Headlight Shootout - Page 15 - JeepForum.com
post #211 of 783 Old 09-19-2011, 07:42 PM
verdugan
Originally Posted by totdoc View Post
It sure would be sweet if they offered a drop in solution for the Jeep!
And if they could offer them within the next month when I'll get my 2012, it would be very much appreciated.
verdugan is offline
post #212 of 783 Old 09-23-2011, 03:51 PM
12JKU
1965 CJ3B
For all the 2012 owners that want to "attempt" this headlight upgrade mod, here is what I did...
Attn: this mod is not for the faint of heart OR the faint of pocket book!!!
As I mentioned in a previous post, the air bag sensors on the 2012's can no longer be rotated and to attempt this would be a serious modification to the air bag system. So what I did was to throw money at the problem and buy a headlamp kit that contains 3 pieces...chrome retainer ring, headlamp and the "outer" plastic ring that the headlamp attaches to. This outer ring is the same ring mentioned above that has to be enlarged to allow the JW Speaker light to fit. I know this sounds stupid to buy additional headlamps that you are not going to use, but the plastic ring is not sold by itself! Left side part # 55078149-ac & Right side part # 55078148-ac (this mod is getting out of hand, price wise)
I took the plastic ring from the kit and placed it in a vise and used a dremel to enlarge the opening so the JW Speaker light would fit. Using screws, I then attached the enlarged ring to the stock ring on the jeep. This created a "double stack" ring that gave the JW Speaker enough clearance with NO additional cutting to the stock jeep parts and NO adjusting the airbag sensor. Yes, the light will protrude out more than stock, but I don't think it is too noticeable and the grill still fits.
Last night when I was working on this "franken-light" project I didn't take any pics, because I didn't know if this hair brain idea would work. Now that I think it might, I'll take a few pics as I finish up the other side.
Also I am not expecting any thing less than a tough time when it comes to adjusting these lights with the "double stacked" rings. ***Edit - looks like the adjustment will not be as big of a problem as I thought. - ***
Stay tuned.
12JKU is offline
post #213 of 783 Old 09-23-2011, 04:15 PM
krutj
2009 JK Wrangler
I'm curious, could you have purchased the "frame" from say a '10 or earlier model for less $$? I don't know the cost, just wondering if it may be an option for this lighting upgrade....^^
-- Joel --
krutj is offline
post #214 of 783 Old 09-23-2011, 08:20 PM
verdugan
Thanks for the post. I think that might be too much for me.
verdugan is offline
post #215 of 783 Old 09-23-2011, 11:16 PM
totdoc
The 07-12 wranglers share the same part numbers for the buckets. I would think the cheapest way to get these would be to buy them from a junkyard from a wrecked jeep. There may be some other options here, too, if people are able to get creative...
For example - maybe washers could be used to extend out the stock mounting bolt positions, so that a redundant outer ring would not be necessary. Or perhaps a custom fit piece of plastic could be made with a blank sheet from a hobby store and an exacto knife to make your OWN ring to insert the light into. Or maybe the fins of the light itself could be trimmed down.
No matter what, I am very happy to see that someone is spearheading this install in the 2012's. I am really hoping to do this upgrade, too!
totdoc is offline
post #216 of 783 Old 09-24-2011, 08:41 AM
12JKU
1965 CJ3B
The JW Speaker lights were successfully installed in my 2012 JKU using the "double stack" method mentioned above here are some pics...
3pc Headlamp kit
Enlarged opening to fit JW Speaker light
"Double Stack" with painted black trim ring
I'm sure there are other options for fitting these JW speaker headlights in a 2012, but this worked for me, and did not have to cut any of the stock parts or mess with the airbag sensors.
12JKU is offline
post #217 of 783 Old 09-25-2011, 09:29 AM
krutj
2009 JK Wrangler
Looks great, nice job!!...^^
-- Joel --
krutj is offline
post #218 of 783 Old 09-26-2011, 07:58 AM
totdoc
Excellent work! Good choice on painting that trim ring black, too. It does protrude a little bit, now, but it still looks really good! Any trouble with the aiming?
totdoc is offline
post #219 of 783 Old 09-26-2011, 10:14 AM Thread Starter
Hilldweller
2014 JK Wrangler
Stay tuned.
