Help, getting sea sick - JeepForum.com
post #1 of 9 Old 12-01-2009, 01:35 PM Thread Starter
Existence
Hi Guys,
I'm at the end of my tether.
We are trying to sort out some steering issues on a Rubicon Unlimited.
The Jeep was fitted with an OME lift kit using the HD package. This set up gave the Jeep a 3.5" lift, but no relocation brackets were supplied.
When driving the Jeep on the motorway it feels like it is floating and constantly pulling to the left. The alignment is in spec with a bit more toe in.
Today we installed a front adjustable track bar and rear track bar relocation bracket to get the axles centred. This actually made it worse.
The next step is to adjust the caster, but is there something I am missing? All bolts are torqued to factory spec and there is nothing loose.
Your advice will be most appreciated.
Thanks
There are two types of pedestrians, the quick and the dead.
Existence is offline
post #2 of 9 Old 12-01-2009, 01:54 PM
Hilldweller
2014 JK Wrangler
See this other thread; OME gives you a lot of lift but not many extras:
http://www.jeepforum.com/forum/f96/r...nstall-914379/
Safety fast,
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing.- Helen Keller
Hilldweller is offline
post #3 of 9 Old 12-01-2009, 02:09 PM
MattJK09
2009 JK Wrangler
We are in the same boat....no pun intended. I'm tired of it and may remove the lift.
09 X 23S Flame Red 2door, tinted, Black Rock 997's, BFG 32" MT's, grab handles, RR XHD front bumper,BW trail armor,4door springs up front, KC's
MattJK09 is offline
post #4 of 9 Old 12-01-2009, 03:01 PM Thread Starter
Existence
Thanks for the link.
The thing I find strange is that the OME kit used to give you a solid, if not hard, ride.
I have the 3" Zone lift with the adjustable trackbar and the same setup, even ride height, to the OME kit as it stands now but mine handles perfectly.
The only difference is that I have the cam adjusters in mine. Could this really make such a huge difference in ride quality?
post #5 of 9 Old 12-01-2009, 03:19 PM
DeepSky
Caster can have a lot to do with wandering and pulling. I would start there for sure.
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #6 of 9 Old 12-01-2009, 05:02 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I have that OME setup with JKS adj front and rear track bars, I ended up adjusting caster to about 3 degrees using front adj upper control arms - perfect ride and control. Later I added rear upper adj CAs to adjust rear pinion angle and avoid a DS problem in the future.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #7 of 9 Old 12-01-2009, 06:46 PM
MattJK09
2009 JK Wrangler
I think the problem we have is finding someone locally who knows what they are doing like you Rockyclymer. I found a local Jeep club guy who met me one day and drove it to see if he could tell what the cause was. He said it drove fine to him...it's hit or miss
MattJK09 is offline
post #8 of 9 Old 12-01-2009, 10:43 PM
RockyClymer
RedRock4Wheeler
Thanks for the compliment - not many of those around and I try to stick to what I know and not speculate...my theory, Good decisions come from bad experiences and bad experiences come from wrong decisions.
NRA Life member
post #9 of 9 Old 12-01-2009, 11:21 PM Thread Starter
Existence
We'll do the caster adjustments today and then see where we are.
Thanks again.
sick jeep rickr TJ Wrangler Technical Forum 5 12-20-2007 11:54 AM
sick of my slushbox.... LilViper95 TJ Wrangler Technical Forum 19 12-15-2005 07:23 PM
Sick TJ THEKEEB17 TJ Wrangler Technical Forum 13 04-05-2005 10:22 PM
sick little 2.5L nsi31 TJ Wrangler Technical Forum 12 05-18-2004 08:49 PM
My jeep is sick 97TJGUZZY TJ Wrangler Technical Forum 10 04-29-2003 09:33 PM
