Hawaii Recon Inspection - JeepForum.com
post #1 of 6 Old 11-02-2013, 02:25 PM Thread Starter
jeepfan30
2014 JK Wrangler
Hi guys,
I just made the switch from the Grand Cherokee side of the house to the JKU side....couldn't be happier! I picked up a 2014 Sport with 3" lift and 35's.
I am in the Army and moving to Hawaii next month, I have been doing some research and will not pass the Recon inspections with the current configuration. My front and rear tires stick outside the wheel wells about 2 inches, I was wondering is someone with a similar setup could give me some advise for this inspection? Will Bushwacker flat top flares cover my tires, I need 8" coverage for rear and 11.5" for front?
Do the fronts tires need to be covered, or just the rear?
If the Bushwacker flares don't cover I'll either have to find a stock set of wheels arms tire to put on for inspection day, then take them off afterwards, or use the Home Depot garden trim trick.
I really appreciate any advise, especially from someone who has dealt with this first hand. Glad to be a part of the forum, looking forward to learning and sharing. Thanks,
3" EVO Enforcer, Fox 2.0 Shocks, 4.56 w/Truetracs, Coast F&R DS, 35" Toyo M/T, Warn Zeon 10-S
jeepfan30 is offline
post #2 of 6 Old 11-03-2013, 05:38 AM
Waltjason
2011 JK Wrangler
I just pcsd from Hawaii. During my time there I had an 08 JKU 4" lift and 35"tires. To get the recon this is what you will need. A current alignment showing that the vehicle is within spec. You will need mud flaps on the rear tires. My tires stuck out about 1/2" from the fender flares. All I did was purchase some landscaping black plastic trim temporarily attached it to the underside of the flares. Here is the deal once you get your recon sticker it is good for life and you will not need to go get it inspected again. So once you get the sticker I took all that stuff off just like everyone else does there. The Honolulu police(HPD) only police on the island will not pull you over once you have the sticker and that's why everyone takes the mud flaps etc off because they look stupid. But every year you will need to get a safety inspection which consists of insurance cards,lights working,wipers work etc. You will not be able to get a safety until you have they recon. All the recon does is say the vehicle was modified properly. There is only on shop in Honolulu that does it and if I remember right they only do it three times a week. Don't get scared about it like all the other SM's do there it was very easy. I went one day with my jeep and asked them to look at it and tell me what they wanted. They are the ones that suggested the garden plastic on fenders then remove it once I pass. Enjoy the islands I was lucky enough to extend there and did a 9 year tour of course deployments so ended up maybe 6 years there. They have some awesome off-roading there to. Good luck
Waltjason is offline
post #3 of 6 Old 11-03-2013, 08:49 AM Thread Starter
jeepfan30
2014 JK Wrangler
Thanks! I feel much better after hearing from someone with a similar setup to mine that has first hand knowledge. How long do I have to get the inspection done after my Jeep arrives? Thanks again!
post #4 of 6 Old 11-03-2013, 02:24 PM
Waltjason
2011 JK Wrangler
When I was there you had either 60 or 90 days. Can't remember but it was enough time.
post #5 of 6 Old 11-22-2013, 10:36 AM
BlackRUB1C0N
2010 JK Wrangler
Good thing I came across this... I'm PCSing to Pearl Harbor and had no idea about the sticker or inspection (thanks TMO...) I assume I can Google the requirements?
BlackRUB1C0N is offline
post #6 of 6 Old 11-22-2013, 11:18 AM
fratis
fratis's Avatar
Go away its too crouded as it is.
Here's a resource for you:
Oahujeepers.com
The Mudd flap thing is relatively new and after reading the (circa 1980) regulations I believe the super intelligent inspectors are missinterpreting their own literature.
If you work on base go early.
Have an open mind to other people and their culture.
fratis is offline