Good job.
When I first installed the 8700s, I spoke with them about providing a shim of this type in a "kit" along with a pigtail with the diodes and capicitors included. They thought it was a good idea but never went anywhere with it.
I'm glad you did it and proved that the idea had merit.
Safety fast,
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing.- Helen Keller
Hilldweller is offline
post #220 of 783 Old 09-26-2011, 10:20 AM Thread Starter
Hilldweller
2014 JK Wrangler
Originally Posted by Dead_Nuts View Post
LEDs are very tempting, but emitter 'color temp' with associated CRI would be key to me adopting them. I have extensive experience with LED flashlights (and flashlights in general) and know what a difference color can make. Cooler tints create more glare, while warmer colors (don't take this statement to the extreme, of course) tend to allow better color rendition -- which can be key to object identification and real-time decision making. I've actually seen and experienced this with tactical weapon-mounted lights.
More light is not always better.
Don't get me wrong, I'm not saying anything about any particular product; as I've not seen them in person. I am also not going to say the price is too high. After all, my Marchal's, wiring harness and bulbs were not exactly cheap (especially since I bought Cibie's first). In fact, I believe LEDs are the future of automotive lighting.
I would love to see a set of good LEDs next to a set of Marchals with Osram 70/65 (I know you can get brighter, but they aren't street legal) bulbs. But I would want the lit up scene to have greens and browns and blues in it.
I almost got the Marchals but opted for Z-Beams instead.
Compared with HIDs, the CRI on the 8700s is much better ----- signed, Mr Subjective...
I can't stand HIDs headlights for this reason and tinted the lenses on my HID offroad lights to selective yellow. But the claimed 5000K of the LEDs didn't bother me.
I'd rather it was 3800-4000K though.
Safety fast,
post #221 of 783 Old 10-23-2011, 10:28 PM
gspam1
Originally Posted by mabar View Post
A few months ago, I installed Philips X-Treme, H13 bulbs in my 2011, JK Factory reflectors. It did make a good improvement over the factory bulbs, but....
A couple of days ago, I installed the Hella, E-code reflectors, with Philips X-Treme, H4 bulbs, with their plug-and-play, wiring harness. Purchased from rallylights.com
Wow! What a HUGE difference over the factory reflectors, even with Philips X-Treme, H13 bulbs!
The Hellas are much, much brighter, with a much better light pattern.
HUGE improvement!
Hella Reflector kit with wiring harness
Mabar
How many hours to install this kit? Does it come with decent instructions?
Thanks!
gspam1 is offline
post #222 of 783 Old 10-24-2011, 09:07 AM
krutj
2009 JK Wrangler
Thanks!
I installed mine in an hour on X-mas eve. out in the snow....
Here's some pics to look at...http://www.jeepforum.com/forum/f96/r...stall-1145472/
-- Joel --
krutj is offline
post #223 of 783 Old 10-24-2011, 09:42 AM
Tacman
That's a pretty good "kit" that was provided. I'm impressed with their plug-n-play approach.
Having purchased the Marchals, built harnesses and added in relays all by myself I can tell you it took about 5 hours to come up with basically the same thing.
As far as I'm concerned that price is excellent considering the price of all the components, etc. !
Tacman is offline
post #224 of 783 Old 10-24-2011, 04:23 PM
UnlimitedBry
2011 JK Wrangler
HUGE improvement!
Mabar
Ive been torn on which set up to install but I think im going with this guy Speakers and LEDs are out of budget anyway
UnlimitedBry is offline
post #225 of 783 Old 10-24-2011, 10:48 PM
gspam1
Awesome, thank you very much! Great write up and pics.
gspam1 is offline
kc headlight southernss TJ Wrangler Technical Forum 10 02-05-2011 03:41 PM
Will this headlight fit? kunzcl TJ Wrangler Technical Forum 6 04-26-2010 03:31 PM
Flex shootout, LGC Vs regular lift never monday TJ Wrangler Technical Forum 133 03-17-2009 03:25 PM
Intake Shootout victory red TJ Wrangler Technical Forum 15 02-24-2008 10:00 PM
Headlight ON then OFF JeepDrivr93 YJ Wrangler Technical Forum 4 10-17-2004 11:27 AM
