Hello! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Hello!
Savvy Aluminum Gas Tank SkidFS: Jeep Fog Light LED Bulbs! Several Brightness Options! Stainless Steel Door Hinge Pins
Unread 08-07-2014, 09:19 AM   #1
reddog14
Hello!
Hi! I bought a 2012 JKU Sahara 3.6L that has 3.21 gears completely stock. It has plenty of getup and go for me. I have already read and gained a wealth of knowledge from the stickys and search. I just want to double check before I order 285/70R17 BFG A/T's on 17x9 Level 8 Strike 5's. If I understand correctly, I should be ordering the wheels with -12mm offset, not 0, right? How much will they stick out from the stock fender flares? Will it fit on the stock spare tire carrier/3rd brake light? No plans for lift any time soon. I may re-gear, I'll see how it behaves after the new shoes. It's my DD and does 80-100 miles/day. I know, I should have gotten a Prius but it's a ***** to take the doors off of them. Thanks for your input!
reddog14 is offline   Reply With Quote
Unread 08-07-2014, 10:28 AM   #2
DBA2GO
You stated that you'll drive 24K+ miles a year. I'd stick with stock sized tires & stock sized rims.
The tires and backspacing you are talking about will put mud & grime on the side of your Jeep, cut down on MPG & not really buy you anything (just looks & a little bit of clearance).
It's your decision. But you'll only be putting 1" under your Jeep.
One foot in the grave & one foot on the gas pedal!!
DBA2GO is offline   Reply With Quote
Unread 08-07-2014, 11:50 AM   #3
JTPhoto
JTPhoto's Avatar
To start 285s will rub the stock fenders front and rear if you flex but will be ok on-road only. As already mentioned you will only gain 1" in overall tire size which= 1/2" ground clearance. No point going 1/2 way go with a lift and 35s or stay stock height with 265s on new wheels for the look so you keep your mileage.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited. Auto, Tow pkg, Dual Tops, MyGig, Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 35x12.50x17 Pitbull Rockers on Blackrock Viper Alloys, Flex-o-lite trans cooler, Mr Grille billet grille inserts, AEV Prem Bumper ETC.. AND a Locked and Lifted Honda Foreman for when the trails get real tight
JTPhoto is offline   Reply With Quote
