Hhheelllppp a/c question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Hhheelllppp a/c question
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits End of Summer Sale, 20% OFF!ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 05-07-2014, 05:17 PM   #1
techbomb
Ok I thought i would go by the book and ad a little r134 refrigerant to my 08 sahara, I read the directions and added a little checked the guage and kept going back in fourth till i was in the green where I was supposed to be , then the compressor showed in red all of a sudden , then my compressor started going on and off on and off. Started blowing hot air , what the heck , ok so I then took it down the road and it mad a hissing noise real quick and I looked under the jeep and it blew some of the r134 underneath the car , almost like a pressure relief valve. It is now blowing cold air and so far I havnt seen anymore r134 come out, is it ok to run it , and is that in deed a pressure relief valve underneath the compressor ? Is this normal , what do I do ?
techbomb is offline   Reply With Quote
Unread 05-07-2014, 05:28 PM   #2
jwmbishop
2011 JK Wrangler
You probably overcharged it. HAVE to make SURE the compressor is actually running (the center hub is engaged and spinning) before you add the juice and green line it. If the compressor is NOT in cycle when you add - the pressure goes higher (into the red) when the system does call the compressor.
I am not aware of a relief valve in any system - just a high limit switch that will cycle the compressor just as you described. You may have blown out a service valve, the limit switch or other component. Have it recharged by someone with a two guage system.
J Wm Bishop EA, ASADE
How to start an online argument - express opinion - wait.
jwmbishop is offline   Reply With Quote
Unread 05-07-2014, 05:46 PM   #3
techbomb
Guess thats what I get for trying to do something myself errrrr, . The weird thing is that the pressure is correct now and is blowing cold air so I wonder if I should just drive it for a bit and watch it or just bite the bullet and go to a dealer ?
Unread 05-07-2014, 05:47 PM   #4
techbomb
If I blew out a service valve or something wouldn't it be running refrigerant out at all times ?
Unread 05-07-2014, 06:14 PM   #5
techbomb
Well I got a little close with the flashlight on the bottom of the compressor , it defiantly looks like a pressure relief valve, I think Im still gonna take it to have it looked at just to be safe thou.
Unread 05-08-2014, 08:20 AM   #6
jwmbishop
2011 JK Wrangler
Its a schrader valve - almost exact match design wise for a tire valve core. They CAN reseat.
My buddy told me he sees it a lot. He is in business so must capture the refrigerant - but the fix is to bleed some off. Just pay attention to what the pressure should be for your ambient air temp at time of service. The warmer the day - the higher the pressure.
If its working now - run it.
