Hard Idle/Vibration at Stops - JeepForum.com
post #1 of 6 Old 04-21-2013, 05:45 PM Thread Starter
TornadoBob
Hi everyone, first time poster seeking opinions.
I have 2012 Wrangler Sport with 9000 miles. After it gets warm, when stopped at a light in drive it seems to idle very hard and send a vibration through the steering wheel and center console. Not so much that you can visibly see it shake, but you can really feel it.
I've had it in for service (along with a drivers side tick, but that's another topic) and the dealer insists that since their no CEG on that it's normal. I had TJ a few years back but don't recall this phenomenon.
So my question is, how much idle vibration through the steering wheel or elsewhere is considered "normal"?
Any help or info is greatly appreciated. Thanks.
TornadoBob is offline
post #2 of 6 Old 04-21-2013, 07:05 PM
222Doc
222Doc's Avatar
could be the bad head. But until it tosses a cel of miss fire. they may not want to dig that deep. Not that this is going to help you. There was post a post where a guy logged the data on fuel and its effect. 87/89/91 The motor is pulling timing on 87. I know ours on 87 can even get into knock. 89 shows a gain of MPG better timing. 91 no gain.
I know i will get flamed on this. I have used it before and even tested it to failur once. In a 20R yota. Ran it with no water until it melted down on a freeway made it 60 miles no water two miles from home . melted at the valve seats and every part that could melt did, all most caught fire. But the block still looked fine the piston walls were fine! we went to a Junk yard and replaced the head and all the wires plastic parts... It ran like a clock for many years after..... Slick 50.
Our 012 runs well and though it has a slight tick its not as bad as others I have heard. it has about 17K on the clock. a slight vib at idle but not much. Just put slick 50 and the thing sounds100% better. i am not amazed as I have used this stuff 30 years. even at cold start it has no sound of needing to pump up.
let the flaming start...
222Doc is offline
post #3 of 6 Old 04-21-2013, 07:11 PM
GPV
Is it a standard transmission. If it is put the transmission in neutral and see if the vibration stops when the clutch is let out.
Good luck!
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
post #4 of 6 Old 04-21-2013, 07:34 PM Thread Starter
TornadoBob
Hey guys, thanks for the replies.
I should have mentioned it's an automatic. The vibrations are mostly felt stopped in drive. In park/neutral it's a bit less. I've been filling up with Mobil/Shell 87.
I just had my second oil change about two weeks ago.
post #5 of 6 Old 04-21-2013, 08:12 PM
JTPhoto
JTPhoto's Avatar
http://www.skepdic.com/slick50.html
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #6 of 6 Old 04-23-2013, 08:12 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
From the 2012 JK Owner Manual:
"Materials Added To Fuel
All gasoline sold in the United States is required to
contain effective detergent additives. Use of additional
detergents or other additives are not needed under
normal conditions and would result in additional cost.
Therefore you should not have to add anything to the
fuel."
JeepCares is online now
