I have recently put 33x13.50x18 tires on my Wrangler JK and I have noticed a significant loss of power from my Jeep. I would like to know if there are any inexpensive ways to help improve the power. I already installed a 3 inch cold air intake and I know I need to get new gears but I am looking for other methods as well. Any ideas would be appreciated.
P.S. I am hoping to keep from sacrificing my fuel economy any more as this is my everyday driver.
Putting stock tires back on is not an option as I am starting to do some more off roading. Plus I like the look of it. So i guess I will just have to drop some money.
Regear. When you increased the tire size, you decreased the final gear ratio. The only way to correct that is to regear the axles to compensate. There's a great chart in the FAQ up top that will get you to the right gear set.
Don't worry about the mpg. If you don't go overboard and start running 4k rpms downt he highway, you will do fine.
Take the "cold air" intake off. It's robbing low end torque to turn the tires.
Sell the CAI and try to make $100 bucks off it.. then use that money as a down payment on a gear install. The only way to truly compensate for all that mass, weight, and diameter you've added is by using a different transmission or different axle gears. Axle gears are cheaper.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
