Grab Handles and Straps - JeepForum.com
post #1 of 6 Old 05-05-2013, 05:50 PM Thread Starter
mdjk10
2010 JK Wrangler
Looking to add grab handles on both driver and passenger sides of my 2010 2 door Sport. What type works best? Also used factory straps to roll back window up this weekend, but for some reason the straps are elastic and the window hangs down too low. Any suggested fixes, or should I buy new straps from American Outlaw that appear to fix this problem? Or are there other better straps?
mdjk10 is offline
post #2 of 6 Old 05-05-2013, 05:58 PM
RockMonster
Get the cheapest ones unless you like the way the handles look or something.
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++ ++++
RockMonster is offline
post #3 of 6 Old 05-05-2013, 06:08 PM
wilywillie
grab handles that fasten in 3 places are least likely to wander around the bar....(if you have a manual, you'll never use it!)
On the rear window, I use some short nylon straps with velcro (REI, I think), mounted just inside that seam on the top, and it keeps the window up inside the top. They're mounted in such a place as to keep the window/channel from warping too badly in the summer sun...
...my $.02
I'm just here for the gasoline. --Max
wilywillie is offline
post #4 of 6 Old 05-05-2013, 07:32 PM
COLOUXJ
2010 JK Wrangler
I like http://www.surprisestraps.com/
They look good and are pretty cheap compared to the others. You can make ones like these on your own but it was not worth it to me for $40 to have someone do a good job on the mounting points.
COLOUXJ is offline
post #5 of 6 Old 05-05-2013, 08:24 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Grab handles on a bare cage can be very dangerous in a roll...the flexible handle rolls to the outside of the cage pinning your hand between the roll bar and against whatever you hit. We almost had an amputation on a trail in Moab a couple of years ago when the rig fell sideways into a
rock ledge...helivaced the person out and saved the hand. Best is to have fixed hand holds welded on or with clamps...after that accident, took mine off ASAP.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #6 of 6 Old 05-06-2013, 06:02 AM
Deuskid
I'm going to need grab handles of some kind. Looking for solutions.
Deuskid is offline
