#1 | |
Hinge Rust
I did some searching but didn't find much related to this topic. I'm experiencing some rust on my door hinge. During the summer months, when I had the doors off, I soaked the bolts in WD40 for a couple days and cleaned things up pretty well. But, I've got some rust showing up on the hinge.
Any idea what I should do to fix/stop this? Would touch-up paint fix the problem or just be a band-aide? I also have a nice chip in the kickguard area. Which I'm considering using touch-up paint then getting the sill guards.
07 JK 4 Door X, Jeep Green, Fog Lights, Tow Hooks |
#2 |
Since you live in NY I would expect that's not the only spot you have rust. The best way to slow it down is to clean it up after you drive in the snow underside and the body.
-Ross 1998 Subaru Forester DD 2002 TJ Sport 4.0 HO (Has some goodies) Weekend play toy 1987 Coleman Columbia 3/4 ton+ tow rig wanted! |
#3 |
Saturate them in lithium grease, work it in real good then wipe off the excess,
Repeat yearly. |
#4 |
Thanks! What exactly is lithium grease though? Is that something that I can get at an auto parts store?
thanks.
#5 |
Yah, it's same a wheel bering grease except it's white and keeps it's viscosity better in more extreem tempertur variations.
#6 |
After getting a few good chips in mine I thought about getting them rhino lined. I think it would look good and be almost indestructible.
#7 |
#8 |
Wow, those are some tiny pics.
But, from what I can see, mine look like that too. |
#9 | |
That is incorrect, just about any can of Lithium Grease will state that it is not for high temperature applications. However, it works great for the moving parts of doors, hinges and window regulators.
JF'er with a Theme Song Member #1 http://www.youtube.com/watch?v=MNzZzsvOClc His: 2009 Dodge Charger R/T- MOPAR CAI, vinyls by RiderGraphix, tinted windows, red painted calipers. 1986 Trans Am- Rebuild underway. Hers: 2003 Grand Cherokee Laredo-4.7 V-8, Leather, Power Everything, Factory Tow and Recovery Points, KOR 2.5" BB, RE Monotube Shocks, Maxxis Bighorns, Kolak 3" Exhaust. Gone, But Not Forgotten: 1994 Wrangler YJ- Too many mods, not enough money! |
#10 |
so you know those hinges are made out of aluminum.
if you use some cleaner wax/compound on them im sure itll come off the painted surfaces
3.5" Lift, 35" tires, 5.13's, bumper, scratches, dents, stories |
#11 |
I also have rust on my hinges, as well as on the metal parts of the front seats. Am I correct in assuming that a bit of surface rust is normal, especially near the ocean?
#12 | |
I wasn't specific but was implying for the cold, wheel bearing greese seems to gel up and work it's way out faster come -20 celecius, which the wife may not like to much if she were to lean up against it. |
#13 |
Take your rusty hinged (actually pins) vehicle back to the dealer for replacement hinges, A change notification has been implemented months ago to address this engineering defect.
#14 | |
#15 |
Yes, if you have the number, let me know as I bring mine in for service this week and am also experiencing rust on the hinges. Less than 1 year old. Too soon IMHO.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
