35" BFG Mud Terrain T/A KM's, 4.56 gears, Detroit Truetrac
up front, factory Trac-Lok out back,Warn M8274 8000lb
winch, York OBA, rock guards, custom intake, 48" HI Lift.
Gomofast is offline
post #2 of 28 Old 02-22-2012, 08:38 AM
1222
RIP John
1222's Avatar
Itís just the opposite for me; all the hinges Iíve seen were just fine.
1222 is offline
post #3 of 28 Old 02-22-2012, 08:45 AM Thread Starter
Gomofast
Gomofast's Avatar
Well, you live in Nevada, and I live in New York. I'm sure the climate has something to do with it.
Anybody else in the northeast notice this? I mean, I'm talking literally about 19 out of 20 JKs that I've looked at have had this problem. I'm wondering if Jeep would repaint the hinges under warranty perhaps (if the factory warranty hasn't expired)?
Gomofast is offline
post #4 of 28 Old 02-22-2012, 08:48 AM
goldenglory18
This is a common problem with jeeps in some areas. Especially jeeps with cut/modified fenders. Lots of debris gets kicked up while off road and the hinges/door handles are the only thing to get in the way.
I wouldn't be too concerned with it so long as there isn't any additional damage anywhere else on the vehicle. I would just pull them off, strip them, and repaint/bedline.
Gone and I dont miss it at all - 2011 JKU
goldenglory18 is offline
post #5 of 28 Old 02-22-2012, 08:59 AM
J33PNSL33P
I don't live in the northeast but I live in the north. And up here I had the same problem. Took a while to find a jk without rust on the hinges, and on the brackets around the windshield. Finally found a garage kept 07 that looked good. So I bought it
J33PNSL33P is offline
post #6 of 28 Old 02-22-2012, 09:05 AM Thread Starter
Gomofast
Gomofast's Avatar
yeah I could understand that on a jeep that sees a lot of offroad use, but all the ones that I'm looking at are stock, un-modded jeeps that have probably never even seen the dirt
Gomofast is offline
post #7 of 28 Old 02-22-2012, 09:07 AM Thread Starter
Gomofast
Gomofast's Avatar
I guess I'm just rather disappointed. I didn't expect that new jeeps would be having serious paint issues in just a few short years.
Gomofast is offline
post #8 of 28 Old 02-22-2012, 09:11 AM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
My '08 is fine, I live in Boston. It is a very low mile '08...
Will be stripping, bedlining them anyway.
Need parts? Need product advice? Contact Jason at
ArticRubi is offline
post #9 of 28 Old 02-22-2012, 09:19 AM
PhatJK
2009 JK Wrangler
Even for un-mod Jeep, the front tires kick up dirt, mud, rocks and small pebbles and the front of the hinges collect all of them. They have the effects of chipping the paint off the hinges overtime. You can paint it over but it's not something I worry about.
09 Unlimited Rubicon
Teraflex 2.5" spring lift kit
ORFAB tire carrier
PhatJK is offline
post #10 of 28 Old 02-22-2012, 09:29 AM Thread Starter
Gomofast
Gomofast's Avatar
Yeah, I get that, but my 98 TJ (that has seen a ton of offroad use, and never been waxed the whole time I've owned it) is just now starting to have a bit of rust on the hinges.
Whereas the JKs I'm looking at are having the paint bubbling off the hinges completely, after only a few years.
I don't think the kicked-up debris is the only issue here.
Gomofast is offline
post #11 of 28 Old 02-22-2012, 09:31 AM
robplumm
Was going to say...sounds like an excuse to toss bedliner on them
robplumm is offline
post #12 of 28 Old 02-22-2012, 09:32 AM
ncb
I haven't had any rust on the hinges so I haven't had to disassemble them for paint. Do the the hinges and pins have any paint on the inside, or are they bare metal? I always assumed the corrosion was due to moisture and road salt living in the hinges.
ncb is offline
post #13 of 28 Old 02-22-2012, 09:34 AM
Vin
I think it has to do with the dealer painting the doors with the hinges on, thereby leaving one side unpainted, but I'm happy to report that my OE full doors show no such bubbling and my half door hinges were painted separately.
Vin is offline
post #14 of 28 Old 02-22-2012, 09:40 AM
WillysEdition04
I just noticed some bubbling on my OE full doors yesterday. It wasn't this bad on my '04.
Time to call my body/paint guy...
04 TJ Willys Edition 41MB-04TJ ...SOLD
08 JK Unlimited
WillysEdition04 is offline
post #15 of 28 Old 02-22-2012, 09:47 AM
cruisemissle
I just dropped a set of half doors and hinges off to get painted.
While I had them I noticed the hinges are alloy of some kind. The problem with the paint is likely to be from the alloy itself, as impurities will work their way out of it with heat cycling.
Well, that's what I think anyhow.....
Now on a related note...
Chrysler needs to put some paint on these Jeeps! There are several places on our '12 where you can see the primer! Paints job is to protect metal from corrosion, can't do it if it's not there.
cruisemissle is offline
door , door hinge , hinges , paint
2002 TJ Hard Top Hinges - Dealer says hinges don't fit!!! lexukc TJ Wrangler Technical Forum 6 01-19-2012 05:45 PM
Paint Bubbling on Hinges AJ in Japan JK Wrangler Technical Forum 10 10-08-2009 08:31 PM
Cosmetic fixes? door hinges rusty and hard top window hinges peeled............... hangwire TJ Wrangler Technical Forum 8 08-25-2009 03:39 PM
Hex bolts for windshield hinges? How do I seal the hinges? ZeroGravity YJ Wrangler Technical Forum 4 05-20-2009 10:34 PM
paint issues with aftermarket hinges? COBY TJ Wrangler Technical Forum 5 07-19-2008 12:52 AM
