Hacking the CAN-Interior Bus - Page 4 - JeepForum.com
post #46 of 58 Old 05-24-2014, 11:42 AM
fastfreddie
Make it so that ALL the nanny-state features(ABS, ESC, etc.) can be disabled and I'll send you a blank check.
fastfreddie is offline
post #47 of 58 Old 07-03-2014, 12:11 PM
RawLiquid
Exactly what I've been looking for!
I've been searching for this info since I bought my JKU, and moreso since I put in all LED bulbs.
It seems to me that the 'fast flash' for the turn signals may be software controlled, and if so I'd like to cancel that message out somehow as all my bulbs are just fine...
What leads me to believe this is if I hit the hazard button, the flash rate goes back to normal.
Additionally, I've had several occasions where while driving, it has gotten reset...
It takes 3 blinks of the turn signal before it activates, and when the reset occurs, the rate goes to normal for 3 cycles.
I don't suppose you have any info on this? I have not yet re-opened my dash to connect via the radio connection, but will be doing so at the latest this weekend.
Any insight would be most appreciated.
Nathan
RawLiquid is offline
post #48 of 58 Old 07-03-2014, 12:30 PM
YATZI1980
2011 JK Wrangler
Nathan
Install a resistor for your led lights. The quick flash happens when you burn out a lamp. Because led draws much less power your jeep thinks you have a bulb burned out. Any good led light kit will come with a built in resistor to compensate for this. Same thing with head light flicker on led bulbs. It's the can us sending a signal to check status of the bulb.
YATZI1980 is offline
post #49 of 58 Old 07-05-2014, 09:56 PM
RawLiquid
I do understand that is the generally accepted explanation of what's going on. And I have done quite a bit of searching on the subject as well as my own tests, and while I am sure that statement was true, I also believe that the game has changed significantly.
I realize that I may very well end up at that very conclusion, but until I have proven that to myself I will continue reading and looking.
Some of the reasons I believe the flash rate is software controlled and subject to alteration is that with all led bulbs, each side fast flashes.Hazards do not...
I also wired up some leds that drew around the same amount of power as the incandescent, wit the same result.
I do thank you for taking the time to respond though, especially to the fact that it was a real answer as many times by the time I go to the web for things, they are so buried in people saying to go search for it or link after link you have to be a detective to get anywhere.
post #50 of 58 Old 07-06-2014, 05:40 PM
YATZI1980
2011 JK Wrangler
You're right there is definitely programming in the software. Maybe the hazards don't flash quickly because of the tail lights being involved in that circuit? I'm better with wiring than programming so the easy fix for me is adding a resistor. Anyway you look at it the software monitors the circuit through resistance. Good luck though I'm interested to see if you find something.
post #51 of 58 Old 11-22-2014, 06:13 PM Thread Starter
dcgibbons
2014 JK Wrangler
Still working on this, and making progress... despite the prodigious lack of free time!
dcgibbons is offline
post #52 of 58 Old 06-30-2015, 05:48 AM
jeepwrnglr92
2015 JK Wrangler
Interesting. Nice work.
2015 Jeep Wrangler JKU "Tank" Sport S
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline
post #53 of 58 Old 02-01-2016, 12:53 PM Thread Starter
dcgibbons
2014 JK Wrangler
Another milestone today... development board arrived! This is to prove out some electrical characteristics and software in-vehicle, before making a final board design.
post #54 of 58 Old 09-12-2016, 03:56 PM
JustinS-IA
2006 XK Commander
This is pretty interesting stuff, any updates?
JustinS-IA is offline
post #55 of 58 Old 09-13-2016, 09:17 AM Thread Starter
dcgibbons
2014 JK Wrangler
Lots of updates; nothing too recently has day job has gotten in the way. I post more on some other forums and my blog.
post #56 of 58 Old 09-13-2016, 11:52 AM
lloydsmale
2015 JK Wrangler
and then you have me. I can barely figure out how to make the radio work!!
2015willys 4 cyl tj 2017 silverado yamaha grizzly, Polaris rzr 04 z06 vette, 600/800 crossfire cat
lloydsmale is offline
post #57 of 58 Old 09-13-2016, 03:18 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Easy.
Buy the grandkids a six pack of soda and turn em loose.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #58 of 58 Old 09-14-2016, 03:09 AM
lloydsmale
2015 JK Wrangler
that's about it!
Originally Posted by jwmbishop View Post
Easy.
accessories , electrical , hack
