HELP!CLUTCH REPLACEMET WITH >6K miles - JeepForum.com
post #1 of 61 Old 06-21-2013, 03:43 PM Thread Starter
LTGreek
I was on the beach driving, I lost power, so i reved the engine. Then, all of a sudden, my clutch started burning and I was strained on the beach. I didn't ride the clutch, or slip it. my wheels lost power and then it started to slip. Maybe I am wording this wrong, but in the end I lost power to wheels and my clutch started burning.
The dealership I am at will not cover it.
It's a 2013 JKU
Has this happen to anybody else.
LTGreek is offline
post #2 of 61 Old 06-21-2013, 03:49 PM
222Doc
222Doc's Avatar
I am thinking you left it in high range. should have been in low. If say add to this bigger tires not enough gear, to much cow bell.
222Doc is offline
post #3 of 61 Old 06-21-2013, 03:55 PM Thread Starter
LTGreek
It's stock with 3.73
LTGreek is offline
post #4 of 61 Old 06-21-2013, 03:57 PM Thread Starter
LTGreek
I hit soft sand and lost power, so I thought. In reality, the clutch the slipping/failing. Either way, a clutch should not fail because of added strain to the drivetrain from soft sand...
LTGreek is offline
post #5 of 61 Old 06-21-2013, 09:00 PM
Spank
2014 JK Wrangler
More details on this and your Jeep, please. Did the dealership look at it or did you just tell them what happened?
'14 Wrangler Unlimited Rubicon
Spank is offline
post #6 of 61 Old 06-21-2013, 09:23 PM
222Doc
222Doc's Avatar
think about it. Its bogging down you do not down shift, go to LOW range? really just floor it? so the pentaticker tries to lay down its 285 horse power and the clutch don't hold? No you should have been in Low range in 5th if you needed to go fast. when it bogged you could have went to all those gears in low to first. heck its only a 2:73 ish low right? not like its a rubi with 4:1 low and can be to slow in some sands.
It BOGGED down in what I am saying in 1st 4x4 HIGH range. Driver should have went to low range BEFORE he went wot against the friction of sand and 4x4. This is like basic off road stuff.
No offense just the way I see it. It was BOGGING down in first high. then go to 5th low and work your way down to first again and if that don't work you are really ******. better regear the heep.
222Doc is offline
post #7 of 61 Old 06-21-2013, 09:27 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Clutch is a wear item and is only covered for 12 months/12k miles on a new Jeep. If you have had your JK for less than 12 months they should fix it.
Jim
JLC08JK is offline
post #8 of 61 Old 06-21-2013, 09:37 PM Thread Starter
LTGreek
It's a 2013 jeep wrangler. I have had it for about six weeks
LTGreek is offline
post #9 of 61 Old 06-21-2013, 09:47 PM
ronjenx
ronjenx's Avatar
This is from the 2013 warranty booklet. Did they say why they wouldn't cover it?
The Basic LimitedWarranty lasts for 36 months from the
date it begins or for 36,000 miles on the odometer,
whichever occurs first. But the following items are
covered only for 12 months or for 12,000 miles on the
odometer, whichever occurs first:
brakes (rotors, pads, linings, and drums);
wiper blades;
clutch discs or modular clutch assembly (as
equipped);
windshield and rear window; and
wheel alignment and wheel balancing
ronjenx is online now
post #10 of 61 Old 06-21-2013, 09:49 PM
JLC08JK
JLC08JK's Avatar
If the dealer has a problem with fixing it for you, take your case directly to Chrysler and they should approve the work.
Jim
JLC08JK is offline
post #11 of 61 Old 06-21-2013, 09:57 PM Thread Starter
LTGreek
No, no, no, no, I was not stuck. I understand that concept and I have done that times when I feel as if I am getting stuck or am stuck, that wasn't the case. As I was driving, I was slowly losing power but gained it, then lost some, and gain it.
It was not like I got stuck, floor it then hope I get out!
I was never stuck
The clutch was slipping as I was casually driving on the beach. A 2013 JKU should not have that happen as it is casually driving on the sand.
LTGreek is offline
post #12 of 61 Old 06-21-2013, 09:58 PM Thread Starter
LTGreek
They keep on saying that it was abuse from the operator. I just don't know how to prove that the clutch was slipping due to the terrain that it was on
LTGreek is offline
post #13 of 61 Old 06-21-2013, 10:01 PM
SubAtomicGenius
2011 JK Wrangler
Depends on what kind of sand we're talking about. Driving along fresh, hard-packed tidal sand or the soft stuff? Because there is a big difference between the two.
Not to take sides with the stealership, but I've driven in both conditions, and I've never had an issue. But flooring the engine in sand? Seriously? Sorry, but at face value it sounds to me like there may be a lesson in "4x4ing in sand" or "how to use a manual transmission" buried here somewhere... at just about the price range of a new clutch.
SubAtomicGenius is offline
post #14 of 61 Old 06-21-2013, 10:02 PM Thread Starter
LTGreek
I called Mopar, they said that it is the dealer's call
LTGreek is offline
post #15 of 61 Old 06-21-2013, 10:06 PM Thread Starter
LTGreek
It's not just me, or my driving habbits
http://www.lemonlaw.com/wordpress/je...vers-worn-out/
LTGreek is offline
clutch , dealership , jku , warranty
