Headrest removal for rear seats? - JeepForum.com
post #1 of 23 Old 01-21-2012, 05:37 PM Thread Starter
1222
RIP John
1222's Avatar
Does anyone know how to remove the rear seat headrests on the 2012? Iím assuming that itís the same for all years though. Iím trying to get a dog seat cover on and need to remove them. I tried using the wonderful search engine this forum has but keep coming up empty.
1222 is offline
post #2 of 23 Old 01-21-2012, 06:28 PM
JemLT1YJ
2011 JK Wrangler
Lol i was stuck on this too... Theres actually 2 buttons on each headrest that you have to push. The one button is hard to find/see but its there. Push them both and they pull right out. This is on a 2011...
JemLT1YJ is offline
post #3 of 23 Old 01-21-2012, 06:32 PM Thread Starter
1222
RIP John
1222's Avatar
Ok thanks. It is so hard to even get a peek inside the slit to see anything but now that I know there is actually something to do inside Iíll give it a harder try.
1222 is offline
post #4 of 23 Old 01-21-2012, 06:36 PM
JemLT1YJ
2011 JK Wrangler
Originally Posted by 1222
Ok thanks. It is so hard to even get a peek inside the slit to see anything but now that I know there is actually something to do inside I’ll give it a harder try.
Should have noted that the buttons are right by the headrest posts. Get to typing on this phone and touch screen i make so many mistakes and gotta retype stuff i leave stuff out the 6th time i type it lol
JemLT1YJ is offline
post #5 of 23 Old 01-22-2012, 11:48 AM
Greenway
You mean like this?
Working on a way to do it without taking the cover off now
2012 Unlimited Rubicon Cosmos Blue
The small things that you come across everyday, The norm that's overlooked until it is unseen, then when that comes you miss life, one thought, one smell, one sound can take you back home, then you realize your a thousand miles away, and then you get sick....
Greenway is offline
post #6 of 23 Old 01-22-2012, 12:15 PM
Greenway
I'm not gonna say it's easy. But it's not that hard to do. Reach under the headrest there are two little spring clips.
Push from the front on both at the same time. Pull headrest.
Then fold seat. ( Watch out for the posts from where the headrest was......) Take apart at the bottom and unclip the foam from the back of the seat. Push the cover under the seat, and put seat back upright. Pull the cover and foam from the front so that you can put your arm in ( not comfortable) and with a 5/16 gear wrench ( use a gear wrench please they r long bolts. ) reach all the way up and about 4 inches below the posts for the headrests are the two bolts. Take them out....(not fun) pull the headrest off and back down through the front of the seat. You have the unclip the wire from the bottom side where the fold and tumble thing is. Then fold the seat again and undo it from the back. And you have no more headrest in the way.
Greenway is offline
post #7 of 23 Old 01-22-2012, 12:21 PM
Greenway
Greenway is offline
post #8 of 23 Old 01-22-2012, 12:51 PM Thread Starter
1222
RIP John
1222's Avatar
Thank you Greenway for that write-up, very informative.
1222 is offline
post #9 of 23 Old 01-22-2012, 04:03 PM
Greenway
Welcome I been wanting them gone for a while figured today was the day. Plus I took the top off and road down to the beach seeing as it's over 80 here today
Greenway is offline
post #10 of 23 Old 01-22-2012, 06:17 PM Thread Starter
1222
RIP John
1222's Avatar
Originally Posted by Greenway View Post
...Plus I took the top off and road down to the beach seeing as it's over 80 here today
80, what the hell, do you live down by the equator or what?
1222 is offline
post #11 of 23 Old 01-22-2012, 06:33 PM
Greenway
I don't live here. I live in Georgia. But I'm in corpus Christi Texas for a couple more months
Greenway is offline
post #12 of 23 Old 01-23-2012, 05:22 AM
billy mo
billy mo's Avatar
Does this work for the pre-11 JKs?
'08 JK Unlimited Rubicon, Steel Blue Metallic, Auto, 33"s, 2.5" RE, 6" KC's, Drake Hood Latches
billy mo is offline
post #13 of 23 Old 01-23-2012, 06:33 AM
Greenway
I don't know mine is a 12
Greenway is offline
post #14 of 23 Old 01-23-2012, 07:01 AM
Joevacs
2010 JK Wrangler
an easier way to get them out of the way temporarily is to fold the seat flat, and then as you set the seat back to the upright position, hold the headrest back with your hand. Then get a bungee or rope, and tie it to the loop behind the seat. That keeps it out of your way and it's still useful if you have a passenger at a later date.
2010 Rubicon, 4" lift, Currie control arms and trackbar, 40" Procomp MTR
Joevacs is offline
post #15 of 23 Old 01-23-2012, 03:10 PM
Jollydodger
There is also a way where you can unclip the spring that raises the headrest from the folded down position. You can see it, I think on the right post when looking at it from the rear cargo area. It's black and you can unclip it with needle nose pliers and it's way better than the bungy thing. Ripping the whole thing out is better unless you fear whiplash.
Jollydodger is offline
rear seats with headrest? SkyLand TJ Wrangler Technical Forum 7 10-09-2014 08:53 PM
Removal of front seat headrest outhouseking JK Wrangler Technical Forum 4 09-27-2011 12:31 PM
Front Headrest Removal Seanbmc JK Wrangler Technical Forum 3 11-06-2010 02:42 PM
09 jk 4 door headrest removal shmelvin JK Wrangler Technical Forum 6 09-12-2009 04:29 PM
Rear Seat Headrest Removal Possible? jckid JK Wrangler Technical Forum 4 11-09-2006 05:15 PM
