hi lift jacking pts - JeepForum.com
post #1 of 9 Old 06-04-2010, 10:50 AM Thread Starter
gsaxe
hi lift jacking pts
go on flame me for being a dangerous newb but my j10 came with a "bumper" jack, the bumpers has slots for it to fit into and the whole body was strong enough to jack directly from even the wheel wells not so the jk, where do you guys jack from, i'll start:
wheel thingy
rock rails
anyone use d rings?
will the curved bumper accessory work on a stock bumper (hi lift site says it works on plastic bumpers
dang vendors who don't answer phones, yea you hi lift....
AKA Catfish
gsaxe is offline
post #2 of 9 Old 06-04-2010, 11:45 AM
owtdorz
2009 JK Wrangler
I jack mine on the rock rails and even did it once on my d-rings on my front bumper.
'09 Detonator Yellow 4dr Rubi, Bestop Element doors, Rugged Ridge XHD w/stinger, Warn 9.5ti, 3.5 Rock Krawler, Woods driveshafts, Hella 500 aux lights, 35x12.5x17 BFG KM2<< THEY SUCK
owtdorz is offline
post #3 of 9 Old 06-04-2010, 12:53 PM
DeepSky
On a stock JK the only real place to jack using a hi-lift would be the rock rails, provided your Jeep even came with them. You would wind up mangling the stock plastic front and rear bumpers if you tried jacking from them. I'm not sure about that 'curved bumper' accessory though, sorry.
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #4 of 9 Old 06-04-2010, 12:56 PM Thread Starter
gsaxe
correction curved bumper thingy only for steel.....
AKA Catfish
gsaxe is offline
post #5 of 9 Old 06-04-2010, 12:58 PM
DeepSky
Definitely one of the drawbacks about all the plastic on the JK's.
DeepSky is offline
post #6 of 9 Old 06-04-2010, 01:03 PM
JIMBOX
The stock JK has two HiLift spots on the front-stock- bumper and two on the rear stock bumper
The stock "Rock Rails" are too close to the body for HiLift use
After mkt bumpers and "Sliders" are the best bet
The stock jack should be placed under lower control arm brackets for individual tire use, or lower shock mount !!
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #7 of 9 Old 06-04-2010, 01:18 PM Thread Starter
gsaxe
jimbo I see bolt holes(?) on the metal box bar under the rear and thought about that, can you be more specific about he stock pts front and rear. Obviously near the fame on front but I don't see it. thanks also for the info on the scissor jack I thought the top looked worng for direct placement on the axle as it lacks a cradle! Guess I should read my manual.
AKA Catfish
gsaxe is offline
post #8 of 9 Old 06-04-2010, 01:23 PM
DeepSky
That's the first I've heard about those. When I had my stock bumpers I didn't even bother trying to use the HiLift on them, primarily because they looked too flimsy to jack from without damaging and also most people on the forums didn't recommend it.
DeepSky is offline
post #9 of 9 Old 06-04-2010, 01:30 PM
JIMBOX
A good idea is to always carry a short (6/8" piece of old scrap (??) 4x4 wood to use as a spacer on the bumpers, from the jack to where the frame ends at the bumper or just to put on top the stock jack, to help eliminate slipping
The lower control arm (LCA)brackets and the lower shock mounting brackets are strong enough for single point use, you never want to put a jack-DIRECTLY-on either axle tube, they are pretty strong, but you never know !!
If you have stock rock rails, then the sissor jack will work on either end-using the 4x4 piece as a spacer--as long as your JK isn't lifted, but still better under the LCA !!
Good luck
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
Jacking question... superslayer TJ Wrangler Technical Forum 7 07-19-2009 06:39 PM
Jacking points for Installing Body Lift JeepsOLot YJ Wrangler Technical Forum 6 06-23-2008 09:35 PM
Jacking vehicle FritzTJ TJ Wrangler Technical Forum 5 11-07-2007 08:28 AM
jacking up jeep for coil lift - where? corey81 TJ Wrangler Technical Forum 1 07-04-2006 06:48 PM
Hi Lift Jacking Points mjeselskis YJ Wrangler Technical Forum 4 09-26-2005 02:33 PM
