hard top removal - JeepForum.com
post #1 of 15 Old 02-28-2007, 11:09 PM Thread Starter
studdboyz75
hard top removal
has anyone removed their hard top yet?
if so how heavy is it? can me and wifey handle it or do I have to buy my buddies beer to come help everytime I take it off ?
I've owned two yj's but both were soft tops.
would a hoist be money well spent?
I saw some quick disconnect type handles that replace the nuts and bolts that seems to make better sense than jumping in the back with a drill evrytime.
studdboyz75 is offline
post #2 of 15 Old 03-01-2007, 12:13 AM
jeepers3
It is easy. Your and your wife can do it just fine. Money on a hoist is a waste if you ask me.
Make sure you get yourself a T40 and T30 bit for a ratchet, and an extender, and you will be fine.
jeepers3 is offline
post #3 of 15 Old 03-01-2007, 05:39 AM
redrom01
JCOB-4-LIFE
redrom01's Avatar
I'll second that. It's not to bad to handle. Though if you bought the dual top then this is where the extender for you ratchet will come in very handy, trust me.
-Jeep History-
1992 XJ - '00 till '04 - RIP (thanks alot dave)
1995 XJ - '03 till '07 - Sold to the HUB
______o00o
/__l_l_,\____\,__
l_---l_l__l----[ ]llllll[ ]
._(o)_)__(o)_)--o-)_)__
-Current Jeep-
2007 JK Rubi (Steel Blue)
Searching for an MJ
|¯¯l,[___],
l---L--OlllllllO¬
=~~~==oo==
()_) ()_)--<>-)_)
redrom01 is offline
post #4 of 15 Old 03-01-2007, 06:30 AM
infosponge
infosponge's Avatar
I made a cheap lift out of ratchet straps and that made it a snap to get the hard top on and off and stowed in the garage.
infosponge is offline
post #5 of 15 Old 03-01-2007, 06:44 AM
YlwColumbia
YlwColumbia's Avatar
Agreed! (And what redrom01 said...)
2007 Wrangler Unlimited X - Red Rock Crystal Pearl Coat
YlwColumbia is offline
post #6 of 15 Old 03-01-2007, 06:57 AM
FLSeaMonkey
My wife and I did it. Not too bad, but a little scary. I lifted the back and she took the front. We had a neighbor help us put it back on. 2 is doable, 3 makes it much easier.
'07 Wrangler Unlimited Sahara Rescue Green
'94 Land Rover Defender 90
'64 Porsche 356C
FLSeaMonkey is offline
post #7 of 15 Old 03-01-2007, 07:23 AM
JeF4y
3 is a breeze... I removed/installed mine with my 2 kids 12/15...
07 Wrangler Unlimted Sahara 4dr 4x4
05 Liberty CRD 4x4 (gone!!! 3/23/07) - When Jeep gives you lemons....
JeF4y is offline
post #8 of 15 Old 03-01-2007, 08:42 AM
boidy7
put mine back on last night with my girlfriend and had everything on and tightened in about 20 min. not bad, little strange with the grip but nothing too bad
boidy7 is offline
post #9 of 15 Old 03-01-2007, 10:18 AM
strykermp5
disconnect the bolts that lock it on the the body... get inside the back... push up and toward the rear of the vehicle... throw in trash... replace with soft top!
j/k
my YJ has both the hard and soft top... hard top is a ***** to remove, but is quieter and warmer in the winter. mine weighs about 85-100 lbs
Jeep Green, Black Cragars, Black Windows
Optional Equipment:
M4 (x2)
Sig 226
strykermp5 is offline
post #10 of 15 Old 03-01-2007, 12:47 PM
sdebol
2010 JK Wrangler
What are the storage options if you don't use a hoist? Can you just stand it on end in the garage?--or do you at least have to use one of those dollys or other type of stand?...
sdebol is offline
post #11 of 15 Old 03-01-2007, 12:58 PM
strykermp5
i would not recommend standing it up... b/c it is heavy for one and the fiberglass chips easily
i would lay it flat (not on the top) on a blanket or hoist it up...
Optional Equipment:
M4 (x2)
Sig 226
post #12 of 15 Old 03-01-2007, 02:26 PM
jeepers3
I plan to just put it in the back yard with a tarp over it. No room in my 1 car garage, that's for sure.
jeepers3 is offline
post #13 of 15 Old 03-01-2007, 02:36 PM
YlwColumbia
How high is your garage ceiling? I don't use a hoist. I built a shelf/platform with 2x4's and plywood and lag-bolted it into the ceiling studs. Twice a year I swap out the hard top to the soft top, etc.
http://www.imagestation.com/6259975/4165811230
post #14 of 15 Old 03-01-2007, 02:59 PM
sdebol
2010 JK Wrangler
Nice picture--that would work for me. Do you remember how low it hangs from the ceiling?
Anyone use the Mopar dolly that holds the top and doors?
Thanks,
Steve
sdebol is offline
post #15 of 15 Old 03-01-2007, 03:04 PM
YlwColumbia
Thanks,
Steve
Off the top of my head, I don't remember. I cut the lengths of the 2x4's hanging down from the ceiling to be about 6" longer than the height of my Hard Top. Cost of materials for the whole thing was about $60.
Hard Top Removal mercier YJ Wrangler Technical Forum 10 07-13-2009 03:25 PM
Hard top removal. Deadhorse TJ Wrangler Technical Forum 20 04-25-2009 04:34 PM
hard top removal GIJoe Driver JK Wrangler Technical Forum 1 04-09-2007 07:09 PM
hard top removal TexasPete TJ Wrangler Technical Forum 6 03-14-2006 10:23 PM
Hard Top Removal Inukshuk YJ Wrangler Technical Forum 4 02-09-2004 12:04 AM
