Help me figure out what to do next...ABS/skid/BDS lights on.. - JeepForum.com
post #1 of 9 Old 06-17-2013, 02:19 PM Thread Starter
yoda13
Force Wheeler
yoda13's Avatar
OK, guys, I had an issue with my swayloc coming apart on me while I was wheeling a few months ago...tore up the front of my Jeep a little...I have everything bent back and the stock sway bar and disconnects reinstalled...
The ABS/skid/BAS lights have been on since the incident...last time I ever pay a mechanic to install something I could do myself (swayloc)...at any rate...I reassembled and bent back all the messed up components, reinstalled the stock swaybar and put my JKS quick disconnects back in...I have checked the steering wheel centering via my pro cal, checked the alignment professionally where I always get it done (shop with computerized system that specializes in Jeeps), checked all the fuses, and looked for loose wires. Everything appears to be fine, yet my dash is still lit up like a Christmas tree...I pulled the codes and got these...
U1417
C1020
C100A
C123C
B165D
U0186
B219F
B1644
B1648
B1643
I forgot what they all meant, though my flashpaq told me...mostly they had to do with distance to sensor not being right...figured it was an alignment issue, but not...
What else do I need to check? I need some ideas here guys Thanks.
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Bilsteins, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, Delta replacement non-quadbar xenon headlamps, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, †John 3:16†
RIP Mrs. yoda13... My life is better for having had you in it and you made me a better man...I can't wait to see you again...I love you always and forever, and for all eternity
If you want to help the sport of off-roading, and protect your right to do so, please visit the
forum...
yoda13 is offline
post #2 of 9 Old 06-17-2013, 02:28 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
You bent back components? Like what ones?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 9 Old 06-17-2013, 02:34 PM Thread Starter
yoda13
Force Wheeler
yoda13's Avatar
tab where the sway bar connects to the axle...
the sway bar links had come loose from the sway loc, but not from the bottom tabs...got caught up and carnage ensued..
forum...
yoda13 is offline
post #4 of 9 Old 06-17-2013, 02:50 PM Thread Starter
yoda13
Force Wheeler
yoda13's Avatar
and why in the heck am I losing communication with the audio amplifier? The radio works perfectly, including the subwoofer?!?
forum...
yoda13 is offline
post #5 of 9 Old 06-17-2013, 02:52 PM Thread Starter
yoda13
Force Wheeler
yoda13's Avatar
half of my codes that I am getting aren't even listed in the faq...
forum...
yoda13 is offline
post #6 of 9 Old 06-17-2013, 03:02 PM
nwbronco
2014 JK Wrangler
Which codes?
His 14 Anvil JKUR-X
Hers 09 Blue JK
Kid's '08 Yellow JKU
'13 Black 10A Rubicon JKU
nwbronco is offline
post #7 of 9 Old 06-17-2013, 03:05 PM Thread Starter
yoda13
Force Wheeler
yoda13's Avatar
pretty much any of the B codes...I so rarely use cruise, I think I am about to go out and see if that still works...I have been reading through threads where this situation has caused some people's cruise to quit working...
forum...
yoda13 is offline
post #8 of 9 Old 06-17-2013, 04:44 PM
nwbronco
2014 JK Wrangler
[QUOTE=I pulled the codes and got these...
U1417
C1020
C100A
C123C
B165D-LEFT PARK LAMP CONTROL CIRCUIT HIGH
U0186
B219F- IGNITION OFF DRAW (IOD) FUSE BLOWN
B1644- REAR LEFT TURN CONTROL CIRCUIT HIGH
B1648- REAR RIGHT TURN CONTROL CIRCUIT HIGH
B1643- REAR LEFT TURN CONTROL CIRCUIT LOW
Quite a list.
Bob K.
His 14 Anvil JKUR-X
Hers 09 Blue JK
nwbronco is offline
post #9 of 9 Old 06-18-2013, 11:08 AM Thread Starter
yoda13
Force Wheeler
yoda13's Avatar
I went out last night...cruise doesn't work also...funny thing is, the IOD fuse isn't blown...I'm beginning to wonder if there is something wrong with the computer...
forum...
yoda13 is offline
