HELP!!! Giant puddle killed my Jeep - JeepForum.com
post #1 of 54 Old 12-18-2009, 12:36 PM Thread Starter
taj8250
Ok I need some help if anyone has experienced something similar. I was coming home and drove through a giant puddle in front of my apartment. Jeep stalled and won't crank back up. All the electrical works fine. No water in the airbox. Engine itself appears dry. It will not turn over. Giving it gas has no affect. Any ideas? Help? Solutions?
taj8250 is offline
post #2 of 54 Old 12-18-2009, 12:45 PM
OregonVette
Yikes.... How giant was Giant?
8" of water or 18"... 28" ?
Originally Posted by smcutter View Post
It's hard to give you good advice at this point. It's almost like you're saying, "I want to have sex, but don't want to get her pregnant. I can't afford condoms, so for now I just want to use Saran Wrap. What brand would you recommend?"
OregonVette is offline
post #3 of 54 Old 12-18-2009, 12:51 PM Thread Starter
taj8250
I dunno I guess like 5"-10" but it was blocking 3/4's of the lane I was in. I couldn't avoid it cuz there was a curb to the right and a car to the left. I shoulda slowed down, but I was like F*** it, it's a Jeep.
taj8250 is offline
post #4 of 54 Old 12-18-2009, 01:10 PM
Hilldweller
2014 JK Wrangler
Check the fuse box yet?
Safety fast,
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing.- Helen Keller
Hilldweller is offline
post #5 of 54 Old 12-18-2009, 01:13 PM
alaskanthunder
If it is wet. Get some canned air and hit that **** HARD!
2007 JK 2-dr X | Steel Blue | 4.10 Auto D44
alaskanthunder is offline
post #6 of 54 Old 12-18-2009, 01:15 PM
mantis
LOL!! That's signature worthy.
mantis is offline
post #7 of 54 Old 12-18-2009, 01:23 PM
Hilldweller
2014 JK Wrangler
I just noticed you're local; where you at?
Safety fast,
post #8 of 54 Old 12-18-2009, 01:23 PM
rirrgang
Could you imagine offroading with it? Yikes.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #9 of 54 Old 12-18-2009, 01:44 PM
NE Wrangling
Can you locate the starter and make sure the power of the water balst didn't disconnect any of the wires attached to it. If not take a OHM meter and test if the power is getting there. Also what codes are you getting?
My guess is something got completely disconnected if you still have electricity flowing.
NE Wrangling is offline
post #10 of 54 Old 12-18-2009, 01:56 PM Thread Starter
taj8250
I'm headed out to check it now. I figured I would let it dry for an hour or so. So I'm gonna check the fuses and wires underneath. And how do I check the codes?
taj8250 is offline
post #11 of 54 Old 12-18-2009, 02:00 PM
NE Wrangling
turn everything off in the jk. Radio, lights and keep the door closed.
Insert key and push in and turn from stop to ACC position 3 times quickly leaving the key in the acc position on the 3rd turn. The dash turns into a christmas tree and the odometer will have dashes as the computer runs a diagnostic test.
looks like ---> ---------
when done it will either return codes or will show ---> --done----
get a pencil and paper as they go fast and you might have to repeat until you get them all.
post #12 of 54 Old 12-18-2009, 02:00 PM
Hilldweller
2014 JK Wrangler
See if anything on the dash blinks when you turn the key to on.
Safety fast,
post #13 of 54 Old 12-18-2009, 02:03 PM
NE Wrangling
if nothing is returned you need to check the oil and spark plugs to make sure water did not get in the engine. Hydrolocked is a evil word but it can happen. Check to make sure the filter is dry and that it is clamped down correctly. I saw two cases of the box not being seated correctly and water getting in.
post #14 of 54 Old 12-18-2009, 02:15 PM
1222
RIP John
1222's Avatar
I think you meant a voltmeter.
(2011-2016)
1222 is offline
post #15 of 54 Old 12-18-2009, 02:17 PM
NE Wrangling
yep sure did
puddle killed my jeep, any ideas what it could be? bmxrules39 TJ Wrangler Technical Forum 30 02-07-2010 11:25 PM
A puddle killed my jeep... TPS maybe? adudenamedsean TJ Wrangler Technical Forum 10 01-22-2010 12:37 PM
Oil Puddle under jeep this am fdkss03 TJ Wrangler Technical Forum 4 01-14-2009 10:24 AM
Coolant Puddle Under Jeep wingzero1285 TJ Wrangler Technical Forum 35 05-29-2007 11:51 PM
jeep wont run after mud puddle RnEmOvr TJ Wrangler Technical Forum 3 11-06-2005 01:21 PM
