Help me find a lift for my 2 door JK PLEASE - JeepForum.com
post #1 of 18 Old 09-25-2013, 09:24 AM Thread Starter
JeepFlow69
Tire Size: 35"x12.50r17
Ive been looking at this tera flex 3" lift http://www.teraflex.biz/jk-wrangler-...arms-1711.html with maybe a cheap 2" body lift? Can i get some opinions or suggestions
JeepFlow69 is offline
post #2 of 18 Old 09-25-2013, 10:24 AM
chiefkp
That lift and 33" tires you will not need that body lift. IMO stay away from the body lift.
2013 JK Rubicon, 2.5 BB 35 inch pro comp M/T
chiefkp is offline
post #3 of 18 Old 09-25-2013, 10:52 AM
JTPhoto
JTPhoto's Avatar
The TeraFlex 2.5" is more then enough for 33".. You can Run 35" tires with 2.5" lift and stock fenders..
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #4 of 18 Old 09-25-2013, 11:19 AM Thread Starter
JeepFlow69
What about with a 35" tire
post #5 of 18 Old 09-25-2013, 11:40 AM
JTPhoto
JTPhoto's Avatar
2.5" lift is plenty for 35" Tires...
^^Jeff^^
JTPhoto is offline
post #6 of 18 Old 09-25-2013, 11:50 AM Thread Starter
JeepFlow69
Thank you. Would just the regular TeraFlex 3" lift be good or would you recommend the long arm lift kit
post #7 of 18 Old 09-25-2013, 12:00 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
The JK already has longer arms than any previous Jeep...no need for a long arm kit at 2.5 inches.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #8 of 18 Old 09-25-2013, 12:10 PM Thread Starter
JeepFlow69
I'm think I'll go with a three inch just for that extra clearance
post #9 of 18 Old 09-25-2013, 01:49 PM
wilgeno
wilgeno's Avatar
There is this thread that covers a lot of details on Lift Kits, "definitive-lift-kit-thread" http://www.jeepforum.com/forum/f96/d...hread-1410631/
TeraFlexed '13 Commando Green JKU Black Hardtop roll'n on 35's!
Bug-Out!
I don't always go topless, but when I do I go Commando!
wilgeno is offline
post #10 of 18 Old 09-25-2013, 03:29 PM
DangFoo
I have a 3.5" ProComp lift on my 4-door (JKU) and a 2.5" Rubicon Express on the 2-door (JK); both are running 35" tires with zero rubbing issues.
The 2.5" lift had the front tire rubbing the air dam at certain steering angles and while compressed [light off-roading; I don't do any rock crawling]. I've since removed the air dam from both JKs and zero issues since.
The 4-door definitely sits higher than the 2-door with that extra inch of lift; exact same tires for that matter (though 17" wheels and 16" wheels respectively). If you want to keep your center of gravity low, then I'd actually go with the 2.5" and flat fenders ... that's just my opinion and the stance that I like.
Note: If you can spend a little extra coin, then opt for some Bilstein 5100s instead of the shocks that come with some of these kits. I have the Bilsteins on my JK and it makes a huge difference; smooth ride.
Best of luck!
DangFoo is offline
post #11 of 18 Old 09-25-2013, 04:23 PM
SLADE
Lift alone doesn't increase tire clearance (not where it's needed). You only need enough lift to cover the needed bump stop for the tire your running.
2.5" lift is plenty for 35's. You can add a 1"-1.25" Body lift if you want a little extra height and suspension travel or add flat flares to keep it low and gain suspension travel. You can get a lot more out of combining a 2.5" suspension lift with a body lift and flat flares than you will with just a 3.5" suspension lift.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #12 of 18 Old 09-25-2013, 06:30 PM Thread Starter
JeepFlow69
So with a 2.5" and flat flares with 35s i wont get any rubbing?
post #13 of 18 Old 09-25-2013, 06:37 PM
SLADE
Front should be fine with stock bump stops, the rear will need the rear bump stop extended a little.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #14 of 18 Old 09-25-2013, 06:55 PM
JTPhoto
JTPhoto's Avatar
The TeraFlex kit comes with the extended bumpstops so you won't have any rubbing with 35" tires and factory flares and of course you will need the appropriate 4.5" wheel backspace. However, If you really want to stuff the wheels up for max up travel for real rough trails then as Slade suggests go with flat fenders, no bumpstop extensions and a small body lift.
^^Jeff^^
JTPhoto is offline
post #15 of 18 Old 09-25-2013, 07:21 PM
COLOUXJ
2010 JK Wrangler
You get no more suspension travel with a body lift.
A 2.5" lift is plenty of lift for 35's and stock flares if you add 2.5" of bumpstop. If you have flat fenders you can get away with about 1" of bumpstop.
COLOUXJ is offline
