Help! Submerged, Can I start it? - JeepForum.com
post #1 of 23 Old 04-14-2013, 10:58 PM Thread Starter
FreedomJKU
Hey, my JKU is partially submerged, up to the bottom of rocker rails. Unfortunately I've bottomed out with no traction on any of my tires and multiple towing attempts with a TJ and another JK failed, and with the heavy duty tow drivers home for the night, I had to turn her off and leave her for the night.
I was hoping to keep her running and keep water out of the tailpipe, but what's done is done. Will be sitting around 12 hours partially submerged before I can get a proper tow. Can I start it after getting pulled from the hole? What do I need to do before and after starting to prevent serious damage? I've reads little about hydro locking and broken rods but I don't really know too much about engines or if I need to worry about that. Found a dark red hue coming from my jeep into the water near front passenger side by the bumper, and a general rainbow tone on passenger side of jeep coming from jeep, not sure which fluids these are, but assume I'll need to flush and refill most of my fluids. What's necessary and what isn't to avoid spending more money than I need to, (by fixing things that are fine, or breaking something further)? Any other important information anyone can provide would be much appreciated. I'm a first time Jeep owner and I don't want this experience to hurt my modification budget too much is minuscule to begin with. Thanks.
FreedomJKU is offline
post #2 of 23 Old 04-14-2013, 11:10 PM
MeatCurtains
I've never sunk one and left it. I would imagine there is a possibility of sucking water in from the exhaust, but its probably minimal.
The oil you see from your jeep could be several things and personally I'd have to look to see what it could be because off of the top of my head a few things come to mind.
As far as changing fluids I would hit up the diffs and anything in the water. Oil wouldn't hurt but it doesn't sound like you are in deep enough to get water in there or the tranny, but again it wouldn't hurt.
MeatCurtains is offline
post #3 of 23 Old 04-15-2013, 01:55 AM
Monstrousmac
1974 CJ5
Simple,
1) Pull out Spark Plugs
2) Crank the Motor over a few times, this will flush out any water in the cylinders.
3) Spray some starter fluid down the spark plug holes into the cylinders
4) Dry off the spark Plugs
5)Put spark plugs back and and start her up
6) Change all your fluids, Oil, transfer Case, Transmission, Diff
Good to go!
I completely submerged my vehicle and Hydro locked it, Did the above and she is still running like a champ. Granted, anytime you hydrolock a motor, there is some potential for engine damage because water does not compress.
Hope this helps
Jeeps I own
1974 CJ-5 w/ 6 inch lift w/ 33's
1996 ZJ W/ 6 inch lift w/ 33's
2010 Jeep Islander
Monstrousmac is offline
post #4 of 23 Old 04-15-2013, 05:20 AM
rha600
What in the world were you thinking there? haha.
OP,
If you are only up to the rock rails what makes you think it got water in the engine? the intake is much higher than that, and you're not going to suck water up the exhaust. Only time the exhaust values are open there is exhaust coming out. Not to mention, as with the intake, the exhaust values are higher than the rails.
I would do what MeatCurtains said though. Can't hurt to spend the $$ on changing the fluids.
rha600 is offline
post #5 of 23 Old 04-15-2013, 05:34 AM
Mello03
Totally agree with rha600. That oil you see in the water could just be some residual coming off your rig. I would change the fluids like you said and should be gtg.
2013 JK Rubicon-Nth springs, Metalcloak arms, Warn M8000, Spod, 35" Nitto Trails, LOD bumpers....
Mello03 is offline
post #6 of 23 Old 04-15-2013, 08:12 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Originally Posted by Monstrousmac View Post
1) Change Oil,
2) Pull out Spark Plugs
6)change all other lubricating fluids - transfer Case, Transmission, Diff
I edited a bit. CHANGE OIL FIRST. Any water in the oil will be at the bottom of the pan. This means when you crank it - the water will be first to get pumped!
Second - why starter fluid in the plug hole AFTER the blow down? that could speed up surface rust as the ether WILL super dry the rings and walls of ALL lubrication (say goodbye to that cross hatch the hone so carefully put there for oil retention). Dry rings can break just turning by hand let alone with speed of starter - add compression at startup and you could break a ring land as well! I would use marvel oil or wd40 as a last resort (but its not very lubricious). Oil first and THEN blow down.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #7 of 23 Old 04-15-2013, 08:29 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Yes and no. There are reversionary waves that brings gasses back along the boundary layer of the pipes (which is how exhaust tuning works). Marine engines with submerged exhaust use separators and run the engine exhaust above the water line (and at least above the engine if the engine is mounted above the water line) and back down to prevent the reversion from carrying the water all the way to the cylinder.
When you shut the engine off - the block cools - when the block cools the volumes of gas contained in the exhaust manifold, cylinders with valve open etc. decrease as cooling occurs - when volume decreases a vacuum is created - the vacuum COULD be replaced with moisture drawn in. Low risk - but even drawing STEAM which will turn to enough water to hydro lock when cooled - enough for me to NEVER try to start an engine that has been shut down and cooled with the exhaust submerged before doing a good blowdown (crank with plugs out)!!
Even the crankcase can draw in if the pan rails are submerged.
Water leaks through a gasket that sufficiently holds oil (ever noticed the "oil vapor line" around the pan and valve cover gaskets after a few hundred miles? ALL gaskets must allow some of the retained fluid into or onto the material or the gasket will dry and fall off as dust!!)
post #8 of 23 Old 04-15-2013, 08:32 AM
rha600
True, but that cooling affect isn't going to suck the water up a foot. There can't be that much of a volume of air in the exhaust to suck it that far?
rha600 is offline
post #9 of 23 Old 04-15-2013, 08:47 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Your looking at WATER only. Steam (created by exhaust heat when running) can come up just as easy as air (that decrease in volume MUST be replaced with something) and then condense into enough water to push compression over 16:1 - hydrolock can occur with as little as 5 ccs of water...
EDIT to add - lets say it draws 5 ccs and you start it - it starts with a good cylinder which carries it past the hydro-locked cylinder and runs great. But you just stress cracked the connecting rod at the beam to big end radius. 12K mile later your rod and piston are laying on the road and you go gee I was just driving it down the road and for NO REASON it exploded...
post #10 of 23 Old 04-15-2013, 08:54 AM
rha600
That makes sense.
rha600 is offline
post #11 of 23 Old 04-15-2013, 10:17 AM
Yendor
I just want to see the pictures of the partially submerged Jeep! lol!
Yendor is offline
post #12 of 23 Old 04-15-2013, 12:40 PM
fltsfshr
I sunk my YJ a couple times out in the swamp. It was hydrolocked. Towed it out, pulled the plugs, turned it over, the water shot out then I sprayed the cylinders with WD40. Put the plugs back in changed the oil and drove it for another 80k.
Finally it really sunk when the clutch popped at a boat launch. That's salt water. It had 260k on it.
I gave it away.
fltsfshr
Past and Present Jeeps 2012 Wrangler, 1997 Wrangler, 1988 Wrangler, M151A
fltsfshr is offline
post #13 of 23 Old 04-15-2013, 12:57 PM
toxicwaste29
I gave it away.
fltsfshr
Should have made it into a trail rig
toxicwaste29 is offline
post #14 of 23 Old 04-15-2013, 01:02 PM
Filthy-Beast
Or a trailer.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #15 of 23 Old 04-16-2013, 03:43 PM
SubAtomicGenius
2011 JK Wrangler
I gave it away.
fltsfshr
lol
SubAtomicGenius is offline
