Got some LED off road lights. Now what lol. - Page 2 - JeepForum.com
post #16 of 23 Old 04-24-2013, 03:09 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Originally Posted by Wavedatya View Post
So he sold me a wiring harness made for different lights? That's great. So now ill have to shop around for a new wiring harness? Or should I just go to a shop and have them finalize the wiring?
I don't plan on using any vehicle wires to control on or off. Ill just use the switch provided to avoid any ECU BS.
You can use an overrated harness - but never an underrated harness. Just put in a 10A fuse in place of the 30.
Always use the smallest fuse you can get by with for greatest protection - rule of thumb 25% over calculated draw - round up to next available fuse rate. SO a 7 draw needs a 10A fuse and a 7.2 draw should go to 15A (as there is no 12.5).
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #17 of 23 Old 04-24-2013, 03:25 PM Thread Starter
Wavedatya
2010 JK Wrangler
Oh ok the harness is over kill lol.
I just don't wanna catch fire or have any electrical issues. I'm prob way over reacting lol. Ill put a 10 fuse in. Thanks so much for the advice folks. Sorry for such noob like questions
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #18 of 23 Old 04-24-2013, 04:04 PM
YATZI1980
2011 JK Wrangler
Exactly. Sorry I left that off. 10 amp fuse is perfect. Your wiring is rated to handle 30 amps so you are golden. You could use that set up to power 6 lights if you wanted to. Ive seen # 10 wire (typically used for 30 amp but uses vary code allows up to 40amps) hold 300 amps and not burn insulation till around 400amps. Those numbers are under test conditions and I would never use that as a guide.
YATZI1980 is offline
post #19 of 23 Old 04-25-2013, 06:24 AM
GauchoMark
2011 JK Wrangler
YATZI1980 is right. He caught my typo! I was trying to say that a 30A fuse sounds high.
At any rate, it looks like you got them working, just lower that fuse some so it is actually protecting your wiring and equipment.
GauchoMark is offline
post #20 of 23 Old 04-25-2013, 08:46 PM Thread Starter
Wavedatya
2010 JK Wrangler
Lights hooked up! Looks really bright. Can't even look at em they're so bright! I guess that's kind if the point though eh? Lol.
I'm super excited and can't wait to see what the puppies can do.
Thanks for all the help guys. As always this, forum rocks!
post #21 of 23 Old 04-26-2013, 06:09 AM Thread Starter
Wavedatya
2010 JK Wrangler
All the lights wired up. What a pain and apparently electrical isn't my thing. They work though lol.
My dad is a certified electrician and obviously I did not get the gene lol. Wired the switch through the cowl ad mounted switch just above the door hook so it's hidden and clean looking.
Again, thanks guys.
And as a bonus i cleaned the garage out and able to fit in now. So the wife and I can park out of the elements!!! Handy in the winter .
post #22 of 23 Old 04-26-2013, 08:05 AM
sjones26573
Again, thanks guys.
Attachment 615843
I was never a fan of those integrated push button switches. When I got my stepdad a Hella harness for some lights that came on the Jeep, first thing I did was cut that cheap switch off and wire it to a decent rocker.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #23 of 23 Old 05-21-2014, 01:25 PM
rafaelm
How bright are these lights compared to 100W halogens?
rafaelm is offline
