Help! Advice Needed on Death Wobble "Fix" - JeepForum.com
post #1 of 12 Old 10-22-2013, 10:00 AM Thread Starter
CTJeepGuy
2010 JK Wrangler
This is a follow-up to a previous thread. I recently experienced "death wobble." Tried fixing it with a new steering damper...no dice. Brought it to Jeep dealer today, and they said an hour-long inspection didn't turn up any clear problems. Their advice is to replace my tires, which do seem to be on their last legs (36,500 city miles). They think that will do the trick, but they're not certain.
My question to you, Jeep Forum sages, is this. Should I:
a) Seek another opinion and see if someone else can fix the Death Wobble? (but where if a Jeep dealer can't?)
b) Replace the tires and hope that, $800 later, that solves the problem?
c) Give up on this Jeep and get another car rather than sink God knows how much money into trying to figure out how to fix this? Seriously...I may abandon Jeeps altogether, although that would kill me.
Seriously, though...what would you do? It's so frustrating not knowing exactly how to fix this. Advice would be seriously appreciated.
2010 Black JK Unlimited Sport
CTJeepGuy is offline
post #2 of 12 Old 10-22-2013, 10:14 AM
COLOUXJ
2010 JK Wrangler
Is it death wobble or just shakes?
Have someone in the jeep turn the steering wheel as you are underneath. Every joint should just rotate. If there is any translation then replace it.
COLOUXJ is offline
post #3 of 12 Old 10-22-2013, 10:18 AM
Maertz
2009 JK Wrangler
This x2 you feel the tie rod drag link n track bar you should be able to feel or see whats bad.
I would assume they checked bjs and psi and tire balancing and castor and toe as that should be easy for them.
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
post #4 of 12 Old 10-22-2013, 10:22 AM Thread Starter
CTJeepGuy
2010 JK Wrangler
It is definitely death wobble. Super violent and won't stop until I stop. Scary stuff on the highway. I'm trusting that the dealer techs are doing the above...
post #5 of 12 Old 10-22-2013, 10:25 AM
COLOUXJ
2010 JK Wrangler
Do it yourself. That's the only way to know what you can do to fix it. The thing with death wobble is you can do certain things to check. But at some point you have to start throwing money at it.
I dont think I have ever heard of new tires fixing DW.
COLOUXJ is offline
post #6 of 12 Old 10-22-2013, 10:28 AM
brianjw
They are not. Otherwise it would be fixed.
brianjw is offline
post #7 of 12 Old 10-22-2013, 10:45 AM
JTPhoto
JTPhoto's Avatar
A bad tire will initiate DW but it not the problem. Something is loose or worn out and that is what allows the bad tire to start DW.. Check out Planmans thread on diagnosing DW..
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #8 of 12 Old 10-22-2013, 11:56 AM
animal145
Is your jeep lifted?
animal145 is offline
post #9 of 12 Old 10-22-2013, 12:04 PM Thread Starter
CTJeepGuy
2010 JK Wrangler
No...totally stock, I'm sad to say.
post #10 of 12 Old 10-22-2013, 12:49 PM
JTPhoto
JTPhoto's Avatar
Hey no worries... It just proves the point that it's not just lifted Vehicles that can be a victim of DW. As I stated previously, check Planmans write up as it is pretty thorough.
^^Jeff^^
JTPhoto is offline
post #11 of 12 Old 10-22-2013, 01:20 PM
propped1
I would do tie rod and ball joints before tires. If you need new tires, you need new tires, but it wont stop it.
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline
post #12 of 12 Old 10-22-2013, 01:53 PM
Maertz
2009 JK Wrangler
I would put my own hands on it and look at it before just randomly buying stuff.. Have someone steer it back and forth and hold the tie rod, drag link, and track bar also look for slop. Bjs are easy to check also.
Maertz is offline
death , fix , tires , wobble
