Hacking the CAN-Interior Bus - Page 2 - JeepForum.com
post #16 of 58 Old 01-02-2014, 04:26 PM
spinlock
Originally Posted by dcgibbons View Post
You know what's annoying - I'm far from the first person to be looking at this data, but there seems to be a mindset of not sharing this information so everyone has to re-discover.
A lot of aftermarket-producs, from tuners to radio interfaces, have done effectively the same thing.
That is because they can gain monetarily from that information and they don't want to enable their competitors. Jeep probably makes at least some of that information available under NDA so that aftermarket manufacturer can build and integrate their products. However, making it available to the general public could lead to a flood of service calls from misuse. The real value of that data is not reading it, it's changing it. From a desktop operating system perspective look at like Windows not Linux.
spinlock is offline
post #17 of 58 Old 01-02-2014, 05:56 PM
jorhay
Awesome. Keep at it man, and good luck!
jorhay is offline
post #18 of 58 Old 01-04-2014, 06:59 PM Thread Starter
dcgibbons
2014 JK Wrangler
I finally found the "power-on" message, so you can bench test a OEM radio:
Code:
20b#6100
to turn it on, and
Code:
20b#0000
to turn it off. The car broadcasts the on message about every 100ms to keep the listening nodes alive, so on a bench you'll need to send it frequently.
dcgibbons is offline
post #19 of 58 Old 01-04-2014, 07:33 PM Thread Starter
dcgibbons
2014 JK Wrangler
And here's a good example of the limitations of interfacing with the bus, which is mostly limited to listening to system changes.
Message id 308 is sent out when the interior dimmer is changed. I've seen the following data so far:
308#0000ff # lights off
308#110000 # daytime - lights on bright
308#122200 # lowest dimmer setting
308#124c00 # next highest
308#12a000 # next highest
308#12c800 # all the way up
It is tempting to want to send your own messages to the bus to have these settings take place, but it doesn't quite work that way.
These messages are generated by the Cab Compartment Node (CCN) whenever it detects changes from the user by using the control stalk. Those messages are listened to by the radio and the TIPM nodes who take action as appropriate - such as dimming the radio lights.
The problem is, the CCN isn't listening for those messages even though it controls a large portion of the lights that are being dimmed. Additionally, it keeps broadcasting the current dimming state every 500ms, so it will override any commands you may send out yourself.
post #20 of 58 Old 01-06-2014, 02:41 PM Thread Starter
dcgibbons
2014 JK Wrangler
Huh, this is interesting. Something blasts out detailed information on song, artist, and album when playing from the USB interface (iPhone) and the radio displays it.
Code:
 (1389040747.468564)  vcan0  3AC   [8]  0B 01 20 20 20 20 20 20   '..      '
 (1389040747.497350)  vcan0  3AC   [8]  1B 03 20 4E 6F 20 49 6E   '.. No In'
 (1389040747.528932)  vcan0  3AC   [8]  03 03 66 6F 20 20 20 20   '..fo    '
 (1389040747.564518)  vcan0  3AC   [8]  3B 04 20 47 69 76 69 6E   ';. Givin'
 (1389040747.597491)  vcan0  3AC   [8]  23 04 27 20 59 6F 75 72   '#.' Your'
 (1389040747.633804)  vcan0  3AC   [8]  13 04 73 65 6C 66 20 41   '..self A'
 (1389040747.667984)  vcan0  3AC   [8]  03 04 77 61 79 20 20 20   '..way   '
 (1389040747.700881)  vcan0  3AC   [8]  0B 05 20 52 61 74 74 20   '.. Ratt '
 (1389040747.736770)  vcan0  3AC   [8]  1B 06 20 44 65 74 6F 6E   '.. Deton'
 (1389040747.760179)  vcan0  3AC   [8]  03 06 61 74 6F 72 20 20   '..ator  '
 (1389040747.794957)  vcan0  3AC   [8]  1B 07 20 4E 6F 20 49 6E   '.. No In'
 (1389040747.826042)  vcan0  3AC   [8]  03 07 66 6F 20 20 20 20   '..fo    '
 (1389040747.855264)  vcan0  3AC   [8]  3B 08 20 47 69 76 69 6E   ';. Givin'
 (1389040747.887166)  vcan0  3AC   [8]  23 08 27 20 59 6F 75 72   '#.' Your'
 (1389040747.923526)  vcan0  3AC   [8]  13 08 73 65 6C 66 20 41   '..self A'
 (1389040747.949203)  vcan0  3AC   [8]  03 08 77 61 79 20 20 20   '..way   '
 (1389040747.986814)  vcan0  3AC   [8]  0B 01 20 20 20 20 20 20   '..      '
post #21 of 58 Old 01-06-2014, 09:08 PM
JoonHoss
2011 JK Wrangler
I wish I had even the slightest idea what all this means, 'cuz i'm fairly certain it's really kewl.
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #22 of 58 Old 01-07-2014, 08:31 AM
TheBoss
Hoss
It's quite elementary really, if you use a simple scan of the codes given throughout it repeatedly says I LIKE 80's ROCK BANDS ie Ratt Detonator album.
:-D
TheBoss is offline
post #23 of 58 Old 01-07-2014, 10:36 AM
JoonHoss
2011 JK Wrangler
See Boss- you lost me again with your new-fangled jargon
(my Ratt library only goes to Reach for The Sky...)
