Help! Submerged, Can I start it? - Page 2 - JeepForum.com
post #16 of 23 Old 04-16-2013, 03:44 PM
SubAtomicGenius
2011 JK Wrangler
Originally Posted by Monstrousmac View Post
Simple,
1) Pull out Spark Plugs
2) Crank the Motor over a few times, this will flush out any water in the cylinders.
3) Spray some starter fluid down the spark plug holes into the cylinders
4) Dry off the spark Plugs
5)Put spark plugs back and and start her up
6) Change all your fluids, Oil, transfer Case, Transmission, Diff
Good to go!
I completely submerged my vehicle and Hydro locked it, Did the above and she is still running like a champ. Granted, anytime you hydrolock a motor, there is some potential for engine damage because water does not compress.
Hope this helps
Looks like you should have either waited for the snow speeders or the imperial walkers to help you out in these pics.
SubAtomicGenius is offline
post #17 of 23 Old 04-17-2013, 10:44 PM
222Doc
222Doc's Avatar
so what ever happened to this guy? I would like to have seen pics of this. Bet he tries to give it to the dealer. Ya i left in water over night....
222Doc is offline
post #18 of 23 Old 04-18-2013, 01:22 AM
Monstrousmac
1974 CJ5
They did not run as well as a Jeep in the cold.
Jeeps I own
1974 CJ-5 w/ 6 inch lift w/ 33's
1996 ZJ W/ 6 inch lift w/ 33's
2010 Jeep Islander
Monstrousmac is offline
post #19 of 23 Old 06-01-2013, 02:15 PM Thread Starter
FreedomJKU
Thanks for all the help guys. I eventually got it out and started it up fine. I included a picture in the same mud hole from before I got it stuck really bad. I threw in a picture of my buddy getting his TJ stuck in the same hole, driving in the opposite direction as well. He got out from my buddy's JK and some tow straps.
FreedomJKU is offline
post #20 of 23 Old 06-01-2013, 08:48 PM
Washi
Rockbiter
Washi's Avatar
2009 JK Wrangler
^ Glad to see that you and your Jeep made it out. Having to leave a rig to get more assistance can be difficult. That being said, you guys might have better luck with this little mud pit if you were using mud terrain tires?
Originally Posted by 00JGC00 View Post
Meh. Jake's is longer. I've seen it...
__________________________________________________ __________________________________________________ _______________________________________
/l ,[_____],
l----L-OlllllllO-
()_) ()_)-o-)_)
Washi is offline
post #21 of 23 Old 06-01-2013, 11:28 PM
ThatWhiteJeep
Winch.
Like my GrandPappy said, only way to learn is to do it yourself. Even if you break some things along the way.
ThatWhiteJeep is offline
post #22 of 23 Old 06-02-2013, 01:21 PM
Monstrousmac
1974 CJ5
Heck that was just a puddle, and yes jeeps are better than snow speeders. The thing that was bad about that day was the weekend before my snorkel came in the mail, but I was too lazy to put it on. That will teach me for being lazy, the jeep gods where mad at me along with my wife.
Jeeps I own
2010 Jeep Islander
post #23 of 23 Old 06-03-2013, 07:08 PM Thread Starter
FreedomJKU
Honestly it looks like a wimpy puddle but the ruts I got stuck in were made by 44s. Only sportimg 32s with no lift, bottoming out the way I did was inevitable. That hole was in Charleston, SC but I'm moved to upstate NY now and I'm enjoying the trailriding scene up here much better.
