Help installing lights firewall entry - JeepForum.com
post #1 of 8 Old 07-31-2013, 10:59 AM Thread Starter
animal145
Hi y'all,
I'm installing two sets of kc lights and my plan is to have my switches on the pillar on the drivers side. I took a look and I don't know where to go through the firewall with the wires. I have a 2013 jkur with a manual transmission.
Thanks in advance
animal145 is offline
post #2 of 8 Old 07-31-2013, 11:18 AM
ferninaz
ferninaz's Avatar
Check under the drivers side dash, pull the carpet back. there is a hole. It may have some foam you need to punch out, but its there.
ferninaz is offline
post #3 of 8 Old 07-31-2013, 12:04 PM
SteveBad
SteveBad's Avatar
2011 JK Wrangler
The jeep is one of the easiest vehicles for this......
In each upper corner of the firewall, (viewed from the engine bay) is a
large foam-filled pocket. Simply tape your wires to a straightened coathanger and poke it through.
" Leave the gun .... take the cannolis. "
SteveBad is offline
post #4 of 8 Old 07-31-2013, 12:55 PM
Astennis1
I'm thinking of doing the same thing. What are you using for your switch mounts on the pillar, and are you using relays?
Astennis1 is offline
post #5 of 8 Old 07-31-2013, 12:58 PM Thread Starter
animal145
Ok I'll check that out. Any good videos on how to take the interior apart to get to that area without messing it up?
post #6 of 8 Old 07-31-2013, 01:01 PM
ferninaz
ferninaz's Avatar
No need to take the interior apart to poke wires thru the firewall.
ferninaz is offline
post #7 of 8 Old 07-31-2013, 01:02 PM
ferninaz
ferninaz's Avatar
ferninaz is offline
post #8 of 8 Old 07-31-2013, 01:27 PM
Lynhalla
Lynhalla's Avatar
I dont know if the 2013 is same as 2008 but if it is, if you look under hood above and right of master cylinder is a hole with rubber plug in it. hole is about 1/2" to 3/4" and if you put a coat hanger down it you can easily feed wires through it. If you plan on adding future accessories, consider installing the SPOD system under your hood. It makes life easy. Comes with a 6 switch pod or 4 switch with compressor pod that installs above your rear view mirror. you only have to feed one wire through firewall. box mounts easily under hood, you just plug accessories into it. It has relays and fuses and wires directly to battery so you dont have a jungle of wires attached to battery or fuse box. can send pictures if interested
___________________
2008 JK Unlimited X
RIPP stage 2 supercharger, R/K xfactor 5.5" long arm coilover susp., 40"x13.5" G/Y kevlars, 17x9.5 Raceline beadlocks, EVO gussets and sleeves, Yukon chromoly shafts, Artec trusses, T/W drive shafts, Eaton lockers, G2 5:13 gears, ORFAB front bumper with smittybuilt 12000 winch, Body Armor rear bumper, ORFAB roll cage, Mastercraft Baja seats, SPOD
Lynhalla is offline