Hoss
JoonHoss is offline
post #24 of 58 Old 01-07-2014, 10:42 AM
TheBoss
Hoss
Gotcha, I could keep going and totally derail the progress here. So let's keep this "out of the cellar"
TheBoss is offline
post #25 of 58 Old 01-07-2014, 11:35 AM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
That is really cool, as an industrial electrical tech I am familiar with the usage of CAN Bus and other comm types, but I DO NOT understand it... I am curious what you are going to do with it. I've wondered about it in this vehicle, but never toyed with it, mainly due to fear of breaking it. (Put another way, I know just enough to be dangerous.) I am toying with the idea of using a Raspberry Pi and/or an Arduino to put sensor data onto a screen in my TJ since the gauge cluster is such a POS.
edit: Did you by chance post this on the Raspberry Pi site? This seems like a pretty sweet project that could use some publicity.
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #26 of 58 Old 01-07-2014, 02:14 PM Thread Starter
dcgibbons
2014 JK Wrangler
I did yep. Lots of folks doing similar things there for different vehicles.
UPDATE: this guy's post has one of the most reasonable explanations of CAN bus data in a vehicle, from the electrical aspects to the software aspects of it: http://fabiobaltieri.com/2013/07/23/...and-socketcan/
But it's deceptively simple, really. It's a network that allows nodes (computers!) to broadcast messages on the bus using specific message identifiers. That's different from a network like TCP/IP (Internet!) where the messages contains source and destinations ids - in the CAN world the message has an identifier that means something, such as "this is my current sirius station." It is up to all the nodes in the system to decide what messages they broadcast and which ones they receive.
It was designed-for and works-well in vehicle applications because the electrical characteristics are very robust, and it allows for very loose coupling between the various computers in the cars.
The audio/video stuff is a great example... the UConnect module broadcast messages about what's playing via the USB control, and it doesn't matter what radio is installed in the vehicle. All the radio (or some other display system) has to do is listen for those messages and do what it wants to do. Electrically, it's all over the same twisted-pair of wires no matter who is involved.
What varies a lot between vehicles is what is a CAN node, what is a LIN (local interconnect network) node, and how many different buses there are.
As another example, in the JK, we've got the cab compartment node (CCN) - effectively the big dash system. That talks to a bunch of different switches over LIN, such as the window switches, the heated switch switches, the control stalks, etc. It may do something with the commands from those switches entirely internally, or decide to broadcast a message out on the CAN bus for someone else to do something. Lights are a great example here:
  1. Turn on your lights via the control stalk, which sends a LIN message to the CCN
  2. The CCN changes its own displays appropriately.
  3. The CCN broadcasts that command over the CAN-IHS bus
  4. The TIPM receives that message and turns on the appropriate light circuits
  5. The Radio receives that same message and changes its display appropriately
post #27 of 58 Old 01-07-2014, 02:50 PM Thread Starter
dcgibbons
2014 JK Wrangler
So all of the hacking I am doing is centered around listening to existing messages from existing nodes in the car and doing something extra with that data (like turning on auxiliary lights), and also sending out my own versions of existing messages to change the display of the EVIC or Radio or whatever else I may find.
All of that is not changing any of the software in the car, it's just listening to and sending out existing messages and changing the behavior slightly.
While there's a lot that can be accomplished there, the super fun stuff is likely limited to changing the actual programming in an existing node, like the TIPM or CCN, rather than what I am doing.
post #28 of 58 Old 01-07-2014, 08:56 PM Thread Starter
dcgibbons
2014 JK Wrangler
In case this is useful, too (and a reminder that I really need to write up a post on how to build this thing step-by-step):
I didn't have a cad diagram for the receptacle end of the wiring harness, but you get the idea. It's a straight wiring for the 6 circuits my C2 harness had, plus splicing the 2 CAN connections off so bring to my CAN interface board. I think your harness will vary if you don't have an amplifier etc. There's a few options for that connector looking at the repair information.
For reference: Mopar Connection Repair Kit and 1438759-1 Product Details - TE
I actually bought some aftermarket radio repair harnesses off eBay to get that connector/receptacle cheap, though. TE doesn't make a receptacle mate for that connector that isn't part of a PCB mount solution.
post #29 of 58 Old 01-08-2014, 12:24 AM
ufgeek
Looks great. I'm interested in testing. I have an 07 JKU. I'm in Longmont, PM me. I'm a SW Engineer at QCOM, perhaps I can give you a hand on making this into something really interesting.
ufgeek is offline
post #30 of 58 Old 01-09-2014, 05:35 PM Thread Starter
dcgibbons
2014 JK Wrangler
I finished the 1st proof-of-concept for using the CAN-Bus data to control auxiliary relays. It worked great. Attached is a block diagram of what I used, and a longish video of how the testing went.
If you want to skip all the bench testing, the actual in-car testing happens at the 11:15 mark of the video.
www.youtube.com/embed/v64EYqzys0Q
Code for the demo can be found at https://github.com/dcgibbons/jeepbot/tree/poc1
A few hours after I finished, a bluetooth-low-energy board I ordered showed up. The next step will be to throw that on there so that I can use the smartphone to configure each switch and optionally control them by hand.
Each switch will have the following different possible control states:
  • always on
  • manual only
  • on when interior lights are on
  • on when high-beams are on
Right after that, I'll start working on a prototype PCB and housing so I can start testing real versions of this system.
I'll post the design, schematics and code in progress on my blog so anyone can offer feedback as it gets built.
accessories , electrical , hack
