Going bigger, need advice - JeepForum.com
post #1 of 4 Old 08-26-2012, 05:13 PM Thread Starter
smartbutlazy374
2011 JK Wrangler
I have a 2.5 lift on and wanting to go bigger, I already have some ideas on what lift im going to get next, but dont know which one to get right now im looking at 4 different lifts
1) 3.5" Super-Flex Short Arm Suspension System
2)RCD Suspension 4" Lift Kit
3.) AEV 3.5" DualSport SC Suspension System with Bilstein Shocks
4.) 4 Phase II Lift Kit (made by 4wp)
And to answer the questions people may ask, yes this jeep will be wheeled (60% highway 40% off road) I do realize i will need to change the drive shafts so i will (not right away) I would like to run a 37 with flat flares.
So if any of you have any experiance with any of these lifts please give me some info. Thanks!
"This is why you do all your mods before you get a wife." - WhiteOut
"I have come to the conclusion that the wave is NOT a Jeep thing- it is a WHEELER thing." -N2rock
smartbutlazy374 is offline
post #2 of 4 Old 08-26-2012, 05:21 PM Thread Starter
smartbutlazy374
2011 JK Wrangler
Forgot to mention, shocks dont really matter because im getting Profender shocks.
post #3 of 4 Old 08-26-2012, 05:26 PM
MrSmiley
Absoutly none of those. I would go with a RK 3.5" kit with full CA and High Steer. or a TF 3-4" with High Steer. You could then run 37's with flats and bee fine.
MrSmiley is offline
post #4 of 4 Old 08-27-2012, 08:19 AM
Joevacs
2010 JK Wrangler
Spend your money wisely. Especially since you are already doing this for the second time. ( I wasted a lot of money the first time too )
get Currie and be done with it.
http://www.currieenterprises.com/ces...t.aspx?id=2908
2010 Rubicon, 4" lift, Currie control arms and trackbar, 40" Procomp MTR
Joevacs is offline
lift advice
Need advice to install bigger brakes kms JK Wrangler Technical Forum 9 06-12-2012 07:35 PM
Bigger tires and bigger brakes GPV JK Wrangler Technical Forum 11 01-19-2012 06:53 AM
Bigger tires, bigger problem. CopMech YJ Wrangler Technical Forum 5 04-20-2010 07:21 AM
Bigger Lift means Bigger Problems?? Jeep Kid TJ Wrangler Technical Forum 1 03-08-2008 04:41 PM
Lift + Bigger Tires - Really Need Advice steve3911 TJ Wrangler Technical Forum 10 09-10-2004 09:49 PM
