General Maintenance Questions - JeepForum.com
post #1 of 10 Old 04-11-2013, 10:42 AM Thread Starter
DickSnuffy
2010 JK Wrangler
I have a 2010 JK with 43,000 miles on it. I purchased it from the dealership used with 7,000 miles on it. Since purchasing it, I have done no maintenance to it other than changing the oil at regular intervals. I contacted the dealership and asked them about it and they recommended that I get I believe either a 30,000 mile or 40,000 mile service for which they wanted around $400. That seems extremely pricey to me for what is basically fluid changes if I'm not mistaken. My question is what exactly you should do to maintain a JK, as far as maintenance and if i can do any of this myself. Any and all input is appreciated.
Thanks in advance!
DickSnuffy is offline
post #2 of 10 Old 04-11-2013, 10:53 AM
ncb
Follow the schedule on the owners manual. All of the fluid changes can be done in your garage.
ncb is offline
post #3 of 10 Old 04-11-2013, 11:54 AM
Wavedatya
2010 JK Wrangler
I would say oil. Transfer case. Both axles. There are plenty of great write ups and if you browse the sticky section you'll find a few. Also look up YouTube and google. And see if you can find some vids. I do my axles in under 30 minutes front and back
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #4 of 10 Old 04-11-2013, 01:26 PM
CoreyZ
This... and if you have an auto, consider draining and replacing the fluid. TBH, any time you buy a used auto, you should consider doing all of those just so you can begin with your own maintenance cycle.
Then start checking your bushings for wear, hoses too.
Spark plug wires, plugs themselves... etc
'12 JK COD:MW3 Edition
'10 WK, Black(sold)
Colorado Jeep Club member #217
CoreyZ is offline
post #5 of 10 Old 04-11-2013, 03:38 PM
rirrgang
X2 on following the manual. Don't guess and take the "I would say" or I would do". Just follow the manual and you'll be fine. The schedule is there for a reason.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #6 of 10 Old 04-11-2013, 04:08 PM Thread Starter
DickSnuffy
2010 JK Wrangler
I was curious as to wether some shop oter than the dealer could be trusted to do the service as I don't really have all the time in the world, thoughts?
post #7 of 10 Old 04-11-2013, 04:14 PM
smcutter
Just avoid the Quick and Dirty oil change shops like Jiffy Lube and EZ Lube and such. Get referrals from other Jeep owners in your area.
For the record, I'm probably judging you for your bad grammar or spelling.
smcutter is offline
post #8 of 10 Old 04-11-2013, 04:24 PM
Wavedatya
2010 JK Wrangler
4x4 shops would be a great place to start of you want a better chance at quality service. Lots in my area provide maintenance services and have decent prices.
Although a axle is usually $100 I can do both for that price.
post #9 of 10 Old 04-11-2013, 11:46 PM
davidsonlaw
Changing the oil on these things is not difficult, particularly if you have any kind of lift on your jeep. Change the diff oil is ridiculously simple and quick. You'll spend more time on your iphone surfing the web while the fluids drain than you will actually turning a wrench or pouring.
http://www.davidson-law.net/blogs/jeeplaw/
davidsonlaw is offline
post #10 of 10 Old 04-12-2013, 08:55 AM
rirrgang
I use a trusted tech around the corner from me. He's honest, knowledgeable and gets me in and out of the shop quickly.
Keep records and you'll be fine
-Rick
07 Sahara Unlimited
rirrgang is offline
jk , maintenance
