HELP! 2012 Wrangler has developed two oil leaks!!! - JeepForum.com
post #1 of 15 Old 05-25-2014, 03:35 PM Thread Starter
Drummerboy1975
While doing a routine oil change on the wife's 2012 JK, I found two oil leaks. One is engine oil coming from what looks to be two rubber grommets(weep holes?) just aft of the oil pan.
The other is oil drilling of of the ends avles where the spindle mounts. That oil is thick like axle or bearing grease. I've attached photos of both. I'll be taking it into my local dealership, as its still under warranty. I'd like to know what I'm looking at before calling them and taking it in. Thanks...
Drummerboy1975 is offline
post #2 of 15 Old 05-25-2014, 03:42 PM
AngryRedBird
You sure that's the oil pan?.. looks like that's part of an automatic transmission..
AngryRedBird is offline
post #3 of 15 Old 05-25-2014, 03:46 PM
Bnabb
Yeah that looks like the bottom of the bell housing, I would say rear main or rear of the oil pan.
1993 YJ
2001 XJ
2009 JK
1950 Chevy 3600
Bnabb is offline
post #4 of 15 Old 05-25-2014, 03:52 PM
AngryRedBird
Hey Thx @Bnabb
I've yet to explore any of the Fiat jeeps.. and I was taking a stab at it.Bnabb
But now that Bnabb's point this out and after a second look.. there is a seam (note the two main bolts in the image left & Right of center) So I'm thinking main seal.. between the engine and trans.
post #5 of 15 Old 05-25-2014, 03:59 PM Thread Starter
Drummerboy1975
Yes its where the engine and tranny meet... Hence aft the oil pan.
I'm guessing its the rear main seal.
Now I need to figure out what going on with the front end.
post #6 of 15 Old 05-26-2014, 06:17 AM
Bnabb
As for the front end if it is axle/bearing grease, really the only places it could come from would be ball joint boots or the cv joint.
1993 YJ
2001 XJ
2009 JK
1950 Chevy 3600
Bnabb is offline
post #7 of 15 Old 05-26-2014, 08:55 AM
rock-rocker
Just curious, how many miles on this Jeep before these 2 problems cropped their head up? Trying to determine how long I have.
The 2 rubber grommets/plugs tells me this is the bell housing and where the oil is leaking I'd guess it's your engine rear main seal. If it's an automatic trans you might be able to pull both of the plugs out, shine a flashlight in one and look in the other and look see if the oil is running down the back of the block. Usually hard to see. I have never really looked closely at mine so I'm not 100% sure if you will be able to look see.
The oil on the knuckle looks as if it may be axle oil. If you can get some on your finger and smell it (gear oil definitely has a distinct smell to it) you may be able to determine what it is that way. Hard to tell by the pics but it looks as if it's on the knuckle and closer to the axle tube. If it is diff oil then the inner seal is leaking.
Both issues are a PITA and if they are just weeping it makes more of a mess rather than detrimental to the operation of the vehicle (as long as the oil isn't steadily running out) and you check the oil levels on a regular basis.
Axle seal = easy. Good time to gusset, sleeve and chrome moly shafts.
Rear main seal = PITA
HTH but it is hard to determine the real problems by pic's. If you are still under the warranty try to get them to fix these issues. That's what we pay them the big bucks for.
BTCS, USN, Retired
2013 Jeep JKU Rubicon 10th Year Anniversary.
rock-rocker is offline
post #8 of 15 Old 05-26-2014, 11:23 AM Thread Starter
Drummerboy1975
Thanks everyone. It has a little over 43,000 miles but we have an extended warranty so I'll be taking it in this week.
post #9 of 15 Old 05-26-2014, 01:40 PM
Spank
2014 JK Wrangler
This issue should be covered under your 5yr/100k powertrain warranty.
'14 Wrangler Unlimited Rubicon
Spank is online now
post #10 of 15 Old 05-27-2014, 10:28 AM
SoK66
2009 JK Wrangler
More likely a valve cover leak. When chasing leaks start at the top of the engine & Work your way down.
Jeeps: Where my 401(k) went to die!
SoK66 is offline
post #11 of 15 Old 11-05-2016, 03:22 PM
WranglerEd03
2016 JK Wrangler
Drummer, did you ever get this resolved? The oil by the rubber grommets? Reason I'm asking, I've been seeing the same thing, couple drops on the driveway. I just crawled under, found oil around one of the grommets and wet around this area..Just some history, dealer replaced my oil pump in the beginning of this summer ( due to a code) and called me and told me my rear main was weeping and said I should probably have it replaced while they had the pan dropped . They covered the pump and the rear main under warranty, everything seemed fine but recently seeing some wet spots! Got 32,300 miles on my bought new 2012. Also noticed it looks like a lot of grey RTV used on the oil pan bulging out. Mines very wet around the black rubber grommet, the one on the passenger side and blowing back and dripping while parking..The other one is dry..Any ideas?
~Ed~
WranglerEd03 is offline
post #12 of 15 Old 05-06-2017, 06:23 PM
JDaPP
I have the same issue at the weep holes/rear of oil pan/front of the transmission, not enough to cause drops just wet. 2012 with 60k miles, should I be worried/need to get it fixed?
JDaPP is offline
post #13 of 15 Old 05-07-2017, 04:51 PM
christensent
2014 JK Wrangler
I had the exact same appearance with oil coming out the two rubber plugs. It was the rear main seal (but, just because it comes out there doesn't guarantee it is the rear main).
I wouldn't say it's a "common" problem for the JK, but it's certainly not rare to have the rear main seal go out. Mine was replaced under warranty.
christensent is offline
post #14 of 15 Old 05-07-2017, 05:01 PM
JDaPP
Ugh, I am out of warranty. I may just live with it since it is not dripping and I am sure it will be expensive to repair.
JDaPP is offline
post #15 of 15 Old 07-02-2017, 07:56 PM
JDaPP
So I put oil dye in and I discovered a little pool of oil right next to the oil filter housing. Took two pictures, hard to see but it right next to housing by the lowest bolt. Thoughts on where it would be coming from? Oil filter housing cracked? Could it be coming from the breather I took a picture of (looked like it had dry oil on it)? Any place else might be coming from to arrive in that area? Thanks.
JDaPP is offline
