Hardtop Insulation - JeepForum.com
post #1 of 8 Old 09-02-2010, 03:30 PM Thread Starter
taoshum
Hardtop Insulation
Heaven only knows why the Jeep Designers decided to paint the hardtops BLACK with no insulation. They are very, very effective radiant heaters when the sun is out. So effective, in fact, that the A/C cannot begin to keep up... so I put in some insulation. Thought I'd share the approach:
materials: 3/16" foam core 4'X8'; 1/8" foil insulation from hardware store 4' X 8'; 3M spray on adhesive; velcro adhesive backed.
* cut a panel for each of the front hardtop sections from the foam core board
* taper the edge
* cut a corresponding piece of the foil insulation about 3/4" smaller than the foam core board
* clean surfaces with alcohol
* spray the 3M adhesive on the foil, make sure to use the correct side...
* join the foil to the foam core, let it cure for 45 minutes
* clean again with alcohol and clean the inside of the hardtop
* put velcro on foil in spots where it will adhere to the lowest rib of the hardtop
* press the assembly in place... easier for the front hardtop sections
* cut the back hard top foam core board into two pieces... down the middle works since you cannot install without removing the hard top completely
* repeat for the rear section of the hardtop
* get some white tape to cover the joint if desired.
* enjoy...
hardtopInsul (1).JPG   hardtopInsul (2).JPG   hardtopInsul (3).JPG   hardtopInsul (4).JPG   hardtopInsul (10).JPG
Geezer from NM
"Wisdom isn't cheap; we pay for it with pain
taoshum is offline
post #2 of 8 Old 09-02-2010, 03:42 PM
mickeymeanie
2011 JK Wrangler
Great idea... looks like a project for me once our Jeep arrives!
Wonder how well the Velcro will hold up once it sits in the heat for a while... those panels you made can't weigh much, so it may be alright. Probably would become a problem if you added any sort of fabric cover which would be added weight.
Thanks for posting this!
I have to wonder if the inside of the 2011 top will be white as well... we are getting the painted top on the Sahara... not likely the interior is painted would be my guess.
mickeymeanie is offline
post #3 of 8 Old 09-02-2010, 03:55 PM Thread Starter
taoshum
I'll post again if they fall off... so far so good. Interior is white on this one so the white foam core board is a pretty good match, colorwise. With velcro, I can add paint or fabric later if needed but it would be more weight...
Geezer from NM
taoshum is offline
post #4 of 8 Old 09-02-2010, 09:53 PM
WolfgangGullich
2010 JK Wrangler
Does this deaden noise from outside at all too?
'10 JK Wrangler Sport Unlimited | Surf Blue
'12 MINI Countryman Cooper S All4 | True Blue/Chili Red JCW Appearance Pack
WolfgangGullich is offline
post #5 of 8 Old 09-02-2010, 11:58 PM Thread Starter
taoshum
I've only had this installed for 24 hours and haven't had much time to drive around but my initial impression is that "yes", it seems little quieter and it is definitely cooler and the a/c doesn't have to work as much. I had the fan on low and was comfortable where as before, I had the fan on high and it could not keep up.
I'm happy so far and my DW even says that it looks like the "factory" installed it. I don't know about that but it's ok. I think the foil really reflects the heat away from the interior.
Geezer from NM
taoshum is offline
post #6 of 8 Old 09-25-2010, 09:34 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Thanks to Taoshum's DIY project, I finally started on mine. Mike, who owns a four door JK loaned me his hard top front pieces for me to fabricate the insulation. I like the flexibility of having extra pair of hard top panels so I can work inside the house (still tooo hot outside).
I chose 1/2" form insulation from Home Depot.
Here, I am making a pattern using vanilla folders:
Tracing the pattern before cutting:
Insulation has been cut and fitted to roof top panels:
Next step would be to go get foil insulation from lowes tomorrow. I gotta do something about the pink color. I will either glue on roof headliner material or put some white paint on the bottom side...
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline
post #7 of 8 Old 09-25-2010, 10:32 PM
DenverDan78
Junior Member
Or you could get a more powerful AC
DenverDan78 is offline
post #8 of 8 Old 09-25-2010, 11:46 PM
Thunderstrike
2009 JK Wrangler
No, gotta insulate. The hot radiating heat from hard/soft top will put you to sleep on a long drive to Moab.
4x4 Trips:
Ouray - 8/2007
Rubicon - 9/2008
diy , hard top , insulation , JK Wrangler , wrangler
Hardtop insulation ideas for Canadian winters? VanBCguy TJ Wrangler Technical Forum 34 02-04-2013 10:43 PM
hardtop insulation CreepyCrawler95 YJ Wrangler Technical Forum 8 01-04-2010 09:58 AM
Hardtop insulation fowlball TJ Wrangler Technical Forum 2 02-26-2008 02:37 PM
hardtop headliners/Insulation wdyman TJ Wrangler Technical Forum 7 02-05-2006 02:06 PM
Hood insulation helter YJ Wrangler Technical Forum 3 06-11-2001 05:51 AM
