Having problems with Skyjacker lift on Unlimited X - JeepForum.com
post #1 of 18 Old 03-19-2007, 12:07 PM Thread Starter
PhotographyLove
I have just had a Skyjacker 4" lift installled on my new Unlimited X and I am having extreme problems. When I hit a pothole at about 50 the front end starts bouncing violently and once I stop and start going again I am good until the next pothole. The pothole has to be pretty big and it is mostly spuratic. The problem is it is dangerous and I can't figure it out. I have taken it back to the shop that did the Skyjacker lift and everything seems ok and tight but I was wondering if any one else has had simular problems or what I should do... I am considering taking it back to the shop and having them put the stock suspension back on.
thanks
PhotographyLove is offline
post #2 of 18 Old 03-19-2007, 12:10 PM
billy mo
billy mo's Avatar
Sounds like a case of the death wobbles. Did you have it aligned after the lift was installed?
'08 JK Unlimited Rubicon, Steel Blue Metallic, Auto, 33"s, 2.5" RE, 6" KC's, Drake Hood Latches
billy mo is offline
post #3 of 18 Old 03-19-2007, 12:30 PM Thread Starter
PhotographyLove
I talked with the shop owner about itand he said it was not needed. Yes it is a death wobble.
post #4 of 18 Old 03-19-2007, 12:31 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Depending on the size of tires you put onto your Jeep, you might wish to run a dual high-rate steering stabilizer. That has been a fix for alot of other Jeeps before this, and it worked on my YJ when I had that problem.
You might also wish to use Rancho adjustable shocks with In-Cab controller - play with the settings from 1 to 9 till you find a rate that controls the shakes.
Another thing to check - are all the bolts torqued to specifications, any play in the mounts at all?
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #5 of 18 Old 03-19-2007, 12:42 PM Thread Starter
PhotographyLove
One thing that happened was one of the bolts for the sway bars had fallen out but I suspect it was the effect of one of my death wobbles as opposed to the cause. Thank you for the help. After the bolt was replaced everything was good for a week and then it started again.
post #6 of 18 Old 03-19-2007, 12:47 PM
Prot
Prot's Avatar
2014 JK Wrangler
Jack up each wheel and loosen the lug nuts, shake the wheel, and reseat them against the spindle and slowly tighten each nut in the appropriate pattern. If the wheels are not hub centric, it could be caused by the wheel not being centered up properly so what I just mentioned should take care of it. Re-alignment not necessary? Sounds like you need to go to a different shop. The larger the lift, the more necessary the allignment is. From the factory, the allignment is not adjustment which is why the shop may have said what they said. After altering the suspension, the allignment will have to be checked and adjusted. On some of the more complete lift kits, such as from Black Diamond, a camber/caster adjustment kit is included that allows the allignment to be adjusted. On my 2000 F150, the allignment was not adjustable from the factory but I recently had to get a camber kit for it so it could be adjusted, and my truck does not have a lift kit or anything. Hope that helps.
Prot is offline
post #7 of 18 Old 03-19-2007, 01:37 PM
apollo111
I have the same lift on my 2 door,and had similar problems as yours.I added a skyjacker HD steering damper(stock damper is POS),and changed upper sway bar link bolts for longer ones and double nutted them.This solved 90% of wobble.Still a very light wobble sometimes at about 60 to 70 kmh.I could probably use a dual steering stabilizer as NaeKid suggests.Hope this helps.
apollo111 is offline
post #8 of 18 Old 03-19-2007, 02:24 PM
bonedigger
you probably need to get your caster adjusted.
bonedigger is offline
post #9 of 18 Old 03-20-2007, 07:00 AM Thread Starter
PhotographyLove
Bonedigger
The shop called Skyjacker and they suggested adjusting the caster to the max so we are trying that today.
Apollo
After the sway bar bolt fell out I put in a longer bolt with the ny-lock nut on it but never thought to double nut it. I am interested that you still have wobble. I have found that with the Skyjacker lift the drive went from very stable due to the 4 door to almost sloppy. It now feels like the rear end is trying to pass me all the time. Are you having the same feel with the 2 door?
post #10 of 18 Old 03-20-2007, 07:08 AM
stathunter
what shocks are you running?
Scott
2004 Black X w/ RE LA 37" SSR's, etc etc
In Michigan? Call Jim from
"Do or do not, there is no try" Yoda
stathunter is offline
post #11 of 18 Old 03-20-2007, 07:31 AM Thread Starter
PhotographyLove
We went with the Skyjacker hydro shocks that came witht he lift kit
post #12 of 18 Old 03-20-2007, 02:13 PM
apollo111
My 2 door feels a bit less stable than stock,nothing major.I think this is mostly due to the larger tires.I'm runnin mickey thompson 315 75 r16's on 16x8 rim.
It was also suggested to me to adjust caster,but havent done it yet.Curious to know if it helps you.
post #13 of 18 Old 03-20-2007, 05:53 PM
Prot
Prot's Avatar
2014 JK Wrangler
There is a reason why some manufacturers include a caster/camber kit..........
Prot is offline
post #14 of 18 Old 03-20-2007, 08:55 PM
billy mo
billy mo's Avatar
I'm still trying to adjust my SkyJacker kit. When I hit the gas, it pushes to the left. Let off the gas, it pulls to the right. Are you having a similar issue when you say that you feel like the rear is trying to pass you?
billy mo is offline
post #15 of 18 Old 03-20-2007, 09:01 PM
igofshn
Locked @ both ends
igofshn's Avatar
Do you have an automatic locker in the rear?
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
2.5''skyjacker, will there be any problems? Jeepkid09 TJ Wrangler Technical Forum 2 06-27-2008 11:10 PM
Problems with my Skyjacker 2" BB sporticon03 TJ Wrangler Technical Forum 1 06-13-2008 03:47 PM
problems with skyjacker? rinterr TJ Wrangler Technical Forum 20 07-03-2006 07:47 PM
Unlimited springs give 1" lift on non-unlimited? loudog3114 TJ Wrangler Technical Forum 2 07-01-2005 08:24 AM
Unlimited....Who has had problems? BIGNUTT TJ Wrangler Technical Forum 19 06-12-2005 01:36 PM
