High beam signal side wire color - JeepForum.com
post #1 of 2 Old 07-14-2013, 10:10 PM Thread Starter
DustinS
2011 JK Wrangler
I'm hooking up a set of lights to double up on my high beams. I have all the wiring hooked up to the relay except the signal side.
I'm curious if there's a place on the JK where I can hook up the signal wire, or if I should just tie it in to the high beam?
Thanks,
2011 Wrangler Rubicon, Zone 3" lift, 3/4" spacers, SRC Front and Rear bumpers, Bushwacker flares.
DustinS is offline
post #2 of 2 Old 07-16-2013, 05:37 AM
MrZ71
1987 YJ Wrangler
i think the mopar kit pulls the signal from the high beam to power the switch to power on the lights
step 38 seems to reference what you are looking for
http://www.quadratec.com/Assets/Installation/75754.pdf
If you look at the DIY up top there is a fuse under the hood you could use to power a switch that way you do not have to have the high beams on to run the AUX lights
http://www.jeepforum.com/forum/f96/e...ource-1253810/
I used the under hood switched power to power my switches to fire up relays for my lights and OBA have the Rugged Ridge A pillar switch panel but take time so it does not turn into a mess of wires going all over
/l , [____], '87 YJ 4.2 Auto Howell EFI
l---L--[]lllllll[]- lifted and locked on 35's
()_) ()_)--o--)_) Super 30 and 44, 4.88's
l____l 09 JKU Sahara Rock Krawler 2.5
(OlllllllO) Ripp supercharger 35x12.5's 5.13's
[]--O--[] magnaflow D.I.Y. exhaust -James-
MrZ71 is offline
