HELP - Can't Disable the ESP. - JeepForum.com
post #1 of 46 Old 05-17-2010, 09:47 PM Thread Starter
bmf2001
I received, in the mail, an addition to my owner's manual with instructions on how to permanently disable the ESP. I have followed the instructions 20 times with no success. Can anyone tell me the trick to get it to work? I took it to the dealer but they wouldn't touch it, said it was a liability if they disabled it.
I am burning through brake pads whenever I turn or take the circle shaped on and off ramps for the freeway doing 25 MPH.
I have a Hypertech programmer but I wouldn't think that makes a difference. Maybe it does and I have to set it back to factory first?
Thanks!
bmf2001 is offline
post #2 of 46 Old 05-17-2010, 10:04 PM
MilitaryJK4455
2010 JK Wrangler
You need to center your steering wheel computer wise it sounds like. There is a sensor in your steering wheel of exact center and mechanically your steering can be fine, but if it is not electronically center then it will kick on the esp because your jeep thinks you are trying to go one way and your really going straight or turning or what have you... Understand?
MilitaryJK4455 is offline
post #3 of 46 Old 05-17-2010, 10:05 PM
MilitaryJK4455
2010 JK Wrangler
Oh, and why are you running a 6" lift with 35's? are you planning on 40's in the near future? Or do you just like that look? Pics please!
post #4 of 46 Old 05-17-2010, 10:39 PM Thread Starter
bmf2001
The instructions say:
Put it in 4H, center the steering wheel, cycle the ignition key off and on and wait 5 seconds, turn the steering wheel a half turn to the right and push the ESP OFF button for 7 seconds, turn the sterring wheel back to center, turn the steering wheel a half turn to the left and push the ESP OFF button for 7 seconds, turn the steering wheel back to center and push the ESP OFF button for 7 seconds, then cycle the ignition key off.
I've done this 20 times but it never works.
I was told when I purchased the lift it would look good and it does!!! I am so glad I didn't go with the 4" lift. I'd post pics but I'm not a paying subscriber so I believe I can't.
bmf2001 is offline
post #5 of 46 Old 05-17-2010, 11:10 PM
kudah
here is that problem that we have discovered... per Star (Chrysler tech support line) you have to disable the ESP........ before you install the lift. :
Robert
kudah is offline
post #6 of 46 Old 05-17-2010, 11:35 PM Thread Starter
bmf2001
Great, that figures! I was told you can disable the ESP with a Superchip so it sounds like that's going to be my only solution or get new brakes every 25,000 miles.
bmf2001 is offline
post #7 of 46 Old 05-18-2010, 04:18 AM
bubba2u
2009 JK Wrangler
why not press the esp disable button on the lower enter dash console?
bubba2u is offline
post #8 of 46 Old 05-18-2010, 08:18 AM Thread Starter
bmf2001
The "ESP OFF" button only works if your JK has not been lifted. It automatically overrides the "ESP OFF" in certain situations depending on the mods and for me that's every situation.
bmf2001 is offline
post #9 of 46 Old 05-18-2010, 08:25 AM
N2rock
N2rock's Avatar
I gotta agree. Is your steering wheel dead center? I know a lot of people with lifted JK's. And the only time the ESP has been an issue was when the steering was not dead center. And every time, centering the steering wheel corrected the ESP issues.
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #10 of 46 Old 05-18-2010, 08:27 AM
juiceparn
Who told you that? I turn off my esp all the time, I'm lifted (not 6"). If you just hit the button it doesn't turn it completely off, but if you hold it down until it dings then it's completely off. If your sitting still before you take off, how does your jeep know you have a lift kit?
07 JK 4DR 3.5" Rubicon Express, C gussets, Front XHD stubby, winch, Taboo Customs rear bumper with tire carrier, Taboo Customs Rock sliders.
juiceparn is offline
post #11 of 46 Old 05-18-2010, 08:40 AM Thread Starter
bmf2001
How do you know if the steering wheel is dead center or not. I assume having to pay for an alignment?
You know I have never tried pushing the button in for 5 seconds till it dings. I've always pushed it and the light comes on the panel showing it is off, according to the manual the light means it's off. (I got that info from kudah's response to this thread.)
bmf2001 is offline
post #12 of 46 Old 05-18-2010, 08:45 AM
N2rock
N2rock's Avatar
when you are driving straight down the road, is the Jeep logo in the center of the steering wheel completely straight? If it is angled at all, you are not centered. This is very common after lifting.
You re-center it by adjusting the drag link. Very simple to do
N2rock is offline
post #13 of 46 Old 05-18-2010, 10:15 AM
juiceparn
The manual tells you exactly what you want to know.
post #14 of 46 Old 05-18-2010, 01:30 PM
2jk1cjtj
my dealer shut my esp off for me i got a good dealer
2jk1cjtj is offline
post #15 of 46 Old 05-18-2010, 02:20 PM Thread Starter
bmf2001
Okay, the steering wheel is not true center, it drifts to the left. And I held the ESP OFF button for 5+ seconds and did not hear any dings, the light came on and then turned off while I was holding it though.
I'll try taking it to a different dealer to see if they will permanently disable it.
bmf2001 is offline
ESP disable Hilldweller JK Wrangler Technical Forum 40 11-18-2011 05:15 PM
Disable air bag Jasen TJ Wrangler Technical Forum 9 03-14-2010 11:45 AM
Disable ABS kingvm TJ Wrangler Technical Forum 4 12-22-2006 10:00 PM
TJ airbags disable? Bobbywolf TJ Wrangler Technical Forum 3 06-28-2006 04:37 PM
Start Disable Professor Bobo YJ Wrangler Technical Forum 7 11-10-2005 10:55 AM
