HELP!!! Giant puddle killed my Jeep - Page 2 - JeepForum.com
post #16 of 54 Old 12-18-2009, 02:34 PM Thread Starter
taj8250
ok im gonna check the codes thing now. Where is the starter at? All the fuses were fine. The engine bay is bone dry. I can't see anything disconnected. When I crank it it revs to like 500 RPMs and dies just as quick.
taj8250 is offline
post #17 of 54 Old 12-18-2009, 02:49 PM Thread Starter
taj8250
Ok no codes. Just says done. No water in the oil when I checked the dipstick. Guess I'm gonna have to get her towed in the morning. Hope warranty will cover whatever the problem is.
taj8250 is offline
post #18 of 54 Old 12-18-2009, 02:52 PM Thread Starter
taj8250
Oh and to the guy that asked, I live in Atlanta between midtown and buckhead.
taj8250 is offline
post #19 of 54 Old 12-18-2009, 03:12 PM
NE Wrangling
I beleive it is on the underside of the engine on the drivers side but I can't verify right now as jeep is not home.
In the morning it will more than likey have dried out so if the wiring did not give then it should start. not so sure that is the issue now that you said it got to 500 rpm then went away. try it in a few hours as it sounds like where ever the water is preventing the connection might be drying out.
NE Wrangling is offline
post #20 of 54 Old 12-18-2009, 04:12 PM Thread Starter
taj8250
Disconnected the battery for 10 minutes. Still wouldn't start. Thanks for the suggestions guys. I will have it towed to the stealership in the morning.
taj8250 is offline
post #21 of 54 Old 12-18-2009, 04:47 PM
Dumontra
2009 JK Wrangler
Here's a stupid question! Are you out of gas? Sorry, had to ask...
Dumontra is offline
post #22 of 54 Old 12-18-2009, 05:04 PM
Imped
Imped's Avatar
Let this be a lesson. That's why you drive through deep water SLOW. Jeep or not, that's just poor form.
OlllllllO
IndyORV
Imped is offline
post #23 of 54 Old 12-18-2009, 05:52 PM
Joe Diver
2009 JK Wrangler
Oh, I don't know.....
There's this intersection by my house.....every time it rains, two of the lanes get a BIG puddle of water......and the oncoming traffic stops right by it. If you were in one of those cars, the big arse puddle would start by your left front tire and go all the way to the other curb.
In the summer, if you're lucky, you can catch a converible sitting there at the light as you blast through.....
Yeah, I know....that's mean as h3ll......but sometimes it's so funny...like the time I caught a car full of high school girls....the screams were priceless.
2009 Sahara, Red Rock, auto, MyGig REN, Trac-Lok, remote start, soft top, Nuvi 765T, Escort X50 Blue, Cobra 29WXNW, Firestick II, Recovery Kit, Bestop Bikini Top, Soft Top Cover, Jeep Hood Bra
Joe Diver is offline
post #24 of 54 Old 12-18-2009, 06:24 PM
traderdan
I had the same problem last month. Mine turned out to be hydolocked. It doesn't take much. When it happened I checked the dipstick and no water. I pulled the plugs and and there it was. Only a couple drops of water. Only on two of the plugs. Hope it isn't but sounds like it. You can also try to manually turn it to see. I would take out plugs and empty oil first.
traderdan is offline
post #25 of 54 Old 12-18-2009, 06:37 PM
RacingRandie
2009 JK Wrangler
If it is turning over it is not hydrolocked unless the rods already broke.
RacingRandie is offline
post #26 of 54 Old 12-18-2009, 06:38 PM
DirtyJeepBoy
Originally Posted by mantis View Post
LOL!! That's signature worthy.
hahaha yes it is
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
My Build:
BDS/BTF/MCE
DirtyJeepBoy is offline
post #27 of 54 Old 12-18-2009, 07:08 PM
Intrepid4576
2009 JK Wrangler
o.o haha lol that would be neat to see on you tube
Intrepid4576 is offline
post #28 of 54 Old 12-18-2009, 08:11 PM
tylerd
2006 WK
I think that's a challenge Joe.
tylerd is offline
post #29 of 54 Old 12-18-2009, 09:31 PM
NE Wrangling
what I was suggesting earlier on checking the oil was remove it. I mean drain it, take it out and replace. Then pull all the spark plugs and check carefully each one as you take out.
Then with the plugs out try to crank the engine to blow out the water. If you take the plug wires off you should also check that they are not wet as this can cause the effect you mention.
good luck and post up what is found or the stealership finds. I'd do these minimal thing before letting them even smell the engine. I don't trust their diagnostic skills for the majority of the mechanics at the dealerships. First thing is ask who is the master mechanic and request he is the only one that checks it over.
post #30 of 54 Old 12-18-2009, 09:37 PM
Green4dr
show the jeep some tough love kick it. my rear wiper on my cherokee responds to being hit. you just gotta knock some sense into it.
98 Green Cherokee Classic 4.0
3'' Rough Country II 33x12 bfg at
Spring Break Build thread/ makeover
http://www.jeepforum.com/forum/f22/98xj-classic-springbreak-makeover-1344754
Green4dr is offline
puddle killed my jeep, any ideas what it could be? bmxrules39 TJ Wrangler Technical Forum 30 02-07-2010 11:25 PM
A puddle killed my jeep... TPS maybe? adudenamedsean TJ Wrangler Technical Forum 10 01-22-2010 12:37 PM
Oil Puddle under jeep this am fdkss03 TJ Wrangler Technical Forum 4 01-14-2009 10:24 AM
Coolant Puddle Under Jeep wingzero1285 TJ Wrangler Technical Forum 35 05-29-2007 11:51 PM
jeep wont run after mud puddle RnEmOvr TJ Wrangler Technical Forum 3 11-06-2005 01:21 PM
