Heavy Duty, lightweight winch bumper installed. (Pics) - JeepForum.com
post #1 of 33 Old 12-11-2009, 05:02 PM Thread Starter
Xtremjeepn
What has always made Jeeps fun to me is that they were light weight "scouting" type vehicles. Then we get a hold of them and start adding weight until they break. :shaking:
Having built dozens of Jeeps I was determined to not build the JK into a over burden beast. The more weight you add the more weight you have to haul up and over rocks. The more weight you have to lug around town, stop , start and turn. It breaks parts on the trail, it uses more gas, tires, brakes etc.
Of course there are certain things that a Jeep just kinda needs. Like a winch. I'm not totally convinced they need a bumper. But, I am not quite ready to hack off my front frame rails.
I have been waiting for someone to come out with a light weight winch mount solution, and hoping it would hold my factory fogs too.
So when Aberle Offroad introduced their one piece cast A356-T51 aluminum bumper I was ready to get one. It weighs less than 65lbs. Only about a 20lb difference over my stock set up with tow hooks and metal frame.
Here is their website for more info. Aberle Off Road Jeep Bumper
I took tons of pics. :laughing:
All the stock stuff removed.
Some quick test fitting with my Bulldog 12k winch.
Here is the back side of the bumper.
Forgive the cheap calipers I was too lazy to go get the good ones out. This is the winch plate.
Top deck.
Bottom deck in front of sway bar bracket.
Cole Ford
Xtremjeepn is offline
post #2 of 33 Old 12-11-2009, 05:03 PM Thread Starter
Xtremjeepn
This is the built in fairlead for the winch rope.
Got it bolted up. Super easy. Fits perfect.
This is Winchline.com winch rope with the dual rope. The red section is for high heat.
Done. That was fast and easy. They make a really cool hoop that matches the lines of the hood and grill but I wanted to stay super light and am not a big fan of hoops.
Cole Ford
post #3 of 33 Old 12-11-2009, 05:03 PM Thread Starter
Xtremjeepn
So then I ran out to take more quick pics.
Cole Ford
post #4 of 33 Old 12-11-2009, 05:04 PM Thread Starter
Xtremjeepn
Now I just need to go wash the Jeep. Hopefully it will be warm enough tomorrow.
Cole Ford
post #5 of 33 Old 12-12-2009, 07:36 AM
ArmyFireFighter
Nice Bumper, I was looking into getting a Rancho, but your set up looks real clean.
ArmyFireFighter is offline
post #6 of 33 Old 12-12-2009, 07:56 AM
mattman8706
mattman8706's Avatar
2009 JK Wrangler
thats why I just have the AEV winch mount on the front of my jeep.
to lightweight
-Matt
mattman8706 is offline
post #7 of 33 Old 12-12-2009, 08:07 AM
1222
RIP John
1222's Avatar
Good to see there’s another player in the bumper department. Looks good.
Why would you wash your Jeep with all that snow on the ground?
(2011-2016)
1222 is offline
post #8 of 33 Old 12-12-2009, 08:16 AM
Imped
Imped's Avatar
I'm diggin it man! It fits the winch very nicely. I'll be replacing steel with aluminum soon as well.
OlllllllO
IndyORV
Imped is offline
post #9 of 33 Old 12-12-2009, 10:21 AM
DeepSky
I didn't think I was going to like it at all from the first couple pics but damn that looks good on your Jeep!
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #10 of 33 Old 12-12-2009, 10:26 AM
jjg214
very sharp. if i had a jk, i dont think i could resist one of these, im using a multi mount winch set up with XJ right now.
Can i ask...if your going for a low weight rig, why did you start with a 4 door? arent they considerably heavier then the 2 door model?
WTB: HP Dana 30, Long Island/New York Area
detours backbone system for sale
jjg214 is offline
post #11 of 33 Old 12-12-2009, 12:01 PM
DANJEEPO8
Hey Xtremjeepn:
Do you know if you can buy the shackles by themselves? Also, it looks like they just mount directly to the factory holes behind the bumper. Could these be mounted to the stock bumper? It's what i've been looking for, since i'm broke and can't afford a kick *** bumper...thanks!
DANJEEP08
DANJEEPO8 is offline
post #12 of 33 Old 12-12-2009, 12:49 PM Thread Starter
Xtremjeepn
I'm not going for a light weight rig, rather trying to not build a heavy weight rig. I need the 4 door for all sorts of other reasons. A 4 door is not an excuse to just blindly add heavy stuff, but even more reason to keep it light since they start heavier.
Originally Posted by DANJEEPO8 View Post
Hey Xtremjeepn:
You can probably buy them separately from the bumper. Your stock bumper will still have the crush cans in front of the bolts on the frame. So you can't just bolt them through the stock bumper. (crush cans are about 4" deep)
Cole Ford
post #13 of 33 Old 12-12-2009, 03:00 PM
dirtyjpwrangler
ahhh I want it! but a/m bumpers are so expensive!!
dirtyjpwrangler is offline
post #14 of 33 Old 12-13-2009, 06:23 AM
BigRed09
2009 JK Wrangler
to the OP... this bumper has a nice design that went into detail here.... but if you're stuck on price, try the rancho bumper, it's in your price range and so is the warrior bumper
BigRed09 is offline
post #15 of 33 Old 12-13-2009, 07:28 AM
tcass
looking real nice....just added the link to my "Bumber" folder. Thanks for sharing.
tcass
tcass is offline
OME HK (Heavy Duty) Suspension Kit- Launch Time Without Heavy Bumper? hikerpaddler TJ Wrangler Technical Forum 8 03-11-2009 11:50 AM
Help install Heavy Duty Winch Mount Plate stevensinger TJ Wrangler Technical Forum 15 12-26-2007 11:51 AM
LoD Heavy Duty Rear Bumper & Tire Carrier -- Installed w/ Pics Trombino TJ Wrangler Technical Forum 23 09-13-2006 04:23 PM
TJ Heavy Duty bumper for 369??? Flendo TJ Wrangler Technical Forum 15 02-17-2005 06:22 PM
