HELP!CLUTCH REPLACEMET WITH >6K miles - Page 3 - JeepForum.com
post #31 of 61 Old 06-22-2013, 02:08 PM Thread Starter
LTGreek
never fired, only dropped once
LTGreek is offline
post #32 of 61 Old 06-23-2013, 03:09 AM
singular_lupus
Ditto on the "any offroad driving is considered abuse". Took my new jeep onto a trail to help pull a friend out of a hole and had the mud water (you know that really thin mud that dries like silt) kill one of the rear speed sensors. Didn't hit anything or scratch my vehicle while I was out. Took it to the stealership and got told I was abusing it and were very reluctant to repair it. The mud water killing the e-brake pads in the 12 or so hours of driving in between the mud and the stealership also contributed to their reluctance.
singular_lupus is offline
post #33 of 61 Old 06-23-2013, 03:36 AM
tankinyj
Im trying to wrap my head around this. How did you smoke your clutch if you werent riding on it? (your foot on the clutch pedal) Ive put my JK, and even my old YJ, through some ****, and the clutch has only smoked if I was wheeling and had to feather the clutch due to my lack of gears at the time. AFAIK the 2013 and the 2012 are identical in terms of drivetrain. Traction Control/ESP wouldnt be an issue had you been in low-range since all those safety systems are turned off, and if you were in high-range you would have been throwing indicator lights and tones all over the place. Your saying the engine was putting out all its power that caused the flywheel to loose its grip on the clutch and just smoke it? In first?I dunno, without a case of oil soaking that clutch this seems pretty farfetched to me.
Got a son or girlfriend that stole your Jeep for the night to learn to drive manual?
Sorry. One vote for user error...
2012 JK, 44s, rubi case, 37" PBRs, stretched 8"
Crush Orange Jeep Member #55
NYC Jeep Club
tankinyj is offline
post #34 of 61 Old 06-23-2013, 11:20 AM Thread Starter
LTGreek
the clutch was slipping as I was hitting soft sand. I was not on the clutch, and started to smell the universal smell of a burning clutch. I looked at my feet and was beyond confused, since it was not on the clutch. Then I stopped and put it in 4wd low and tried to make it to the road but it was too late.
I was talking to my uncle, who is an engineer. I explained to him the situation and this is basically what he said, "the reason why my clutch was slipping when you were not riding it is because it was fail, a jeep wrangler should not have a clutch slip on it's own while going through different sand.
I called Mopar, they were speechless, and it made it sound like they have ran into this problem before. The problem is, I am traped at dealer that is not willing to do the proper diagnostic.
LTGreek is offline
post #35 of 61 Old 06-23-2013, 11:22 AM Thread Starter
LTGreek
Also, when I am on the road the clutch burns when I am passing or merging on the highway, at around 4500.
LTGreek is offline
post #36 of 61 Old 06-23-2013, 11:31 AM Thread Starter
LTGreek
I don't understand it at all!
all I know is that I read an article on how to turn the esp off in 4WD high. My clutch started to burn as I was driving in the tracks of other people. Soon after, the clutch started to smoke, so I stopped and put her in 4WD low. By then, it was too late. The 4x4 of the decade couldn't handle the beach.
Those light never came on...
I DID NOT GET BOGGED DOWN.
My Jeep is stock with radical tires and 3.73 gears.
The thing that really made me angry was the fact that emergency road side assistance said that they were coming and 12 hours later the park ranger came to my jeep and said that you need to figure this out on your own.
So, In the end, I was on the beach, overnight, doorless, and with no cell phone service waiting for roadside to come. Only to be bullied by a dishonest dealer.
LTGreek is offline
post #37 of 61 Old 06-23-2013, 12:32 PM
Taylode
From what I've read so far, I think that the clutch slipping may be Jeep's issue; however, to go from a slipping to smoking I think is all on you. A slipping clutch should be very noticeable especially in the low gears where there is lots of torque. A slipping clutch would be noticeable whether you were on pavement or ice. When you felt the lessing of power (slipping) you should have noticed your RPM rising while your speed was diminishing. By down shifting and mashing the accelerator you exacerbated the problem and totally fried your clutch in the process. Had you been paying attention to what your Jeep was doing, and shifted into a higher gear with has less torque you may have been able get the clutch to reengage and limp your way out and perhaps get away with a simple clutch adjustment. I have no way of knowing but I'd guess that if you had brought your Jeep in with a slipping clutch rather than a completely fried and smoking one the dealer would have repaired it without complaint. However, to bring in one that is completely fried is probably why they view it as abuse. Good luck in finding a dealer to fix it under warranty and regardless of whether you do or not hopefully you learned something from this experience.
Dennis
2013 Jeep JKU Sahara
Taylode is offline
post #38 of 61 Old 06-23-2013, 12:58 PM
Bville-Bud
Hey OP, what dealership are you working with? I'm less than 50 miles from Smithsburg and probably two weeks away from a new JK. After registering on True Car and a few other sites, I am getting emails and phone calls from every dealership around; I'll be happy to tell them why I wouldn't consider buying from them.
Bville-Bud is offline
post #39 of 61 Old 06-23-2013, 01:16 PM Thread Starter
LTGreek
I had no idea what was going on at first. I didn't know that it was slipping. I thought that it was loosing traction from esp system and that was why I went to 4wd low.
I was not slamming on the accelerator, when I noticed that I was losing speed, I up shifted. Not because I was trying to engage my clutch, but because I didn't want my engine to overheat.
I have a lot to learn, I am not saying that.
I just believe that I should not have to pay for a clutch that was slipping because I was in the sand.
LTGreek is offline
post #40 of 61 Old 06-23-2013, 01:23 PM Thread Starter
LTGreek
I appreciate the help, but I am at a dealer in Georgetown, Deleware.
Check out koons! I got my jeeps for 6k under the msrp.
They will low ball you on the trade, if you have one. Mine went from 7k to 16k lol. The sale-mens was lying to me, telling me that I broke suspension parts due to off roading. Then, I looked him in the eye and called him an idiot after I said that if there was 5K worth of suspension damage I would not of been able to make the drive on 70, 270, and 465.
Good Luck
LTGreek is offline
post #41 of 61 Old 06-23-2013, 01:27 PM
Taylode
Well it sounds like you have the right attitude and I really do wish you luck!
Dennis
Taylode is offline
post #42 of 61 Old 06-26-2013, 08:57 AM Thread Starter
LTGreek
Jeep will not replace the clutch under any circumstances. They don't care if you drove off the lot a mile and it explodes...
LTGreek is offline
post #43 of 61 Old 06-26-2013, 09:23 AM
Tanimal
Lol that's doubtful, they prob flagged you for offroad abuse
Learning as I go and it's worth every penny!
Tanimal is offline
post #44 of 61 Old 06-26-2013, 09:36 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
there is no way that the clutch wouldn't hold the engines power, thats ridiculous to think that it would slip. if he had his foot on the clutch pedal or messed up - its one thing but blaming the clutch slipping on its own is just stupid. either the OP did something directly to mess it up (which it sounds like he did not) or it was a bad clutch and the dealer needs to fix it. call chrysler corporate again. demand action.
My builds:
and
or follow us on
spyder6 is offline
post #45 of 61 Old 06-26-2013, 09:52 AM Thread Starter
LTGreek
I have been!!! It's so frustrating. I feel like I going to have to do research on my lemon rights....
All car manufacturers have a cartel against fixing their manual clutch! They said that it's the industry norm to make their customers pay for the clutch, no matter the situation.
LTGreek is offline
clutch , dealership , jku , warranty
