on going JK questions - JeepForum.com
post #1 of 4 Old 05-15-2013, 10:46 AM Thread Starter
desertriding
Picking up my 2013 2 dr Rubicon in 60-90 days ...planning on trying to immediately trade the stock rims/tires to a tire dealer (Les Schwab in Oregon) for at least 33's.and do a Pro Cal recalibration. Will also go to the 2.5" Tera Flex spring lift with the shock extensions as soon as is possible. Front bumper will also be changed to a Quadratek winch bumper package.....all initially. Later in fall I will access the skid situation.
Questions: If I change the tires right away and later add the lift W/in weeks, will a Jeep dealer give me problems with warrenty issues if any? The servicing dealer will not be the same dealer as the selling dealer (different states)?? If I get new rims (17") how much of an off-set rim (whose and dimentions) do I need if going wider to say something like 33/ 12:50's and not using wheel spacers. Have read several threads (several of mine as well) and am still confused....I do not initially want to go hard core this rig will be dual purpose, and get me where i want to go without body damage.
All recommendations and thoughts are welcome...thanks in advance....Desertriding's new on/off road project....
desertriding is offline
post #2 of 4 Old 05-15-2013, 10:58 AM
KrawlOff-Road
Vendor
KrawlOff-Road's Avatar
The Dealer warranty is up to the dealer. I would contact them to make sure first.
On thing to keep in mind with the TeraFlex 2.5" lift is you have to run wheels with 4.5" or less BS or wheel spacers. So, keep that in mind if you swap out the wheels.
If there is anything we can do or if you have any quesitons, please feel free to PM, email, or call us at anytime!
-Jason
Phone: 864-437-8029
Forum Discount: KORJEEPFORUM
KrawlOff-Road is offline
post #3 of 4 Old 05-15-2013, 11:04 AM
mello
Dealer's do not like vehicles that were not bought at their dealership. They will work on it but might not be as willing to work with you as selling dealer. Time will for sure tell though.
mello is offline
post #4 of 4 Old 05-15-2013, 12:06 PM
222Doc
222Doc's Avatar
They can void any of the related warranty to the mods as related to the issue it had caused. IF you very worried about this best to keep it stock. You break an axle they can say it was from the larger tires. The radio breaks they can not say it was from the lift. If drive lines go bad after the lift, they can and have a right to say its do to the lift. some are picky some are not. Fact is they can pull the ABUSE card at will as well. depends on the dealer and how you talk to them.
222Doc is offline
