Head Unit Swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Head Unit Swap
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Solution to Radius Arm Bind - Meet Lock-N-LoadFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 09-22-2014, 03:31 PM   #1
o6unlimited
Head Unit Swap
I was looking for some info before I do a bunch of work for nothing.
I have a 2012 JK Sahara with Nav and a 2013 JK Sport. I want to swap head unit. Sounds like its doable if you get the right CAN BUS but does the Sahara have a amp that I will need to swap?
Any help would get great. Thanks!
o6unlimited is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 11:41 PM   #2
outbackfarmer
I cannot answer your specific questions, but I can tell you this. I have a 2013 Freedom Edition that did not have factory nav, but had u-connect. My dad had a 2012 Dodge Laramie that had Nav, that was totaled in a storm. I pulled his Nav and put it in my Jeep and put my CD/Radio in his totaled truck. I had to contact the dealer and get the theft codes for both units, but both were plug an play and worked flawless after I entered the theft code. Even the start up screen that said RAM in the pickup, as soon as I put it in the jeep the start up screen said JEEP. The U-connect would not work in the jeep. I had to do some research and found there was a wire I needed to make this work. It was 50 or so dollars, and once I plugged it in the u-connect worked too. I was literately a 20-30 minute job.
2013 JK Unlimited Freedom Edition mods underway! / 1998 Wrangler 4.0 Auto 4" Lift ProComp 33's / 2006 Z06 Corvette Supercharged Le Mans Blue / 2010 ZR1 Corvette Blade Silver 710HP Lingenfilter / DD 2011 Longhorn Mega Ram 4X4 / DD 2012 Tahoe LTZ 4X4
outbackfarmer is offline   Reply With Quote Quick reply to this message
Unread 09-25-2014, 03:23 PM   #3
o6unlimited
Thank you! Everything works perfect but as you said I needed the code from the dealer.
